Joomla 4 new template error
paulwiertsema
paulwiertsema posted this 21 November 2022
I created a fresh Joomla 4 install and uploaded the Themler file for Joomla 4. When I click edit on the default style, the Themler edit window comes up. I can edit and save the template.
However, when I try to create a new template, or try to import one, I am gettin a error: "Upload failed: Invalid controller, name = 'install', format =''
What is going wrong here?
Hi, I created a fresh Joomla 4 install and uploaded the Themler file for Joomla 4. When I click edit on the default style, the Themler edit window comes up. I can edit and save the template. However, when I try to create a new template, or try to import one, I am gettin a error: "Upload failed: Invalid controller, name = 'install', format ='' What is going wrong here?
6 Comments
Support Team posted this 21 November 2022
Please try the theme attached. If the issue is still present, please specify your exact Joomla version.
Hello, Please try the theme attached. If the issue is still present, please specify your exact Joomla version. Sincerely, Nettie
paulwiertsema
No change, I'm afraid.
My Joomla version is : Joomla! 4.2.5 Stable [ Uaminifu ] 8-November-2022 15:00 GMT
No change, I'm afraid. My Joomla version is : Joomla! 4.2.5 Stable [ Uaminifu ] 8-November-2022 15:00 GMT
forpractice374
forpractice374 posted this 25 October 2025
The 24V J618 4×4 ATV is a spacious kids’ ride-on quad designed for two riders. Powered by a reliable 24V battery with 4-wheel drive, Carzone Toys 24V J618 4×4 ATV delivers safe, exciting playtime with LED lights, Bluetooth music, and EVA soft wheels that handle multiple surfaces with ease.
The 24V J618 4×4 ATV is a spacious kids’ ride-on quad designed for two riders. Powered by a reliable 24V battery with 4-wheel drive, [Carzone Toys 24V J618 4×4 ATV][1] delivers safe, exciting playtime with LED lights, Bluetooth music, and EVA soft wheels that handle multiple surfaces with ease. [1]: https://carzonetoys.com/our-collection/atv-4-wheeler/24v-j618-4x4-kids-electric-atv/
jamoya2414
jamoya2414 posted this 25 December 2025
G’day, ich wollte schon länger Geld sparen, um mir endlich ein neues Tablet zu gönnen, doch immer wieder kamen unerwartete Ausgaben dazwischen und mein Sparplan scheiterte. Dann entdeckte ich play jonny mit speziellen Boni für Spieler aus Deutschland. Ich probierte das Slot-Spiel „Golden Pyramid“ aus und nach einigen Fehlschlägen wagte ich einen höheren Einsatz – und gewann überraschend eine ordentliche Summe. Jetzt kann ich mir das Tablet leisten und habe gleichzeitig eine spannende Möglichkeit gefunden, mich nach Feierabend zu entspannen.
G’day, ich wollte schon länger Geld sparen, um mir endlich ein neues Tablet zu gönnen, doch immer wieder kamen unerwartete Ausgaben dazwischen und mein Sparplan scheiterte. Dann entdeckte ich [play jonny][1] mit speziellen Boni für Spieler aus Deutschland. Ich probierte das Slot-Spiel „Golden Pyramid“ aus und nach einigen Fehlschlägen wagte ich einen höheren Einsatz – und gewann überraschend eine ordentliche Summe. Jetzt kann ich mir das Tablet leisten und habe gleichzeitig eine spannende Möglichkeit gefunden, mich nach Feierabend zu entspannen. [1]: https://play-jonny-casino.com/de-de/
washerrepairyakima
washerrepairyakima posted this 25 December 2025
This error usually happens due to Joomla permissions or installer restrictions, not Themler itself. When creating or importing a new template, Joomla uses the install controller, and if file permissions, PHP upload limits, or disabled installer plugins are present, it throws the “Invalid controller” error.
Check that:
The Installer – Package Installer plugin is enabled
Your /tmp and /administrator/components/com_installer folders are writable
upload_max_filesize and post_max_size in PHP are high enough
I’ve run into similar issues when working on Joomla sites for appliance repair projects where hosting security rules blocked template installs. Once permissions and installer plugins were fixed, Themler worked as expected.
This error usually happens due to Joomla permissions or installer restrictions, not Themler itself. When creating or importing a new template, Joomla uses the install controller, and if file permissions, PHP upload limits, or disabled installer plugins are present, it throws the “Invalid controller” error. Check that: The Installer – Package Installer plugin is enabled Your /tmp and /administrator/components/com_installer folders are writable upload_max_filesize and post_max_size in PHP are high enough I’ve run into similar issues when working on Joomla sites for [appliance repair][1] projects where hosting security rules blocked template installs. Once permissions and installer plugins were fixed, Themler worked as expected. [1]: https://washerrepairyakima.com/
janiecarmody
janiecarmody posted this 3 weeks ago
Running into setup errors can really slow things down, especially when you’re trying to move forward without extra hassle. From a user point of view, it helps when the issue is broken down step by step and fixed without confusion. I’ve had similar moments where clear problem handling mattered just as much as the solution itself, like when dealing with electrical contractors bergen county nj for unexpected issues. Having someone who stays patient and explains what’s happening makes the whole experience smoother and less stressful.
Running into setup errors can really slow things down, especially when you’re trying to move forward without extra hassle. From a user point of view, it helps when the issue is broken down step by step and fixed without confusion. I’ve had similar moments where clear problem handling mattered just as much as the solution itself, like when dealing with [electrical contractors bergen county nj][1] for unexpected issues. Having someone who stays patient and explains what’s happening makes the whole experience smoother and less stressful. [1]: https://enaranj.com/
