posted this
26 September 2022
Hello Kristina,
Thank you for the detailed description of issues and sorry that you encountered them.
I'm not able to import the template (blank_themler_joomla4_theme.zip) provided on your website in Themler desktop.
And also two following questions.
Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update.
Here are possible ways to make creating themes easier (if they are made to re-create old themes):
- organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling
There is a separate Themler theme for Joomla 4 at https://themler.io/Download. Currently it is in Beta. Please update it to the latest Themler version as it includes some fixes.
Can I safely uninstall Themler and then install it with my licence?
Yes, sure. Only please make sure to log in with your email and password to Themler after installing.
Is it possible to install two Themlers in parallel (Joomla3-Version and newest) or on another computer?
You may use as many websites as needed with different CMS versions and even different CMS's on a hosted website or on some localhost (like xampp). You may use and edit Themler themes in each of them.
On the other hand, Themler desktop includes Joomla 3 installation, so you may use it for Joomla 3 and also use Joomla 4 with Themler on a website on some live hosting or localhost. Only there can be issues in running multiple themes simultaneously. In case you will get a warning in a browser and will need to close Themler and clear cache.
Hello Kristina,
