Virtuemart 4, Joomla 4 error: "500 - behavior::modal not found"
souacz
souacz posted this 03 January 2023
Joomla 4, Virtuemart 4, Themler 559, PHP 8.1
After entering the product category, I get the error: "500 - behavior::modal not found".
On the standard Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when tried to edit category template.
Downgrading the php version to 7.4 does not solve the problem (I mention this because you advised a user with a similar problem)
Please intervene urgently.
Joomla 4, Virtuemart 4, Themler 559, PHP 8.1 After entering the product category, I get the error: "500 - behavior::modal not found". On the standard Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when tried to edit category template. Downgrading the php version to 7.4 does not solve the problem (I mention this because you advised a user with a similar problem) Please intervene urgently.
28 Comments
Sinergia Innovaciones
Sinergia Innovaciones posted this 27 January 2023
Hello, I have the same problem, it seems that Themler is not yet compatible with virtuemart in J4.
reginaloragwen
reginaloragwen posted this 21 June 2023
The message "500 - behavior::modal not found" also appears on my screen. Did you find a way to solve the problem?
reginaloragwen
If you the answer, please tell me how to fix it. Thanks. elastic man
> The message "500 - behavior::modal not found" also appears on my screen. Did you find a way to solve the problem? If you the answer, please tell me how to fix it. Thanks. [elastic man][1] [1]: https://elastic-man.com
labourdolphin
labourdolphin posted this 12 July 2023
When using Joomla 4 and Virtuemart 4, the error message "500 - behavior::modal not found" typically appears. This error message occurs most commonly when certain Virtuemart files are not loaded properly or are not compatible with the most recent version of Joomla geometry dash unblocked
When using Joomla 4 and Virtuemart 4, the error message "500 - behavior::modal not found" typically appears. This error message occurs most commonly when certain Virtuemart files are not loaded properly or are not compatible with the most recent version of Joomla [geometry dash unblocked][1] [1]: https://geometrydash-unblocked.com
philippe.t
philippe.t posted this 05 January 2024
in \templates\untitled\editor\html\com_virtuemart\category\default.php
comment lign 27
as :
//JHTML::_('behavior.modal');
in \templates\untitled\html\com_virtuemart\category\default.php
lign 27
same as :
philippe
Hello, in \templates\untitled\editor\html\com_virtuemart\category\default.php comment lign 27 as : //JHTML::_('behavior.modal'); in \templates\untitled\html\com_virtuemart\category\default.php lign 27 same as : //JHTML::_('behavior.modal'); regards, philippe
souacz
souacz posted this 05 January 2024
Thanks for your answer,
now I've got another error message:
0 - Cannot use positional argument after named argument
EDIT: It works properly for PHP 7.x but not for 8.x
Thanks for your answer, now I've got another error message: 0 - Cannot use positional argument after named argument EDIT: It works properly for PHP 7.x but not for 8.x
nehaaaduttt
nehaaaduttt posted this 08 January 2024
These days, there is such a gigantic assortment of people that need to con people into getting their money as it were. Be that as it may, what do you do when you need some sensible level Call Girls in Goa All things contemplated, you return fitting to us when you consider that we're acclaimed for giving our customers the Goa Escorts Service that gives assurance and validity as well.
These days, there is such a gigantic assortment of people that need to con people into getting their money as it were. Be that as it may, what do you do when you need some sensible level [Call Girls in Goa][1] All things contemplated, you return fitting to us when you consider that we're acclaimed for giving our customers the Goa Escorts Service that gives assurance and validity as well. [1]: https://www.twinklesingh.in/
iampriyankapluss
iampriyankapluss posted this 30 April 2024
I am telling those guys who are getting stressed or obsessed about to fuck please visit not only for visiting the religious places in haridwar also take the services of Haridwar Escort Sana Khan this name is very famous if you search this name of google or other web search engines
I am telling those guys who are getting stressed or obsessed about to fuck please visit not only for visiting the religious places in haridwar also take the services of [Haridwar Escort][1] Sana Khan this name is very famous if you search this name of google or other web search engines [1]: https://www.sanakhan.in/haridwar-call-girls.html
questcraftvr
questcraftvr posted this 03 May 2024
On the standard Yacine TV Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when trying to edit the category template.
I have the same problem, it seems that Themler is not yet compatible with Virtuemart 4, Themler 559, PHP 8.1.
> Joomla 4, Virtuemart 4, Themler 559, PHP 8.[1][1] > > After entering the product category, I get the error: "500 - behavior::modal not found". > > On the standard [Yacine TV][2] Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when trying to edit the category template. > > Downgrading the php version to 7.4 does not solve the problem (I mention this because you advised a user with a similar problem) > > Please intervene urgently. I have the same problem, it seems that Themler is not yet compatible with Virtuemart 4, Themler 559, PHP 8.1. [1]: https://filmplus.vip/ [2]: https://yacinetv.me/
make.goalken
make.goalken posted this 03 May 2024
Thank you for providing such useful information. I've been having trouble coming up with many questions about this topic. I'll stick with you! fnaf game
Thank you for providing such useful information. I've been having trouble coming up with many questions about this topic. I'll stick with you! [fnaf game][1] [1]: https://fnafgame.io
frautim68
frautim68 posted this 03 May 2024
Brilliant article, your commitment to enriching the community is truly commendable. Solar
Brilliant article, your commitment to enriching the community is truly commendable. [Solar][1] [1]: https://medium.com/@solar-power-systems/the-advantages-and-disadvantages-of-solar-energy-in-henderson-nevada-dadbac2fd385
annata0215
annata0215 posted this 30 July 2024
The error "500 - behavior::modal not found" Pokerogue in Joomla 4 with VirtueMart 4 typically indicates a problem with the Joomla behavior class not being properly recognized or included in your site's configuration.
The error "500 - behavior::modal not found" [Pokerogue][1] in Joomla 4 with VirtueMart 4 typically indicates a problem with the Joomla behavior class not being properly recognized or included in your site's configuration. [1]: https://pokeroguegame.io/
Evangeline
Evangeline posted this 16 October 2024
Since the error occurs only with the Themler template, check if there are any overrides in your template that might be causing the issue. Look for any custom JavaScript, slope or CSS that might conflict with Joomla's modal behavior.
Since the error occurs only with the Themler template, check if there are any overrides in your template that might be causing the issue. Look for any custom JavaScript, [slope](https://slope-play.com) or CSS that might conflict with Joomla's modal behavior.
suzannomer258
suzannomer258 posted this 17 October 2024
CredibleBH is a software company specializing in behavioral health solutions. They offer a comprehensive health record system designed for various mental health organizations, focusing on improving patient care.
[CredibleBH][1] is a software company specializing in behavioral health solutions. They offer a comprehensive health record system designed for various mental health organizations, focusing on improving patient care. [1]: https://www.crediblebh.ltd/
jameswalterra8262
jameswalterra8262 posted this 01 May 2025
Thanks for reporting this.
The “500 - behavior::modal not found” error is a known industrial cleaning plant compatibility issue between Themler-generated templates and Joomla 4/VirtueMart 4. Since it also appears in the Themler editor and persists even after downgrading to PHP 7.4, it points to a template issue rather than a server one.
Hi, Thanks for reporting this. The “500 - behavior::modal not found” error is a known [industrial cleaning plant](https://twincitiesindustrialcleaning.com/industrial-plant-cleaning-services/) compatibility issue between Themler-generated templates and Joomla 4/VirtueMart 4. Since it also appears in the Themler editor and persists even after downgrading to PHP 7.4, it points to a template issue rather than a server one.
emilycandy1012
emilycandy1012 posted this 13 May 2025
I'd want to convey my gratitude for offering such excellent content level devil. I saved your website to explore the fresh ideas you generate, and I truly enjoyed every minute of it.
I'd want to convey my gratitude for offering such excellent content [level devil][1]. I saved your website to explore the fresh ideas you generate, and I truly enjoyed every minute of it. [1]: https://level-devil.io
minhkilback
minhkilback posted this 23 May 2025
Learn quick tips and tricks to master the Crazy Cattle 3D Game and rule the ranch like a legend!
Learn quick tips and tricks to master the [Crazy Cattle 3D](https://crazycattle3d.vip/) Game and rule the ranch like a legend!
levandovskii
levandovskii posted this 09 July 2025
I’ve faced the 500 error before, and it's super frustrating! It could be anything from server issues to conflicting code or plugins. I found that sometimes simply checking your server’s settings or clearing the cache helps. While troubleshooting, I also discovered mad muscles review which isn't related to Joomla directly, but if you want to optimize your system or just boost your overall web performance, it can help! It’s a resource I found when exploring ways to keep things running smoothly across different platforms, and I thought it might be worth mentioning.
I’ve faced the 500 error before, and it's super frustrating! It could be anything from server issues to conflicting code or plugins. I found that sometimes simply checking your server’s settings or clearing the cache helps. While troubleshooting, I also discovered [mad muscles review][1] which isn't related to Joomla directly, but if you want to optimize your system or just boost your overall web performance, it can help! It’s a resource I found when exploring ways to keep things running smoothly across different platforms, and I thought it might be worth mentioning. [1]: https://madmuscles.com/review
wackyflip125
wackyflip125 posted this 14 July 2025
I'd want to offer my heartfelt appreciation for your kindness and smart advise. I am deeply grateful for the significant impact you have made on my life Wacky flip.
I'd want to offer my heartfelt appreciation for your kindness and smart advise. I am deeply grateful for the significant impact you have made on my life [Wacky flip][1]. [1]: https://wackyflip.io
SkarletRivpiz
SkarletRivpiz posted this 09 August 2025
Looks like Themler hasn’t been updated to handle Joomla 4’s changes in modal behavior. In HK dev circles we’ve seen similar fixes shared via Telegram groups, often involving replacing behavior::modal with the new Bootstrap 5 modal script.
Looks like Themler hasn’t been updated to handle Joomla 4’s changes in modal behavior. In HK dev circles we’ve seen similar fixes shared via [Telegram][1] groups, often involving replacing behavior::modal with the new Bootstrap 5 modal script. [1]: https://www.telegram-ios.com
