JoomUnited - Dictionary
geri108
geri108 posted this 14 September 2022
Hi! I use the JoomUnited dictionary module on my website. The module does not display properly and the JoomUnited customer service provided the following information:
"This is the issue of your pagination. I find the function in
/templates/nyomda108_v1_220813/functions.php
there the function is written renderTemplateFromIncludes.
also this is written in pagination in our code. either you can disable the pagination or check with template developer and try to fix the pagination."
Can you fix it?
The page: https://co-print.hu/!uj/
The wrong dictionary page: https://co-print.hu/!uj/nyomda/nyomda-szotar
Thank you, Gergő
Hi! I use the JoomUnited dictionary module on my website. The module does not display properly and the JoomUnited customer service provided the following information: "This is the issue of your pagination. I find the function in /templates/nyomda108_v1_220813/functions.php there the function is written renderTemplateFromIncludes. also this is written in pagination in our code. either you can disable the pagination or check with template developer and try to fix the pagination." Can you fix it? The page: https://co-print.hu/!uj/ The wrong dictionary page: https://co-print.hu/!uj/nyomda/nyomda-szotar Thank you, Gergő
Support Team posted this 15 September 2022
Hello Gergő,
Does it work correctly with the default Joomla theme enabled?
Did you try to remove the pagination control?
Hello Gergő, Does it work correctly with the default Joomla theme enabled? Did you try to remove the pagination control? Sincerely, Nettie
geri108
geri108 posted this 15 September 2022
Hello Nettie,
Yes, it works perfectly with the joomla template and even if I hide the page numbers.
But if I display the pagination, it falls apart.
Gergő
Hello Nettie, Yes, it works perfectly with the joomla template and even if I hide the page numbers. But if I display the pagination, it falls apart. Gergő
