0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
Pierre665
Pierre665 posted this 16 November 2022
This bug is still not fixed : 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
It kicks in for me when a menu item is attached to an "alias" or "separator". When are you going to fix this?
Some messages in the forum on this subject date from May. Thank you in advance for your answer.
Pierre
Hello, This bug is still not fixed : 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params It kicks in for me when a menu item is attached to an "alias" or "separator". When are you going to fix this? Some messages in the forum on this subject date from May. Thank you in advance for your answer. Regards, Pierre
Denis L.
Denis L. posted this 10 April 2023
Hey Themler Devs, any update on a fix for this v.559 template?! It's all related with the Joomla menu module. Please fix this! We are paying customers and we really don't have for our money's worth with that kind of slow service!
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 11 April 2023
We also have the same problem.
We cannot continue our work, which causes us enormous damage.
When will the bug be fixed?
We also have the same problem. We cannot continue our work, which causes us enormous damage. When will the bug be fixed?
tamas
tamas posted this 07 June 2023
0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params We also have the same problem. We cannot continue our work, which causes us enormous damage. When will the bug be fixed? ?????????????????????????????? ????????????????????????????????????? ,????????????????????????????????????????,,, ???????????????????????????????????????????????????
tamas
tamas posted this 08 June 2023
tamas
tamas posted this 13 June 2023
tamas
You are an incorrect company
Werbeagentur Schulz-Design posted this 28 June 2023
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator:
Wouldn't it be possible to fix at least this error?
That would be great.
Thank you so much for your help.
Thankful
Thorsten
Werbeagentur Schulz-Design e. K.
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator: 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params Wouldn't it be possible to fix at least this error? That would be great. Thank you so much for your help. Thankful Thorsten [Werbeagentur Schulz-Design e. K.][1] [1]: https://www.schulzdesign.info
