0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params
armando.gobbi2
armando.gobbi2 posted this 22 November 2022
Hi, when i put an image in a menu's voice i get this error.
If i deactivate that menu's voice the website starts working again.
The problem is with php 8 and with php 7.4
Joomla 4.2.5
Themler v 559
Hi, when i put an image in a menu's voice i get this error. 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params If i deactivate that menu's voice the website starts working again. The problem is with php 8 and with php 7.4 Joomla 4.2.5 Themler v 559
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 28 June 2023
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator:
Wouldn't it be possible to fix at least this error?
That would be great.
Thank you so much for your help.
Thankful
Thorsten
Werbeagentur Schulz-Design e. K.
The J4 beta for Themler is already quite good. Unfortunately, the following error still exists with the menus if you want to insert a submenu item, a menu alias, or a separator: 0 - Cannot access protected property Joomla\CMS\Menu\MenuItem::$params Wouldn't it be possible to fix at least this error? That would be great. Thank you so much for your help. Thankful Thorsten [Werbeagentur Schulz-Design e. K.][1] [1]: https://www.schulzdesign.info
appliancerepaircalg01
appliancerepaircalg01 posted this 04 August 2023
Thank you for sharing this blog. Keep posting. Pool Rescreening Kissimmee, FL
Thank you for sharing this blog. Keep posting. [Pool Rescreening Kissimmee, FL][1] [1]: https://www.kissimmeescreening.com/
trieudinhqt1057
trieudinhqt1057 posted this 04 August 2023
check for any direct access to the "params" property in your code and replace it with the appropriate getter method provided by Joomla. Additionally, ensure that your extensions, including the menu module, are updated to versions compatible with PHP 8 and PHP 7.4. If the problem persists, consult Joomla's support or the Themler development team for assistance. You can go on official site.
check for any direct access to the "params" property in your code and replace it with the appropriate getter method provided by Joomla. Additionally, ensure that your extensions, including the menu module, are updated to versions compatible with PHP 8 and PHP 7.4. If the problem persists, consult Joomla's support or the Themler development team for assistance. You can go on [official site][1]. [1]: https://www.livetheorangelife.net/
walker.ethan1989
walker.ethan1989 posted this 28 October 2025
Thanks for sharing this issue — I ran into something similar when updating a Joomla site recently. It’s amazing how certain extensions can break after version changes, kind of like how choosing the Best horse supplements can make all the difference in performance and stability over time.
Thanks for sharing this issue — I ran into something similar when updating a Joomla site recently. It’s amazing how certain extensions can break after version changes, kind of like how choosing the [Best horse supplements][1] can make all the difference in performance and stability over time. [1]: https://corebalanceus.com/
jermainepurple
jermainepurple posted this 27 March 2026
Horses are herbivorous animals, meaning they feed mainly on grass, hay, and grains and Can Horses Eat Oranges?. They have powerful legs and are known for their speed, endurance, and agility.
Horses are herbivorous animals, meaning they feed mainly on grass, hay, and grains and [Can Horses Eat Oranges?][1]. They have powerful legs and are known for their speed, endurance, and agility. [1]: https://visakhaspca.org/horses/can-horses-eat-oranges/
