Themler Joomla 3 have to wait after changing stuff please help
web-team
web-team posted this 16 November 2022
Hello we have a Joomla 3 site running Themler templates. Everything was working fine but now the editing is really slow.
For example I want to copy an element from column A to column B. After pasting it the mouse cursor changes to loading state and I can't do nothing for like 30 seconds. After that next element same thing happens again.
It's not possible to work with this situation!
This is really annoying. How to fix it?
Please help I don't want to spend so much more time on this project pleeaasaee
Hello we have a Joomla 3 site running Themler templates. Everything was working fine but now the editing is really slow. For example I want to copy an element from column A to column B. After pasting it the mouse cursor changes to loading state and I can't do nothing for like 30 seconds. After that next element same thing happens again. It's not possible to work with this situation! This is really annoying. How to fix it? Please help I don't want to spend so much more time on this project pleeaasaee
Support Team posted this 17 November 2022
This shouldn't be that long. Looks like there is either browser issue, or server or machine issue.
  1. Could you please try switching between browsers - Chrome/Firefox - and check if there is any difference?
  2. If it doesn't help, please check if there is any difference if you disable VPN/proxy/antivirus or any third-party applications that may slow down internet connection?
  3. If there is still no difference, could you please try from another computer (preferrably also in another network) and see if it is slow as well?
Hello, This shouldn't be that long. Looks like there is either browser issue, or server or machine issue. 1. Could you please try switching between browsers - Chrome/Firefox - and check if there is any difference? 2. If it doesn't help, please check if there is any difference if you disable VPN/proxy/antivirus or any third-party applications that may slow down internet connection? 3. If there is still no difference, could you please try from another computer (preferrably also in another network) and see if it is slow as well? Sincerely, Nettie
michealjassona6614
michealjassona6614 posted this 11 June 2023
I apologize for the frustration you're experiencing with the slow editing in Themler on your Joomla 3 site. Here are a few steps you can take to try and improve the performance:
Clear cache: Clear the cache in Themler to ensure that you're not working with outdated or cached data. In the Themler menu, go to "File" -> "Clear Cache" to clear the cache.
Optimize your website: Ensure that your Joomla site is optimized for performance. This includes optimizing images, enabling caching, and minimizing unnecessary scripts and plugins. You can use Joomla's built-in cache and compression settings to improve performance.
Check system requirements: Verify that your server meets the recommended system requirements for Themler and Joomla. Ensure that you have sufficient server resources, including CPU, memory, and disk space.
Update Themler: Make sure that you are using the latest version of Themler. Check for any available updates and install them if necessary. Updated versions often include bug fixes and performance improvements.
Disable unnecessary extensions: Temporarily disable any unnecessary extensions or plugins in Joomla. Sometimes, conflicts between extensions can slow down the editing process. Disable them one by one to identify if any specific extension is causing the slowdown.
Test on a different environment: Try working with Themler on a different computer or network environment to see if the issue persists. This can help determine if the problem is specific to your current setup.
Contact Themler support: If none of the above steps solve the issue, it's best to reach out to the 360 photo booth Orlando FL Themler support team for further assistance. They can provide specific guidance and investigate if there are any known issues or solutions related to the slow editing problem you're experiencing.
By following these steps and seeking support from the Themler team, you should be able to address the performance issue and improve the editing experience on your Joomla 3 site.
I apologize for the frustration you're experiencing with the slow editing in Themler on your Joomla 3 site. Here are a few steps you can take to try and improve the performance: Clear cache: Clear the cache in Themler to ensure that you're not working with outdated or cached data. In the Themler menu, go to "File" -> "Clear Cache" to clear the cache. Optimize your website: Ensure that your Joomla site is optimized for performance. This includes optimizing images, enabling caching, and minimizing unnecessary scripts and plugins. You can use Joomla's built-in cache and compression settings to improve performance. Check system requirements: Verify that your server meets the recommended system requirements for Themler and Joomla. Ensure that you have sufficient server resources, including CPU, memory, and disk space. Update Themler: Make sure that you are using the latest version of Themler. Check for any available updates and install them if necessary. Updated versions often include bug fixes and performance improvements. Disable unnecessary extensions: Temporarily disable any unnecessary extensions or plugins in Joomla. Sometimes, conflicts between extensions can slow down the editing process. Disable them one by one to identify if any specific extension is causing the slowdown. Test on a different environment: Try working with Themler on a different computer or network environment to see if the issue persists. This can help determine if the problem is specific to your current setup. Contact Themler support: If none of the above steps solve the issue, it's best to reach out to the [360 photo booth Orlando FL](https://www.orlando360photoboothrental.com) Themler support team for further assistance. They can provide specific guidance and investigate if there are any known issues or solutions related to the slow editing problem you're experiencing. By following these steps and seeking support from the Themler team, you should be able to address the performance issue and improve the editing experience on your Joomla 3 site.
appliancerepaircalg01
appliancerepaircalg01 posted this 04 August 2023
I am Experiencing this kind of issue. The editing is really slow. Porch Screen Installation North Port, FL
I am Experiencing this kind of issue. The editing is really slow. [Porch Screen Installation North Port, FL][1] [1]: https://www.northport-screening.com/
