Pagination problem with Themler 559 and Joomla 4.2.3
gaatec
gaatec posted this 15 October 2022
There is a problem with Themler Pagination in Joomla 4.2.3 (Themler 559)
If I set a menuitem to "Category List" it should list all articles in a category, and does so until pagination is needed.
If I set a limit of 10 articles to list and then show pagination, then I get a problem as soon as the pagination is supposed to kick in.
Example:
I have set a menu item to "Category List", and have under article options set "# Articles to List" to 10.
  • As long as I have up to 10 articles in that category everything works fine.
  • However, as soon as I add article number 11 to that category (and pagination should be displayed) I now get the following error in the frontend:
0 - Call to undefined function renderTemplateFromIncludes()
1) This is definitely a problem with Themler, as the problem and error disappear if I switch the template to Cassiopeia.
2) If I e.g change the # of articles to 15, then the problem occur as soon as I add article # 16 to the category
There is a problem with Themler Pagination in Joomla 4.2.3 (Themler 559) If I set a menuitem to "Category List" it should list all articles in a category, and does so until pagination is needed. If I set a limit of 10 articles to list and then show pagination, then I get a problem as soon as the pagination is supposed to kick in. Example: I have set a menu item to "Category List", and have under article options set "# Articles to List" to 10. - As long as I have up to 10 articles in that category everything works fine. - However, as soon as I add article number 11 to that category (and pagination should be displayed) I now get the following error in the frontend: **0 - Call to undefined function renderTemplateFromIncludes()** 1) This is definitely a problem with Themler, as the problem and error disappear if I switch the template to Cassiopeia. 2) If I e.g change the # of articles to 15, then the problem occur as soon as I add article # 16 to the category
19 Comments
abohasan2
Is Solution
abohasan2 posted this 21 October 2022
The functions.php file is somehow not being included in the pagination layout file, I solved this by adding the following line to TEMPLATE/html/layouts/joomla/pagination/list.php:
require_once $templateDir . DIRECTORY_SEPARATOR . 'functions.php';
Make sure to write it after '$templateDir' assignment. i.e. after this line: $templateDir = JPATH_THEMES . '/' . $templateName;
The functions.php file is somehow not being included in the pagination layout file, I solved this by adding the following line to TEMPLATE/html/layouts/joomla/pagination/list.php: **require_once $templateDir . DIRECTORY_SEPARATOR . 'functions.php';** Make sure to write it after '$templateDir' assignment. i.e. after this line: **$templateDir = JPATH_THEMES . '/' . $templateName;**
gaatec
gaatec posted this 21 October 2022
That sounds good.
Is that a permanent fix, or is that going to be overwritten next time Themler issue an update, e.g. from 559 to 560 ?
Goran
> The functions.php file is somehow not being included in the pagination layout file, I solved this by adding the following line to TEMPLATE/html/layouts/joomla/pagination/list.php: > > **require_once $templateDir . DIRECTORY_SEPARATOR . 'functions.php';** > > Make sure to write it after '$templateDir' assignment. i.e. after this line: **$templateDir = JPATH_THEMES . '/' . $templateName;** That sounds good. Is that a permanent fix, or is that going to be overwritten next time Themler issue an update, e.g. from 559 to 560 ? Regards Goran
abohasan2
If they fix it in the next update it won't happen again, however, if they don't I believe it will be overwritten in the update and you'll get that error again.
gaatec
gaatec posted this 01 January 2023
Sorry for the late reply. I was holding off to see if your fix would be included in the next Themler update.
Thanks a lot for this fix, it does indeed do the trick, and I hope that Themler have the sense to ensure that this fix is included in the next version.
This problem really would affect a lot of people. As an example, I have just on a couple of sites setup Joomla with the fabulous DJ-Catalog2 component, and here it breaks the 'User Products view' where a frontend user can view and edit catalog products.
Needless to say, it is all down to the same pagination problem, and with your fix, everything work as it should.
Thanks a lot for this. Highly appreciated.
Goran
> If they fix it in the next update it won't happen again, however, if they don't I believe it will be overwritten in the update and you'll get that error again. Sorry for the late reply. I was holding off to see if your fix would be included in the next Themler update. Thanks a lot for this fix, it does indeed do the trick, and I hope that Themler have the sense to ensure that this fix is included in the next version. This problem really would affect a lot of people. As an example, I have just on a couple of sites setup Joomla with the fabulous DJ-Catalog2 component, and here it breaks the 'User Products view' where a frontend user can view and edit catalog products. Needless to say, it is all down to the same pagination problem, and with your fix, everything work as it should. Thanks a lot for this. Highly appreciated. Regards Goran
marcin8
marcin8 posted this 01 March 2023
This fix doesn't work for me (DJ-Catalog2).
The page layout is fixed but the page pagination buttons are not visible.
This fix doesn't work for me (DJ-Catalog2). The page layout is fixed but the page pagination buttons are not visible. ?
tapeterrible
tapeterrible posted this 31 July 2023
This fix doesn't work for me (DJ-Catalog2). geometry dash
It seems that there is a problem with the Themler Pagination feature in Joomla 4.2.3 (Themler 559). When setting a menu item to "Category List" and specifying a limit for the number of articles to list, an error occurs when pagination is supposed to be displayed.
The error message states "Call to undefined function renderTemplateFromIncludes()". This error is specific to Themler and does not occur when using the Cassiopeia template.
To further investigate and resolve this issue, you can try the following steps:
Check for any updates or patches for Themler. Sometimes, software updates can fix known issues and bugs.
Contact the Themler support team or forum for assistance. They may be able to provide specific guidance or a solution for this problem.
Consider using an alternative template or pagination solution if the issue persists. There are many other Joomla templates available that may not have this problem.
If possible, try replicating the issue on a different Joomla installation or environment. This can help determine if the problem is specific to your setup or a more general issue.
Remember to always backup your website before making any changes or updates to avoid any potential data loss.
> This fix doesn't work for me (DJ-Catalog2). [geometry dash][1] > The page layout is fixed but the page pagination buttons are not visible. > ? It seems that there is a problem with the Themler Pagination feature in Joomla 4.2.3 (Themler 559). When setting a menu item to "Category List" and specifying a limit for the number of articles to list, an error occurs when pagination is supposed to be displayed. The error message states "Call to undefined function renderTemplateFromIncludes()". This error is specific to Themler and does not occur when using the Cassiopeia template. To further investigate and resolve this issue, you can try the following steps: Check for any updates or patches for Themler. Sometimes, software updates can fix known issues and bugs. Contact the Themler support team or forum for assistance. They may be able to provide specific guidance or a solution for this problem. Consider using an alternative template or pagination solution if the issue persists. There are many other Joomla templates available that may not have this problem. If possible, try replicating the issue on a different Joomla installation or environment. This can help determine if the problem is specific to your setup or a more general issue. Remember to always backup your website before making any changes or updates to avoid any potential data loss. [1]: https://geometrydash-free.com
appliancerepaircalg01
appliancerepaircalg01 posted this 04 August 2023
Thank you for sharing this blog. Keep posting. https://www.waketreeremoval.com
Thank you for sharing this blog. Keep posting. [https://www.waketreeremoval.com][1] [1]: https:///www.waketreeremoval.com
davidmarco19x
davidmarco19x posted this 08 August 2023
The functions.php file is somehow not being included in the pagination layout file, I solved this by adding the following line to TEMPLATE/html/layouts/joomla/pagination/list.php: drift hunters
Adding a require_once statement for the functions.php file in the pagination layout template is a good way to make sure it gets included.
> The functions.php file is somehow not being included in the pagination layout file, I solved this by adding the following line to TEMPLATE/html/layouts/joomla/pagination/list.php: [drift hunters][1] > > **require_once $templateDir . DIRECTORY_SEPARATOR . 'functions.php';** > > Make sure to write it after '$templateDir' assignment. i.e. after this line: **$templateDir = JPATH_THEMES . '/' . $templateName;** Adding a require_once statement for the functions.php file in the pagination layout template is a good way to make sure it gets included. [1]: https://drift-hunters.io
saxophonebritish
saxophonebritish posted this 15 August 2023
I tried this code and its work.
moto x3m
I tried this code and its work. [moto x3m][1] [1]: https://moto-x3m.io/
gaatec
gaatec posted this 15 August 2023
HELLO MODERATORS !!!!!
Please wake up, I have reported these last 4 comments to my post.
The only thing these 4 postings do is to reply and add a URL (Maybe malicious) into the commentfield.
This is at least SPAM, and the link might lead to MALICIOUS content. Moderators should be quicker to respond and remove and ban the offenders.
HELLO MODERATORS !!!!! Please wake up, I have reported these last 4 comments to my post. The only thing these 4 postings do is to reply and add a URL (Maybe malicious) into the commentfield. This is at least SPAM, and the link might lead to MALICIOUS content. Moderators should be quicker to respond and remove and ban the offenders.
doteourselves
doteourselves posted this 4 weeks ago
Creating a Plugin or a Module for Joomla 4, namespaces conventions, prepared statements trap the cat, using the new web asset classes and many more.
Creating a Plugin or a Module for Joomla 4, namespaces conventions, prepared statements [trap the cat][1], using the new web asset classes and many more. [1]: https://trap-thecat.com
thomas89anderson
thomas89anderson posted this 4 weeks ago
Absolutely fine thanks for this info....
victorortegadgg
victorortegadgg posted this 3 weeks ago
We appreciate you sharing this blog. Keep publishing eggy car
We appreciate you sharing this blog. Keep publishing [eggy car][1] [1]: https://eggycar.co
wkaysee23
wkaysee23 posted this 3 weeks ago
Great detailed information on your tips, appreciated! I'd also like to recommend Handyman services for their great service!
Great detailed information on your tips, appreciated! I'd also like to recommend [Handyman services][1] for their great service! [1]: https://www.handymancedarcity.com/
StephenStoelinga14
StephenStoelinga14 posted this 3 weeks ago
Based on the search results, it seems that there is a pagination problem with Themler 559 and Joomla 4.2.3. The functions.php file is not being included in the pagination layout file, which causes the issue. Here are some steps you can take to try and resolve the issue:
  1. Add the following line to TEMPLATE/html/pagination.php file:
    require_once JPATH_THEMES . '/' . $this->template . '/functions.php';
  2. Save the file and refresh the page to see if the issue has been resolved.
  3. If the issue persists, try updating your Joomla version to the latest version or try using a different pagination extension.
  4. If none of these solutions work, you may need to reach out to Themler support for further assistance. They may be able to provide additional troubleshooting steps or help you identify the root cause of the issue.
It is important to note that pagination issues can be caused by a variety of factors, including conflicts with other extensions or outdated software versions. Therefore, it may be helpful to review the Joomla documentation and other resources to ensure that you are using the system correctly and that it is the right fit for your website needs.
MyLabCorp.com
Based on the search results, it seems that there is a pagination problem with Themler 559 and Joomla 4.2.3. The functions.php file is not being included in the pagination layout file, which causes the issue. Here are some steps you can take to try and resolve the issue: 1. Add the following line to TEMPLATE/html/pagination.php file: require_once JPATH_THEMES . '/' . $this->template . '/functions.php'; 2. Save the file and refresh the page to see if the issue has been resolved. 3. If the issue persists, try updating your Joomla version to the latest version or try using a different pagination extension. 4. If none of these solutions work, you may need to reach out to Themler support for further assistance. They may be able to provide additional troubleshooting steps or help you identify the root cause of the issue. It is important to note that pagination issues can be caused by a variety of factors, including conflicts with other extensions or outdated software versions. Therefore, it may be helpful to review the Joomla documentation and other resources to ensure that you are using the system correctly and that it is the right fit for your website needs. [MyLabCorp.com][1] [1]: https://www.mylabcorp.us/
gaatec
gaatec posted this 3 weeks ago
MODERATORS, there is now a further 4 'comments' only placed there to include a potential malicious url.
I have reported these, through the 'report abuse' link, but since the previous spam comments are still there despite me calling these out 4 weeks ago, I take it that there is noone from Themler reading the forum, or responding/reacting to 'report abose' replies from genuine members.
Honestly, very disappointing indeed.
MODERATORS, there is now a further 4 'comments' only placed there to include a potential malicious url. I have reported these, through the 'report abuse' link, but since the previous spam comments are still there despite me calling these out 4 weeks ago, I take it that there is noone from Themler reading the forum, or responding/reacting to 'report abose' replies from genuine members. Honestly, very disappointing indeed.
gemmalyly
gemmalyly posted this 2 weeks ago
Make sure you are using a compatible version of connections unlimited Themler for your Joomla installation. Sometimes, issues arise when using outdated or incompatible extensions or themes.
Make sure you are using a compatible version of [connections unlimited][1] Themler for your Joomla installation. Sometimes, issues arise when using outdated or incompatible extensions or themes. [1]: https://connectionsunlimited.io/
gaatec
gaatec posted this 2 weeks ago
MODERATORS, here is another scammer posting apotential maittious url
> Make sure you are using a compatible version of [connections unlimited][1] Themler for your Joomla installation. Sometimes, issues arise when using outdated or incompatible extensions or themes. > > > [1]: https://connectionsunlimited.io/ MODERATORS, here is another scammer posting apotential maittious url
focaw68834
focaw68834 posted this 2 weeks ago
I had the same pagination problem in Joomla ,thanks for solving my problem too
catalogosdigitales
I had the same pagination problem in Joomla ,thanks for solving my problem too ----------------------- [catalogosdigitales][1] [1]: https://www.catalogosdigitalesmx.com/
