update a joomla 3 template to joomla 4
p.costa
p.costa posted this 2 weeks ago
Hello, do you have a procedure to update a joomla 3 template to joomla 4, because the current template is not recognized.
Sincerely Pascal
Hello, do you have a procedure to update a joomla 3 template to joomla 4, because the current template is not recognized. Sincerely Pascal
Hello Pascal,
Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update.
Here are possible ways to make creating themes easier (if they are made to re-create old themes):
- organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip
- there are Export / Import options available in the Posts tab to transfer Posts layout and styling
There is a separate Themler theme for Joomla 4 at https://themler.io/Download. Currently it is in Beta. Please update it to the latest Themler version as it includes some fixes. Or please use the updated theme attached to this post.
Hello Pascal, Old themes are all for Joomla 3 and cannot be imported or converted for Joomla 4 automatically. The themes are completely different as if they were for different CMS's. That is why for Joomla 4 a separate theme should be downloaded and not just Joomla 3 theme with Themler update. Here are possible ways to make creating themes easier (if they are made to re-create old themes): - organize controls in Sections and use Export as Zip option in the Section tab, then import them in a new theme using Import as Zip - there are Export / Import options available in the Posts tab to transfer Posts layout and styling There is a separate Themler theme for Joomla 4 at https://themler.io/Download. Currently it is in Beta. Please update it to the latest Themler version as it includes some fixes. Or please use the updated theme attached to this post. Sincerely, Nettie
