0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
Pierre665
Pierre665 posted this 19 September 2022
I found where the problem came from. It's the menu link to a "separator" that is not supported.
Can you correct this?
Pierre
Hello, I found where the problem came from. It's the menu link to a "separator" that is not supported. Can you correct this? Regards, Pierre
32 Comments
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 21 April 2023
Hello Support,
when will this problem be fixed?
Can anyone answer here?
Hello Support, when will this problem be fixed? Can anyone answer here?
dietrichvidal
dietrichvidal posted this 27 April 2023
Dear Support, When will this issue be resolved? basketball stars
Can anyone here respond?
Dear Support, When will this issue be resolved? [basketball stars][1] Can anyone here respond? [1]: https://basketball-stars.co/
neskemiquel
neskemiquel posted this 01 May 2023
could you share more information please ? Price Chopper Direct Connect Login
could you share more information please ? [Price Chopper Direct Connect Login][1] [1]: https://www.pricechopperdirectconnect.org/
rorygwgehman
rorygwgehman posted this 03 May 2023
To fix the issue, you may want to consider removing the link to the unsupported "separator" or replacing it with a supported menu item, such as a page or category. Alternatively, if your website's platform or theme supports custom coding, you may be able to modify the menu code to add support for the "separator" item. www.tigerishome.com
To fix the issue, you may want to consider removing the link to the unsupported "separator" or replacing it with a supported menu item, such as a page or category. Alternatively, if your website's platform or theme supports custom coding, you may be able to modify the menu code to add support for the "separator" item. [www.tigerishome.com][1] [1]: https://www.tigerishome.us/
larvaraaa
larvaraaa posted this 22 May 2023
Pizza Tower #1 gg .Play it now, because it's all free. Enjoy hours of fun with us.
[Pizza Tower](https://pizza-tower.io) #1 gg .Play it now, because it's all free. Enjoy hours of fun with us.
carl481
carl481 posted this 05 June 2023
I hope it is working now. hvac contractors in nj poop scoop service real estate marketing agency
I hope it is working now. [hvac contractors in nj][1] [poop scoop service][2] [real estate marketing agency][3] [1]: https://www.profgatsby.com/ [2]: https://www.k9doodiepatrol.com/ [3]: https://createbyinfluence.com/
kkellyppeters
kkellyppeters posted this 06 June 2023
Hello Pierre,
Thank you for bringing this issue to our attention. I apologize for the inconvenience caused. It seems that the problem is related to a menu link to a "separator" which is not supported in the current setup.
To correct this, you can try one of the following solutions:
Remove or replace the menu link to the "separator" with a supported menu item type.
If you need to keep the visual separation in the menu, you can use a different method such as adding custom CSS to create a visual separator.
Please let me know if you need any further assistance or if you have any other questions.
Tempest Hosting
Hello Pierre, Thank you for bringing this issue to our attention. I apologize for the inconvenience caused. It seems that the problem is related to a menu link to a "separator" which is not supported in the current setup. To correct this, you can try one of the following solutions: Remove or replace the menu link to the "separator" with a supported menu item type. If you need to keep the visual separation in the menu, you can use a different method such as adding custom CSS to create a visual separator. Please let me know if you need any further assistance or if you have any other questions. [Tempest Hosting][1] [1]: https://tempest.net/
michealjassona6614
michealjassona6614 posted this 11 June 2023
Regarding the unsupported "separator" menu link causing the problem, you have a few options to address it:
Remove the unsupported separator: If the "separator" menu item is causing issues and is not supported in your Joomla version or menu module, you can simply remove it from the menu structure. Edit the menu in the Joomla administration panel and delete the separator menu item.
Replace the separator with a supported alternative: Instead of using a "separator" menu item, you can utilize other supported elements to visually separate menu items. For example, you can use a blank menu item with a custom https://www.gilbertphotobooth.com CSS class to add styling that resembles a separator. Alternatively, you can consider using a different menu module or extension that provides built-in support for separators.
Regarding the unsupported "separator" menu link causing the problem, you have a few options to address it: Remove the unsupported separator: If the "separator" menu item is causing issues and is not supported in your Joomla version or menu module, you can simply remove it from the menu structure. Edit the menu in the Joomla administration panel and delete the separator menu item. Replace the separator with a supported alternative: Instead of using a "separator" menu item, you can utilize other supported elements to visually separate menu items. For example, you can use a blank menu item with a custom [https://www.gilbertphotobooth.com](https://www.gilbertphotobooth.com) CSS class to add styling that resembles a separator. Alternatively, you can consider using a different menu module or extension that provides built-in support for separators.
carl481
carl481 posted this 15 June 2023
Affordable Fence Installation Oklahoma City has served hundreds of families from El Reno and Yukon to Midwest City. affordable fence
Affordable Fence Installation Oklahoma City has served hundreds of families from El Reno and Yukon to Midwest City. [affordable fence][1] [1]: https://affordablefenceok.com/
Werbeagentur Schulz-Design posted this 28 June 2023
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator:
Wouldn't it be possible to fix at least this error?
That would be great.
Thank you so much for your help.
Thankful
Thorsten
Werbeagentur Schulz-Design e. K.
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator: 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params Wouldn't it be possible to fix at least this error? That would be great. Thank you so much for your help. Thankful Thorsten [Werbeagentur Schulz-Design e. K.][1] [1]: https://www.schulzdesign.info
carl481
carl481 posted this 16 July 2023
I also have the same case with you. Click here to view.
I also have the same case with you. [Click here][1] to view. [1]: http://www.tampa-deckbuilders.com/
carl481
If there's a bug, it can still be fixed though. www.berkeley-roofing.com/ www.longbeachbathroomremodeling.com/
If there's a bug, it can still be fixed though. [www.berkeley-roofing.com/][1] [www.longbeachbathroomremodeling.com/][2] [1]: https://www.berkeley-roofing.com/ [2]: https://www.berkeley-roofing.com/
jacobwaltz96
jacobwaltz96 posted this 19 July 2023
i cannot see the full stack trace. How cani enable it? install a deck
i cannot see the full stack trace. How cani enable it? [install a deck][1] [1]: https://deckbuildersalbanyny.com/installation-design/
carl481
carl481 posted this 22 July 2023
Spams are all over the internet now. We must protect our devices. long beach kitchen remodeling
Spams are all over the internet now. We must protect our devices. [long beach kitchen remodeling][1] [1]: http://www.longbeach-kitchenremodeling.com/
jacobwaltz96
jacobwaltz96 posted this 04 October 2023
When I enter the site while testing Joomla 4, I see the message "error 0 Cannot access protected property JoomlaCMSMenuMenuItem::$params".
http://www.brooklynsprayfoampros.com
When I enter the site while testing Joomla 4, I see the message "error 0 Cannot access protected property JoomlaCMSMenuMenuItem::$params". http://www.brooklynsprayfoampros.com
carmeloleonardo1
carmeloleonardo1 posted this 17 November 2023
This error occurs when a categories listing module with a certain set of parameters is displayed incompatible with Joomla 4 epoxy coatings
This error occurs when a categories listing module with a certain set of parameters is displayed incompatible with Joomla 4 [epoxy coatings][1] [1]: https://www.capitalregionepoxycoating.com/
dainady015
dainady015 posted this 12 March 2024
Your discovery regarding the inaccessible protected property within Joomla CMS is significant. The fact that it stems from an unsupported menu link to a "separator" underscores the importance of thorough testing and compatibility checks during development.
DAHLCORE offers comprehensive NYC fire protection services, ensuring the safety and compliance of commercial and residential properties. Their team of experts specializes in fire alarm installation, inspection, and maintenance, providing clients with peace of mind and adherence to local regulations. With a commitment to excellence and swift response times, DAHLCORE is the trusted partner for safeguarding properties against fire hazards in New York City.[https://dahlcore.com/fire-protection][NYC Fire Protection Services]
Your discovery regarding the inaccessible protected property within Joomla CMS is significant. The fact that it stems from an unsupported menu link to a "separator" underscores the importance of thorough testing and compatibility checks during development. DAHLCORE offers comprehensive NYC fire protection services, ensuring the safety and compliance of commercial and residential properties. Their team of experts specializes in fire alarm installation, inspection, and maintenance, providing clients with peace of mind and adherence to local regulations. With a commitment to excellence and swift response times, DAHLCORE is the trusted partner for safeguarding properties against fire hazards in New York City.[https://dahlcore.com/fire-protection][NYC Fire Protection Services] [1]: https://dahlcore.com/fire-protection
dainady015
Your discovery regarding the inaccessible protected property within Joomla CMS is significant. The fact that it stems from an unsupported menu link to a "separator" underscores the importance of thorough testing and compatibility checks during development. DAHLCORE offers comprehensive NYC fire protection services, ensuring the safety and compliance of commercial and residential properties. Their team of experts specializes in fire alarm installation, inspection, and maintenance, providing clients with peace of mind and adherence to local regulations. With a commitment to excellence and swift response times, DAHLCORE is the trusted partner for safeguarding properties against fire hazards in New York City. [NYC Fire Protection Services][1] [1]: https://dahlcore.com/fire-protection
ekaterinapawel
ekaterinapawel posted this 09 April 2024
http://www.peeplocal.com/spokane/commercial-service-repair/foundation-repair-spokane-wa
https://www.adpost.com/us/business_products_services/1020869/
https://www.n49.com/biz/5877424/foundation-repair-spokane-wa-wa-spokane-spokane/
http://www.askmap.net/location/6854593/united-states/foundation-repair-spokane-wa
https://www.pennysaverusa.com/services/contractors/foundations-masonry/foundation-repairs/foundation-repair-spokane-wa_i15493394
https://anyflip.com/homepage/uddqb
https://www.nextbizthing.com/construction-20-contractors/foundation-repair-spokane-wa
https://rentry.co/hy2qcpeu
https://foundationrepairspokane.weebly.com/
https://securecc.smartinsight.co/profile/14055377/FoundationRepairSpokaneWA
http://www.travelful.net/location/5401183/united-states-of-america/foundation-repair-spokane-wa
https://www.merchantcircle.com/foundation-repair-spokane-wa-medical-lake-wa
https://www.localbusinesslisting.org/foundation-repair-spokane-wa
https://us.enrollbusiness.com/BusinessProfile/6607371/Foundation-Repair-Spokane-WA-Spokane-WA-99210
https://www.bizoforce.com/business-directory/foundation-repair-spokane-wa/
http://spokane.businesslistus.com/business/5406844.htm
https://www.fyple.com/company/foundation-repair-spokane-wa-o8iq0yy/
https://www.cityfos.com/company/Foundation-Repair-Spokane-in-spokane-WA-23004222.htm
https://www.locanto.com/spokane/ID_6777010177/Foundation-Repair-Spokane-WA.html&myads
https://www.find-us-here.com/businesses/Foundation-Repair-Spokane-WA-Spokane-Washington-USA/34020809
http://www.peeplocal.com/spokane/commercial-service-repair/foundation-repair-spokane-wa https://www.adpost.com/us/business_products_services/1020869/ https://www.n49.com/biz/5877424/foundation-repair-spokane-wa-wa-spokane-spokane/ http://www.askmap.net/location/6854593/united-states/foundation-repair-spokane-wa https://www.pennysaverusa.com/services/contractors/foundations-masonry/foundation-repairs/foundation-repair-spokane-wa_i15493394 https://anyflip.com/homepage/uddqb https://www.nextbizthing.com/construction-20-contractors/foundation-repair-spokane-wa https://rentry.co/hy2qcpeu https://foundationrepairspokane.weebly.com/ https://securecc.smartinsight.co/profile/14055377/FoundationRepairSpokaneWA http://www.travelful.net/location/5401183/united-states-of-america/foundation-repair-spokane-wa https://www.merchantcircle.com/foundation-repair-spokane-wa-medical-lake-wa https://www.localbusinesslisting.org/foundation-repair-spokane-wa https://us.enrollbusiness.com/BusinessProfile/6607371/Foundation-Repair-Spokane-WA-Spokane-WA-99210 https://www.bizoforce.com/business-directory/foundation-repair-spokane-wa/ http://spokane.businesslistus.com/business/5406844.htm https://www.fyple.com/company/foundation-repair-spokane-wa-o8iq0yy/ https://www.cityfos.com/company/Foundation-Repair-Spokane-in-spokane-WA-23004222.htm https://www.locanto.com/spokane/ID_6777010177/Foundation-Repair-Spokane-WA.html&myads https://www.find-us-here.com/businesses/Foundation-Repair-Spokane-WA-Spokane-Washington-USA/34020809
John Devarra
John Devarra posted this 26 June 2024
Thank you for your post! very informative. Please visit Nusantara88 link alternatif main slot di Indonesia
Thank you for your post! very informative. Please visit [Nusantara88][1] link alternatif main slot di Indonesia [1]: https://www.nusa239.com
