Verticle menu showing as horizontal
eleanor
eleanor posted this 31 August 2022
I have a vertical menu showing as horizontal in the footer of my contact page.
The rest of the pages are fine and the menu is showing as vertical.
Can you help?
https://woodfloors.ywdw.co.uk/index.php/contact-us
thank you
Eleanor
Hi I have a vertical menu showing as horizontal in the footer of my contact page. The rest of the pages are fine and the menu is showing as vertical. Can you help? https://woodfloors.ywdw.co.uk/index.php/contact-us thank you Eleanor
eleanor
eleanor posted this 21 September 2022
Hiya
Please could you have a look at this for me?
Hiya Please could you have a look at this for me? Thank you
Support Team posted this 28 September 2022
Hello Eleanor,
Sorry for the delay. Is Module Class Suffix specified correctly for the menu module and assigned to all pages? Is the menu placed into a module position as usual?
Hello Eleanor, Sorry for the delay. Is Module Class Suffix specified correctly for the menu module and assigned to all pages? Is the menu placed into a module position as usual? Sincerely, Nettie
eleanor
eleanor posted this 28 September 2022
Hi Nettie
Everything is as usual.
I remember having this trouble before, I can't find a post to help me but from memory I think it was to do with the RSForm being on that page.
Hi Nettie Everything is as usual. I remember having this trouble before, I can't find a post to help me but from memory I think it was to do with the RSForm being on that page.
Support Team posted this 30 September 2022
Can it be this case as well? Could you please try temporarily disabling third-party modules and components, clear cache and see if there is any difference?
Hello, Can it be this case as well? Could you please try temporarily disabling third-party modules and components, clear cache and see if there is any difference? Sincerely, Nettie
eleanor
eleanor posted this 30 September 2022
Hi Nettie
yep that's the issue. RSForm.
Can you give me any code to add to make the menu vertical on the contact page?
Hi Nettie yep that's the issue. RSForm. Can you give me any code to add to make the menu vertical on the contact page? Thank you
eleanor
eleanor posted this 11 November 2022
Hiya
Any solution to this yet?
Hiya Any solution to this yet? Thank you
eleanor
I've changed the vmenu on the website I mentioned at the top of this post to a block so please have a look at this one with the same issue.
Thank you.
https://firstincare.co.uk/contact
I've changed the vmenu on the website I mentioned at the top of this post to a block so please have a look at this one with the same issue. Thank you. https://firstincare.co.uk/contact
