Request failed: 500
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 14 September 2022
Unfortunately I get this error message when I try to install the Themler plugins on Joomla 4.2.2 and a fresh Themler beta version.
What can be the reason?
Many thanks for the help.
Best regards
Thorsten
Hello, Unfortunately I get this error message when I try to install the Themler plugins on Joomla 4.2.2 and a fresh Themler beta version. What can be the reason? Many thanks for the help. Best regards Thorsten
16 Comments
Support Team posted this 14 September 2022
Is the issue reproducible with the theme in attachment?
Hello, Is the issue reproducible with the theme in attachment? Sincerely, Nettie
Thank you.
Same Problem, sorry.
Hello, Thank you. Same Problem, sorry.
Werbeagentur Schulz-Design posted this 15 September 2022
Hello Nettie,
i changed the php version to 7.4 and was able to install the Themler plugins.
Now, however, Themler will not start. I just get an error message: 'Sorry, an error has occurred. Please clear your browser cache.'
I keep trying.
Hello Nettie, i changed the php version to 7.4 and was able to install the Themler plugins. Now, however, Themler will not start. I just get an error message: 'Sorry, an error has occurred. Please clear your browser cache.' I keep trying.
When I go back to PHP 8, I have the problem again that the 'Edit Template' button can be pressed, but has no effect. Nothing happens except the button appears pressed.
Templates-Stil-bearbeiten---Heilbronner-Weihnachtscircus---Administration---2022-09-15-14.15.46.jpg
All very strange!
Do you have any idea?
When I go back to PHP 8, I have the problem again that the 'Edit Template' button can be pressed, but has no effect. Nothing happens except the button appears pressed. !Templates-Stil-bearbeiten---Heilbronner-Weihnachtscircus---Administration---2022-09-15-14.15.46.jpg! All very strange! Do you have any idea?
When I try to load the template in Themler desktop version I get the following error message:
Parse error: syntax error, unexpected 'class' (T_CLASS), expecting identifier (T_STRING) or variable (T_VARIABLE) or '{' or '$' in C:\ProgramData\Themler\hd_data\themler_1325589969\joomla\templates\untitled1\app\index.php on line 34
I'm getting a little impatient as the website is for a circus that sells tickets and it's already pretty stressful...
Need HELP!
When I try to load the template in Themler desktop version I get the following error message: > Parse error: syntax error, unexpected 'class' (T_CLASS), expecting identifier (T_STRING) or variable (T_VARIABLE) or '{' or '$' in C:\ProgramData\Themler\hd_data\themler_1325589969\joomla\templates\untitled1\app\index.php on line 34 I'm getting a little impatient as the website is for a circus that sells tickets and it's already pretty stressful... Need HELP!
I made a complete backup of the Joomla CMS and installed it on another server.
The result was the same: the editor button can be pressed, but nothing happens.
I have already installed an executable J4 test version on the server with which I can also start and edit Themler.
I exported this theme and installed it in the problematic installations. Unfortunately that didn't help either.
Disabling several extensions didn't help either.
I'm at a loss!
I made a complete backup of the Joomla CMS and installed it on another server. The result was the same: the editor button can be pressed, but nothing happens. I have already installed an executable J4 test version on the server with which I can also start and edit Themler. I exported this theme and installed it in the problematic installations. Unfortunately that didn't help either. Disabling several extensions didn't help either. I'm at a loss!
Support Team posted this 15 September 2022
Is it possible to temporarily install the theme on Joomla 4.1 or 4.0? With PHP 8.
Hello, Is it possible to temporarily install the theme on Joomla 4.1 or 4.0? With PHP 8. Sincerely, Nettie
I don't think so as the website has already been updated to 4.2.2.
I had to react and have now imported a backup with J3.
However, there is still the installation from the backup on my server.
I don't think so as the website has already been updated to 4.2.2. I had to react and have now imported a backup with J3. However, there is still the installation from the backup on my server.
I am now having the same problem with another website. J 4.2.2. PHP 8 Themler 566
The website is on a different server.
The only connection is that the site was previously migrated from J 3.10.11 to J 4.2.2.
With a new installation, the problems do not exist.
I am now having the same problem with another website. J 4.2.2. PHP 8 Themler 566 The website is on a different server. The only connection is that the site was previously migrated from J 3.10.11 to J 4.2.2. With a new installation, the problems do not exist.
Sorry, Themler 556
Sorry, Themler 556
Werbeagentur Schulz-Design posted this 20 September 2022
No reaction?
No reaction?
Werbeagentur Schulz-Design posted this 02 February 2023
This problem persists. :-(
**This problem persists.** :-(
Werbeagentur Schulz-Design posted this 06 February 2023
I'm getting really annoyed!
Errors are not or no longer corrected.
Support rarely responds.
A further development of Themler cannot be determined.
I am considering taking legal action against your company and claiming damages against you! After all, you have publicly claimed several times that Themler is being developed further and is still selling subscriptions. I documented all this with screenshots.
I'm getting really annoyed! Errors are not or no longer corrected. Support rarely responds. A further development of Themler cannot be determined. I am considering taking legal action against your company and claiming damages against you! After all, you have publicly claimed several times that Themler is being developed further and is still selling subscriptions. I documented all this with screenshots.
loyalnot0
loyalnot0 posted this 22 October 2025
It sounds like there might have been a temporary issue with the server, which can sometimes cause a 500 error. You could try clearing your browser cache or checking back after a short while to see if the issue resolves. For those looking to explore https://sanjoaquincountycourt.us or related case details, it’s a good idea to verify the latest updates directly through official channels to ensure accuracy and reliability.
jack12hack16
jack12hack16 posted this 22 October 2025
It seems like there might be a technical issue causing the “Request failed: 500” error. This usually happens due to a temporary server-side glitch or an overload. You can try refreshing the page or clearing your cache to see if it resolves. For more detailed insights on similar technical and judicial updates, you can check out https://palmbeachcountycourt.us for helpful information.
pelotalibre234
pelotalibre234 posted this 23 October 2025
Pelota Libre TV: Ver Futbol Libre online en vivo y directo. Disfruta de partidos de la Copa Libertadores, Sudamericana y del fútbol argentino como River Plate y Boca Juniors. Canales como TyC Sports, ESPN, Fox Sports y TNT transmiten eventos internacionales gratis.
https://pelota-libre.co/
Pelota Libre TV: Ver Futbol Libre online en vivo y directo. Disfruta de partidos de la Copa Libertadores, Sudamericana y del fútbol argentino como River Plate y Boca Juniors. Canales como TyC Sports, ESPN, Fox Sports y TNT transmiten eventos internacionales gratis. https://pelota-libre.co/
