footer and the page size
adrian.p
adrian.p posted this 28 November 2022
Good day
I have problems with the footer and the page size in height. (in Joomla 4)
The page does not get bigger when content is placed and therefore the footer overhangs the content.
Could someone please help me here?
Adrian.p
Good day I have problems with the footer and the page size in height. (in Joomla 4) The page does not get bigger when content is placed and therefore the footer overhangs the content. Could someone please help me here? Adrian.p
32 Comments
jesse628wallick
jesse628wallick posted this 14 March 2024
Good day, MaximTimeClock@Adrian!
The issue you’re facing with the footer overlapping the content in Joomla 4 is a common one, often related to the CSS styling of the footer. Here are some steps you can take to resolve this:
Check the Footer Position: Ensure that the footer is not set to a fixed position, as this can take it out of the normal document flow and cause overlapping.
Adjust the Margin or Padding: You may need to add sufficient margin or padding to the bottom of your content area to ensure there is space for the footer.
Use a Sticky Footer: If you want the footer to always be at the bottom but not overlap the content when the page content is long, you can use a sticky footer technique.
Clear Floats: If you’re using floats in your layout, make sure to clear them before the footer so that it doesn’t overlap the content.
Here’s an example of CSS that can help prevent the footer from overlapping:
#footer {
    position: relative; /* or absolute */
    width: 100%;
    clear: both;
And ensure that your content has enough padding at the bottom:
#content {
    padding-bottom: [height of your footer];
Replace [height of your footer] with the actual height of your footer.
If these suggestions don’t resolve the issue, it might be necessary to look at the specific code involved. You can also seek further assistance on forums like Stack Overflow or the Joomla community forum where you can share code snippets and get more tailored advice.
Good day, [MaximTimeClock][1]@Adrian! The issue you’re facing with the footer overlapping the content in Joomla 4 is a common one, often related to the CSS styling of the footer. Here are some steps you can take to resolve this: Check the Footer Position: Ensure that the footer is not set to a fixed position, as this can take it out of the normal document flow and cause overlapping. Adjust the Margin or Padding: You may need to add sufficient margin or padding to the bottom of your content area to ensure there is space for the footer. Use a Sticky Footer: If you want the footer to always be at the bottom but not overlap the content when the page content is long, you can use a sticky footer technique. Clear Floats: If you’re using floats in your layout, make sure to clear them before the footer so that it doesn’t overlap the content. Here’s an example of CSS that can help prevent the footer from overlapping: #footer { position: relative; /* or absolute */ width: 100%; clear: both; } And ensure that your content has enough padding at the bottom: #content { padding-bottom: [height of your footer]; } Replace [height of your footer] with the actual height of your footer. If these suggestions don’t resolve the issue, it might be necessary to look at the specific code involved. You can also seek further assistance on forums like Stack Overflow or the Joomla community forum where you can share code snippets and get more tailored advice. [1]: http://www.maxim-timeclock.com
letije1126
letije1126 posted this 18 March 2024
Thanks for the solution. Let me share the game papa's pizzeria
Thanks for the solution. Let me share the game [papa's pizzeria][1] [1]: https://papaspizzeria2.io/
hedinbarry
hedinbarry posted this 19 March 2024
Biznisvesti.mk, a renowned source of business news, delves into the captivating history of gambling. From ancient civilizations to modern times, humans have been drawn to games of chance. Click to read full guide on the evolution of this fascinating pastime.
Biznisvesti.mk, a renowned source of business news, delves into the captivating history of gambling. From ancient civilizations to modern times, humans have been drawn to games of chance. [Click to read full guide][1] on the evolution of this fascinating pastime. [1]: https://biznisvesti.mk/shto-e-toa-shto-go-pravi-zarabotuvaneto-pari-onlajn-podobro-od-oflajn-zarabotkata/
ralamis139
ralamis139 posted this 20 March 2024
I usually go to settings to adjust the size. You can play the slope game online
I usually go to settings to adjust the size. You can play the [slope game][1] online [1]: https://slope-game.online
taylorwin167
taylorwin167 posted this 15 June 2024
I am grateful for the prompt notification you have sent, which is in addition to my genuine appreciation for the products you have already supplied. I am appreciative of the opportunity to access this exceptional information. I earnestly anticipate that you will persist in disseminating your exceptional concepts.
papa's freezeria
I am grateful for the prompt notification you have sent, which is in addition to my genuine appreciation for the products you have already supplied. I am appreciative of the opportunity to access this exceptional information. I earnestly anticipate that you will persist in disseminating your exceptional concepts. [papa's freezeria][1] [1]: https://papas-freezeria.io
alexahills654321
alexahills654321 posted this 17 June 2024
Excellent .. Amazing .. I’ll bookmark your blog and take the feeds also…I’m happy to find so many useful info here in the post, we need work out more techniques in this regard, thanks for sharing.. Bangalore Escorts || Escorts in Delhi|| Bangalore Escort|| Delhi Escorts Service||
Excellent .. Amazing .. I’ll bookmark your blog and take the feeds also…I’m happy to find so many useful info here in the post, we need work out more techniques in this regard, thanks for sharing.. [Bangalore Escorts][1] || [Escorts in Delhi][2]|| [Bangalore Escort][3]|| [Delhi Escorts Service][4]|| [1]: https://www.urfi.in/ [2]: https://www.beautiqueen.in/ [3]: https://www.sunnyescorts.in/ [4]: https://www.dimple-gupta.com/
alexahills654321
I am bookmarking this webpage in my favorite's folder so I can return again. You made valid points in this content that I concludes require further exploration. And I concur with much of this info. Bangalore Escorts || Escorts in Delhi|| Bangalore Escort|| Delhi Escorts Service
I am bookmarking this webpage in my favorite's folder so I can return again. You made valid points in this content that I concludes require further exploration. And I concur with much of this info. [Bangalore Escorts][1] || [Escorts in Delhi][2]|| [Bangalore Escort][3]|| [Delhi Escorts Service][4] [1]: https://www.thebangaloreescort.com/ [2]: https://www.rashikhanna.in/ [3]: http://www.bangalore-escorts.in/ [4]: http://www.delhicallgirl.in/
alexahills654321
This is a great inspiring article. I am pretty much pleased with your good work. You put really very helpful information. Keep it up. Keep blogging. Looking to reading your next post. Bangalore Escorts|| Aerocity Escort|| Bangalore Escort|| Dwarka Escorts Service||
This is a great inspiring article. I am pretty much pleased with your good work. You put really very helpful information. Keep it up. Keep blogging. Looking to reading your next post. [Bangalore Escorts][1]|| [Aerocity Escort][2]|| [Bangalore Escort][3]|| [Dwarka Escorts Service][4]|| [1]: https://www.dakshi.in/ [2]: https://www.modelescortsindelhi.com/aerocity-escorts/ [3]: https://www.juhijain.co.in/ [4]: https://www.dwarkaescorts.com/
alexahills654321
am overwhelmed by your post with such a nice topic. Usually I visit your blogs and get updated through the information you include but today’s blog would be the most appreciable. Well done! Bangalore Escorts || Escorts in Bangalore|| Bangalore Escort|| Hotel Escorts in Delhi||
am overwhelmed by your post with such a nice topic. Usually I visit your blogs and get updated through the information you include but today’s blog would be the most appreciable. Well done! [Bangalore Escorts][1] || [Escorts in Bangalore][2]|| [Bangalore Escort][3]|| [Hotel Escorts in Delhi][4]|| [1]: https://www.arohiverma.in/ [2]: https://ctescorts.in/ [3]: https://www.bangaloreescortindia.co.in/ [4]: http://www.callgirlsnearhotels.com/
k8betinfo
k8betinfo posted this 17 June 2024
K8 - K8BET là nhà cái cá cược trực tuyến hàng đầu Châu Á, với độ uy tín cao, tính hợp pháp, mang đến sân chơi công bằng và minh bạch cho mọi cược thủ.
---------- K8 - K8BET là nhà cái cá cược trực tuyến hàng đầu Châu Á, với độ uy tín cao, tính hợp pháp, mang đến sân chơi công bằng và minh bạch cho mọi cược thủ.
jamesnoah78601
jamesnoah78601 posted this 27 June 2024
Maxim Time Clock provides a full range of solutions to improve operational efficiency, including payroll process optimisation, staff attendance tracking, and seamless communication.
Maxim Time Clock
Maxim Time Clock provides a full range of solutions to improve operational efficiency, including payroll process optimisation, staff attendance tracking, and seamless communication. [Maxim Time Clock][1] [1]: https://maxim-timeclock.online
aliyaarora654321
aliyaarora654321 posted this 01 July 2024
Its most noticeably awful piece was that the product just worked discontinuously and the information was not exact. Escorts in Delhi You clearly cannot go up against anybody about what you have found if the data isn't right.
Its most noticeably awful piece was that the product just worked discontinuously and the information was not exact. [Escorts in Delhi][1] You clearly cannot go up against anybody about what you have found if the data isn't right. [1]: https://delhi.shreenandini.in/
aliyaarora654321
What a fantastic post you have made. Kolkata Call Girls Service I just stopped in to tell you I really enjoyed the read and shall be dropping by from time to time from now on.
What a fantastic post you have made. [Kolkata Call Girls Service][1] I just stopped in to tell you I really enjoyed the read and shall be dropping by from time to time from now on. [1]: https://kolkata.shreenandini.in/
henryoliver5178
henryoliver5178 posted this 05 July 2024
Being one of the biggest grocery stores in the country, Kroger uses its consumer feedback survey to constantly enhance its offerings and overall shopping experience.
krogerfeedback.com
Being one of the biggest grocery stores in the country, Kroger uses its consumer feedback survey to constantly enhance its offerings and overall shopping experience. [krogerfeedback.com][1] [1]: https://kroger-feedbacks.online
kolangpurae
kolangpurae posted this 06 July 2024
The L.L.Bean Mastercard website or the back of your card both include contact details for customer support. Utilizing all of the resources accessible to you will assist guarantee a positive and easy transition to your new card.
Activate.llbeanmastercard.com
The L.L.Bean Mastercard website or the back of your card both include contact details for customer support. Utilizing all of the resources accessible to you will assist guarantee a positive and easy transition to your new card. [Activate.llbeanmastercard.com][1] [1]: https://activatellbeenmastarcard.shop/
sadiesink951
sadiesink951 posted this 10 July 2024
Use CSS to adjust the footer height papa louie . Place the footer at the bottom of the page using CSS position: absolute or position: fixed.
Use CSS to adjust the footer height [papa louie][1] . Place the footer at the bottom of the page using CSS position: absolute or position: fixed. [1]: https://papalouie.io/
yahoomunna049
yahoomunna049 posted this 22 July 2024
Customer happiness is our first concern at Lowe's. Tell us about your recent visit by filling out our satisfaction survey. In order to improve your purchasing experience and provide outstanding service, your input is essential.
Lowe’s Survey
Customer happiness is our first concern at Lowe's. Tell us about your recent visit by filling out our satisfaction survey. In order to improve your purchasing experience and provide outstanding service, your input is essential. [Lowe’s Survey][1] [1]: https://lows-comsurvey.org/
mateoliam86025
mateoliam86025 posted this 23 July 2024
It's likely that many of you recall JoinPD.com as the preferred domain in the past to access Pear Deck classes. However, in order to improve user experience and guarantee security, Pear Deck has recently moved its attention to PearDeck.com, its main domain.
JoinPD.com
It's likely that many of you recall JoinPD.com as the preferred domain in the past to access Pear Deck classes. However, in order to improve user experience and guarantee security, Pear Deck has recently moved its attention to PearDeck.com, its main domain. [JoinPD.com][1] [1]: https://pd-join.online
marksteven363738
marksteven363738 posted this 26 July 2024
The official survey website to take part in the Wawa customer satisfaction survey is called MyWawaVisit. The primary goal of the mywawavisit survey is to get accurate feedback from customers.
MyWawaVisit.Com
The official survey website to take part in the Wawa customer satisfaction survey is called MyWawaVisit. The primary goal of the mywawavisit survey is to get accurate feedback from customers. [MyWawaVisit.Com][1] [1]: https://mywawavisits.online
johndavid6397366
johndavid6397366 posted this 29 July 2024
The sponsor disclaims all liability for entries that are misdirected, lost, damaged, illegible, garbled, incomplete, or arrive late. Evidence of transmission or submission shall not be considered evidence of Sponsor reception. Online participants are subject to the notices published on Burlington. Burlingtonfeedback.com
The sponsor disclaims all liability for entries that are misdirected, lost, damaged, illegible, garbled, incomplete, or arrive late. Evidence of transmission or submission shall not be considered evidence of Sponsor reception. Online participants are subject to the notices published on Burlington. [Burlingtonfeedback.com][1] [1]: https://burlingtonfeedback.online/
