WooCoomerce - Disable Product-Image Zoom
@ITS
@ITS posted this 31 August 2022
Hey,
i cant disable the Product Image Zoom for Woocommerce in Wordpress with Snippset in the functions.php or Plugin.
Only a CSS Hack works... but not the best Solution.
this works...
.cloud-zoom-big, .cloud-zoom-lens, .cloud-zoom-tint, .cloud-zoom-soft {
    display:none!important;
this works not.. why ???
i try in wordpress theme functions.php and the functions.php for "woocommerce" in the theme.
function no_zoom() {
remove_theme_support( 'wc-product-gallery-zoom' );
add_filter( 'woocommerce_single_product_zoom_enabled', 'no_zoom' );
or
add_filter( 'woocommerce_single_product_photoswipe_enabled', 'remove_wc_gallery_lightbox' );
function remove_wc_gallery_lightbox() {
  remove_theme_support( 'wc-product-gallery-lightbox' );
please have you an correct snippset for themler templates ?
Hey, i cant disable the Product Image Zoom for Woocommerce in Wordpress with Snippset in the functions.php or Plugin. Only a CSS Hack works... but not the best Solution. this works... .cloud-zoom-big, .cloud-zoom-lens, .cloud-zoom-tint, .cloud-zoom-soft { display:none!important; } this works not.. why ??? i try in wordpress theme functions.php and the functions.php for "woocommerce" in the theme. function no_zoom() { remove_theme_support( 'wc-product-gallery-zoom' ); } add_filter( 'woocommerce_single_product_zoom_enabled', 'no_zoom' ); or add_filter( 'woocommerce_single_product_photoswipe_enabled', 'remove_wc_gallery_lightbox' ); function remove_wc_gallery_lightbox() { remove_theme_support( 'wc-product-gallery-lightbox' ); } please have you an correct snippset for themler templates ?
16 Comments
donna641flint
donna641flint posted this 13 September 2025
That's an excellent and creative workaround. You've correctly identified a way to bypass Plotly Studio's default behavior of copying a static file into the project. By writing a direct choiceADVANTAGE command in the Data module, you're instructing the software to read from the live file path every time, which is a great way to handle local data exploration. As you noted, this method is limited to your local machine because the specific file path wouldn't exist on a remote deployment server.
That's an excellent and creative workaround. You've correctly identified a way to bypass Plotly Studio's default behavior of copying a static file into the project. By writing a direct [choiceADVANTAGE][1] command in the Data module, you're instructing the software to read from the live file path every time, which is a great way to handle local data exploration. As you noted, this method is limited to your local machine because the specific file path wouldn't exist on a remote deployment server. [1]: https://www.choiceadvantage.com.co
hazeldavid240
hazeldavid240 posted this 23 September 2025
Well, the same issue I encountered last week at a cafe while working for my client remotely here in Alaska. It was freezing cold, so I had to sit outside because the cafe was filled with double layers of varsity jackets. As for your problem, let's fix that. Why it's not working is because the remove_theme_support() function must be called after your theme is fully set up and ready, i.e., inside the after_setup_theme action. Also, disabling WooCommerce's zoom or lightbox won't stop third-party scripts (like Cloud Zoom) from initializing.
Well, the same issue I encountered last week at a cafe while working for my client remotely here in Alaska. It was freezing cold, so I had to sit outside because the cafe was filled with double layers of [**varsity jackets**][1]. As for your problem, let's fix that. Why it's not working is because the **remove_theme_support()** function must be called after your theme is fully set up and ready, i.e., inside the **after_setup_theme** action. Also, disabling WooCommerce's zoom or lightbox won't stop third-party scripts (like Cloud Zoom) from initializing. [1]: https://americanjacketsmaker.com/category/men-varsity-jacket/
layijad338
layijad338 posted this 22 October 2025
Get the latest VMware 2V0-13.25 practice questions at Examcollection.us. Strengthen your skills in VMware Horizon Cloud and virtual desktop infrastructure to pass your Professional Desktop and Mobility certification with confidence.
Get the latest VMware [2V0-13.25 practice questions][1] at Examcollection.us. Strengthen your skills in VMware Horizon Cloud and virtual desktop infrastructure to pass your Professional Desktop and Mobility certification with confidence. [1]: https://www.examcollection.us/2V0-13-25-vce.html
henryharvin2000
henryharvin2000 posted this 24 April 2026
New American Jackets transforms legendary style inspiration like the talking heads large suit into modern jackets. We combine oversized design elements with high-quality tailoring to create fashion pieces that are expressive, unique, and unforgettable.
New American Jackets transforms legendary style inspiration like the [talking heads large suit][1] into modern jackets. We combine oversized design elements with high-quality tailoring to create fashion pieces that are expressive, unique, and unforgettable. [1]: https://www.newamericanjackets.com/product/stop-making-sense-1984-david-byrne-big-suit.html
blogs
blogs posted this 30 April 2026
TV Jackets offers simple, wearable styles designed for everyday comfort and ease. The focus stays on clean fits and practical designs that blend naturally into your routine without feeling overdone. Each piece adds a subtle touch of personality while staying easy to style. If you want something inspired by music legends, exploring Michael Jackson inspired outfits is a great way to bring a bold and iconic touch to your wardrobe.
TV Jackets offers simple, wearable styles designed for everyday comfort and ease. The focus stays on clean fits and practical designs that blend naturally into your routine without feeling overdone. Each piece adds a subtle touch of personality while staying easy to style. If you want something inspired by music legends, exploring [Michael Jackson inspired outfits][1] is a great way to bring a bold and iconic touch to your wardrobe. [1]: https://www.tvjackets.com/category/celebrity-inspired-outfits/
sunnyhenry766
sunnyhenry766 posted this 30 April 2026
Tweaking small features like image zoom can really improve user experience and make your product pages feel cleaner and more professional. It’s helpful to see simple solutions that enhance site performance and design without complex coding. Optimizations like these are essential for e-commerce success just like platforms such as J4Jacket, which focus on delivering a smooth and stylish shopping experience.
Tweaking small features like image zoom can really improve user experience and make your product pages feel cleaner and more professional. It’s helpful to see simple solutions that enhance site performance and design without complex coding. Optimizations like these are essential for e-commerce success just like platforms such as [J4Jacket][1], which focus on delivering a smooth and stylish shopping experience. [1]: https://www.j4jackets.com/
americajackets.links
americajackets.links posted this 30 April 2026
Americajackets presents premium Law and Order TV Series Outfits designed to reflect iconic television style with a modern edge. Each piece is crafted using high-quality materials and precise tailoring, offering durability, comfort, and a refined appearance suitable for everyday fashion.
Americajackets presents premium [Law and Order TV Series Outfits][1] designed to reflect iconic television style with a modern edge. Each piece is crafted using high-quality materials and precise tailoring, offering durability, comfort, and a refined appearance suitable for everyday fashion. [1]: https://www.americajackets.com/category/law-and-order-tv-series-outfits/
zellberry3
zellberry3 posted this 30 April 2026
Small UI tweaks like this can make a big difference in user experience, especially for cleaner layouts and faster browsing. It’s always helpful to see simple, practical solutions that improve store performance without heavy customization. Optimizations like these are essential for any e-commerce brand just like Zellberry Outfits, which focuses on delivering a smooth and stylish shopping experience.
Small UI tweaks like this can make a big difference in user experience, especially for cleaner layouts and faster browsing. It’s always helpful to see simple, practical solutions that improve store performance without heavy customization. Optimizations like these are essential for any e-commerce brand just like [Zellberry Outfits][1], which focuses on delivering a smooth and stylish shopping experience. [1]: https://www.zellberry.com/
david_jimmy1234
david_jimmy1234 posted this 07 May 2026
If you want to disable product image zoom in WooCommerce, you can usually adjust it from theme settings or customize the single product scripts. Another option is to override the default zoom feature using a small CSS/JS tweak for better control. For related reference insights on property data systems, Madison Property Records can be helpful to explore structured record handling ideas. You can also check if your theme has built-in WooCommerce compatibility options to turn off zoom effects cleanly. This approach keeps your product pages lightweight and improves user experience across devices.
If you want to disable product image zoom in WooCommerce, you can usually adjust it from theme settings or customize the single product scripts. Another option is to override the default zoom feature using a small CSS/JS tweak for better control. For related reference insights on property data systems, [Madison Property Records][1] can be helpful to explore structured record handling ideas. You can also check if your theme has built-in WooCommerce compatibility options to turn off zoom effects cleanly. This approach keeps your product pages lightweight and improves user experience across devices. [1]: https://madisoncountypropertyappraiser.org
Janny-Jon
Janny-Jon posted this 07 May 2026
Disabling product-image zoom in WooCommerce is a solid choice when aiming for a cleaner product view and faster user interaction. It can also help improve mobile usability where zoom effects often feel intrusive. For more structured access to detailed case and record information, you can check Riverside Court Records which organizes useful legal references in a clear format. Additionally, keeping plugin settings lightweight like this can improve overall site performance and UX consistency. Good adjustment if the goal is a more streamlined shopping experience.
Disabling product-image zoom in WooCommerce is a solid choice when aiming for a cleaner product view and faster user interaction. It can also help improve mobile usability where zoom effects often feel intrusive. For more structured access to detailed case and record information, you can check [Riverside Court Records][1] which organizes useful legal references in a clear format. Additionally, keeping plugin settings lightweight like this can improve overall site performance and UX consistency. Good adjustment if the goal is a more streamlined shopping experience. [1]: https://riversidecountycourts.org
slimfitjacket.sj
slimfitjacket.sj posted this 08 May 2026
Great tip for WooCommerce! Disabling product image zoom improves UX and page speed. Works well for fashion stores selling belted long coat women items. Clear and useful guide.
Great tip for WooCommerce! Disabling product image zoom improves UX and page speed. Works well for fashion stores selling [belted long coat women][1] items. Clear and useful guide. [1]: https://www.etsy.com/listing/4498101338/womens-red-leather-trench-coat-handmade
roaimhaiderofficial
roaimhaiderofficial posted this 08 May 2026
Disabling product image zoom in WooCommerce can improve user experience for furniture catalogs where detailed layout clarity matters more than zoom interactions, especially for premium brands like Lane Furniture
where customers often rely on full-room visuals rather than close-up inspection. For such stores, removing zoom helps keep browsing smooth and prevents layout disruptions on product pages while maintaining a clean, professional presentation. This approach is particularly useful for enhancing performance and ensuring that shoppers focusing on Lane Furniture collections can view products consistently without unnecessary interactive distractions.
Disabling product image zoom in WooCommerce can improve user experience for furniture catalogs where detailed layout clarity matters more than zoom interactions, especially for premium brands like [Lane Furniture][1] where customers often rely on full-room visuals rather than close-up inspection. For such stores, removing zoom helps keep browsing smooth and prevents layout disruptions on product pages while maintaining a clean, professional presentation. This approach is particularly useful for enhancing performance and ensuring that shoppers focusing on Lane Furniture collections can view products consistently without unnecessary interactive distractions. [1]: https://lanefurnitureco.com/ottomans/
william_jhones2
william_jhones2 posted this 09 May 2026
That’s a useful tweak for improving the shopping experience, especially for users browsing on mobile devices. I’ve seen a few store owners combine this with optimized image loading and better gallery settings for smoother performance. Resources related to under the term Clay County Evidence also show how organized media handling can improve overall usability and accessibility. Small adjustments like this can make product pages feel much cleaner and more professional for visitors.
That’s a useful tweak for improving the shopping experience, especially for users browsing on mobile devices. I’ve seen a few store owners combine this with optimized image loading and better gallery settings for smoother performance. Resources related to under the term [Clay County Evidence][1] also show how organized media handling can improve overall usability and accessibility. Small adjustments like this can make product pages feel much cleaner and more professional for visitors. [1]: https://claycountycourts.org
ginisharma143
ginisharma143 posted this 11 May 2026
Find sophisticated Delhi escorts and charming independent companions for elite dating, classy evenings, and exclusive private experiences designed for comfort, excitement, and complete discretion
Call Girls in Delhi
Find sophisticated [Delhi escorts][1] and charming independent companions for elite dating, classy evenings, and exclusive private experiences designed for comfort, excitement, and complete discretion [Call Girls in Delhi][2] [1]: https://rukkso.com/call-girls/delhi [2]: https://rukkso.com/call-girls/delhi
gorillafight684
gorillafight684 posted this 4 weeks ago
Discover successful stores and popular product ideas. Explore trending Etsy shops to find inspiration for your own Etsy strategy.
Discover successful stores and popular product ideas. Explore [trending Etsy shops][1] to find inspiration for your own Etsy strategy. [1]: https://www.etsyoptima.io/features/trending-shops
eddielydon0
eddielydon0 posted this 18 hours ago
Our the purpose is to share the reviews about the latest Jackets,Coats and Vests also share the related Movies,Gaming, Casual,Faux Leather and Leather materials available. clark kent red jacket
Our the purpose is to share the reviews about the latest Jackets,Coats and Vests also share the related Movies,Gaming, Casual,Faux Leather and Leather materials available. [clark kent red jacket][1] [1]: https://www.jacketsmasters.com/product/smallville-clark-kent-red-jacket/
