How to upload the new themes to the WordPress after the file is to big to upload it direct from the control panel of the WordPress?
Load it directly via cPanel or the hosting panel you manage in the wp-content>themes folder and unzip it
https://www.youtube.com/watch?v=7BfNVYJxjyE&ab_channel=SunilChaudhary%28SuniltamsGuruji%29
We confirm it is a great solution. Just in case here is some info from our end.
Many servers use the default limit of 2 MB on the maximum file size. If this is the case with your server, some template files are considered as too big and cannot be uploaded by using the "Upload&Install" button. If this is the case for you, please use the method below.
To install the template via FTP you should upload the unpacked template to the server using your favorite FTP software.
Be sure to upload (copy+paste) the theme folder to the directory:
/path_to_wordpress/wp-content/themes/
where
/path_to_wordpress/
is the location of your WordPress installation on the server.
After making sure your theme folder is successfully moved to "Themes" folder, log in to your WordPress back-end, go to Appearance >> Themes, choose the theme and press "Activate" to activate it.
You may also consider changing the max filesize limit.
Everytime I upload a theme I have this massage:
I have it with Artisteer but also with Themler!
so both my 2 are completely useless.
Fatal error: Uncaught ArgumentCountError: Too few arguments to function WP_Widget::__construct(), 0 passed in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget-factory.php on line 62 and at least 2 expected in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget.php:163 Stack trace: #0 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget-factory.php(62): WP_Widget->__construct() #1 C:\xampp\htdocs\MyWebsite\wp-includes\widgets.php(115): WP_Widget_Factory->register('VMenuWidget') #2 C:\xampp\htdocs\MyWebsite\wp-content\themes\untitled\library\widgets.php(255): register_widget('VMenuWidget') #3 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(308): artWidgetsInit('') #4 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(332): WP_Hook->apply_filters('', Array) #5 C:\xampp\htdocs\MyWebsite\wp-includes\plugin.php(517): WP_Hook->do_action(Array) #6 C:\xampp\htdocs\MyWebsite\wp-includes\widgets.php(1854): do_action('widgets_init') #7 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(308): wp_widgets_init('') #8 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(332): WP_Hook->apply_filters(NULL, Array) #9 C:\xampp\htdocs\MyWebsite\wp-includes\plugin.php(517): WP_Hook->do_action(Array) #10 C:\xampp\htdocs\MyWebsite\wp-settings.php(617): do_action('init') #11 C:\xampp\htdocs\MyWebsite\wp-config.php(96): require_once('C:\xampp\htdocs...') #12 C:\xampp\htdocs\MyWebsite\wp-load.php(50): require_once('C:\xampp\htdocs...') #13 C:\xampp\htdocs\MyWebsite\wp-admin\admin.php(34): require_once('C:\xampp\htdocs...') #14 C:\xampp\htdocs\MyWebsite\wp-admin\customize.php(13): require_once('C:\xampp\htdocs...') #15 {main} thrown in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget.php on line 163
Everytime I upload a theme I have this massage: I have it with Artisteer but also with Themler! so both my 2 are completely useless. Fatal error: Uncaught ArgumentCountError: Too few arguments to function WP_Widget::__construct(), 0 passed in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget-factory.php on line 62 and at least 2 expected in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget.php:163 Stack trace: #0 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget-factory.php(62): WP_Widget->__construct() #1 C:\xampp\htdocs\MyWebsite\wp-includes\widgets.php(115): WP_Widget_Factory->register('VMenuWidget') #2 C:\xampp\htdocs\MyWebsite\wp-content\themes\untitled\library\widgets.php(255): register_widget('VMenuWidget') #3 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(308): artWidgetsInit('') #4 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(332): WP_Hook->apply_filters('', Array) #5 C:\xampp\htdocs\MyWebsite\wp-includes\plugin.php(517): WP_Hook->do_action(Array) #6 C:\xampp\htdocs\MyWebsite\wp-includes\widgets.php(1854): do_action('widgets_init') #7 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(308): wp_widgets_init('') #8 C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-hook.php(332): WP_Hook->apply_filters(NULL, Array) #9 C:\xampp\htdocs\MyWebsite\wp-includes\plugin.php(517): WP_Hook->do_action(Array) #10 C:\xampp\htdocs\MyWebsite\wp-settings.php(617): do_action('init') #11 C:\xampp\htdocs\MyWebsite\wp-config.php(96): require_once('C:\\xampp\\htdocs...') #12 C:\xampp\htdocs\MyWebsite\wp-load.php(50): require_once('C:\\xampp\\htdocs...') #13 C:\xampp\htdocs\MyWebsite\wp-admin\admin.php(34): require_once('C:\\xampp\\htdocs...') #14 C:\xampp\htdocs\MyWebsite\wp-admin\customize.php(13): require_once('C:\\xampp\\htdocs...') #15 {main} thrown in C:\xampp\htdocs\MyWebsite\wp-includes\class-wp-widget.php on line 163The Radiant Therapeutic Massage offers a relaxing and professional environment focused on wellness, helping clients relieve stress and muscle tension through expert care. Located at Address:1004 Parsons Rd SW Unit 7, Edmonton, AB T6X 0J4, Canada, and reachable at Phone: +17805128372, The Radiant Therapeutic Massage is known for providing the best deep tissue massage edmonton residents trust for effective pain relief. Whether you need recovery or relaxation, The Radiant Therapeutic Massage delivers personalized treatments designed to rejuvenate both body and mind.
The Radiant Therapeutic Massage offers a relaxing and professional environment focused on wellness, helping clients relieve stress and muscle tension through expert care. Located at Address:1004 Parsons Rd SW Unit 7, Edmonton, AB T6X 0J4, Canada, and reachable at Phone: +17805128372, The Radiant Therapeutic Massage is known for providing the [best deep tissue massage edmonton][1] residents trust for effective pain relief. Whether you need recovery or relaxation, The Radiant Therapeutic Massage delivers personalized treatments designed to rejuvenate both body and mind. [1]: https://theradiantmassage.ca/deep-tissue-massage-edmonton/
