Good day,
I have a translation problem with WPML & Themler. Everything is working fine, only the translation of the landing page (HOME) is causing problems.
I have inserted texts on the landing page (quite normally as text), which unfortunately are not translated. Alternatively, I tried to use the texts as SHORTCODE with the plug-in INSERT PAGES. So I created a PAGE with the text content and then displayed it on the landing page ... worked well, but unfortunately it does not access the translated texts when changing languages, but stays with the basic language.
A third possibility was via strings, which WPML recognises, but I can't find a string in the theme that shows the text for the landing page. WPML support said maybe Themler would throw out the landing page text content as a "Costum Post Type", but I haven't found anything there either.
I need help urgently! Thanks
PS: The developer of WPML sent us the following link -> https://wpml.org/documentation/support/go-global-program/ (for the Themler developers) and asks whether Themler was developed according to the i18n standard.
Good day, I have a translation problem with WPML & Themler. Everything is working fine, only the translation of the landing page (HOME) is causing problems. I have inserted texts on the landing page (quite normally as text), which unfortunately are not translated. Alternatively, I tried to use the texts as SHORTCODE with the plug-in INSERT PAGES. So I created a PAGE with the text content and then displayed it on the landing page ... worked well, but unfortunately it does not access the translated texts when changing languages, but stays with the basic language. A third possibility was via strings, which WPML recognises, but I can't find a string in the theme that shows the text for the landing page. WPML support said maybe Themler would throw out the landing page text content as a "Costum Post Type", but I haven't found anything there either. I need help urgently! Thanks PS: The developer of WPML sent us the following link -> https://wpml.org/documentation/support/go-global-program/ (for the Themler developers) and asks whether Themler was developed according to the i18n standard.Last edited 25 October 2022 by info2569
