Virtuemart 4, Joomla 4 error: "500 - behavior::modal not found"
souacz
souacz posted this 03 January 2023
Joomla 4, Virtuemart 4, Themler 559, PHP 8.1
After entering the product category, I get the error: "500 - behavior::modal not found".
On the standard Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when tried to edit category template.
Downgrading the php version to 7.4 does not solve the problem (I mention this because you advised a user with a similar problem)
Please intervene urgently.
Joomla 4, Virtuemart 4, Themler 559, PHP 8.1 After entering the product category, I get the error: "500 - behavior::modal not found". On the standard Joomla template it's ok, the problem is only in the template generated by Themler. Themler editor site has the same error when tried to edit category template. Downgrading the php version to 7.4 does not solve the problem (I mention this because you advised a user with a similar problem) Please intervene urgently.
25 Comments
SkarletRivpiz
SkarletRivpiz posted this 09 August 2025
In Hong Kong web projects, we’ve used DeepSeek V3 code search to locate every instance of JHtml::_('behavior.modal') in Themler templates and replace them with Joomla 4-compatible modal initializations. Might help here too.
In Hong Kong web projects, we’ve used [DeepSeek V3][1] code search to locate every instance of JHtml::_('behavior.modal') in Themler templates and replace them with Joomla 4-compatible modal initializations. Might help here too. [1]: https://www.deepseek-apk.com
SkarletRivpiz
For Hong Kong-based Virtuemart communities, we sometimes coordinate bug-fixing sessions via نسخة الويب من واتساب, so developers can live-share browser console logs while testing on different templates.
For Hong Kong-based Virtuemart communities, we sometimes coordinate bug-fixing sessions via [نسخة الويب من واتساب,][1] so developers can live-share browser console logs while testing on different templates. [1]: https://www.whathesapp-web.com
SkarletRivpiz
Some Joomla meetups here also troubleshoot template override issues together, and we’ve used Versi Web WhatsApp chats to keep track of fixes, especially when comparing results between PHP 8.1 and 7.4 environments.
Some Joomla meetups here also troubleshoot template override issues together, and we’ve used [Versi Web WhatsApp][1] chats to keep track of fixes, especially when comparing results between PHP 8.1 and 7.4 environments. [1]: https://www.whatlsapp-web.com
suzyiulee2024
suzyiulee2024 posted this 29 August 2025
The 2D run-and-jump platform game stickman boost ! 2 incorporates aspects of parkour. More emotions, move explosions, stunts, and levels!
The 2D run-and-jump platform game [stickman boost](https://stickmanboost.com/) ! 2 incorporates aspects of parkour. More emotions, move explosions, stunts, and levels!
928380504
928380504 posted this 13 December 2025
https://play-slice-master.com/
https://1v1-lol.cc/
https://planet-clicker.co/
https://text-twist.co/
https://buildnow-gg.org/
https://capybara-clicker.co/
https://play-retro-bowl.com/
[https://play-slice-master.com/][1] [https://1v1-lol.cc/][2] [https://planet-clicker.co/][3] [https://text-twist.co/][4] [https://buildnow-gg.org/][5] [https://capybara-clicker.co/][6] [https://play-retro-bowl.com/][7] [1]: https://play-slice-master.com/ [2]: https://1v1-lol.cc/ [3]: https://planet-clicker.co/ [4]: https://text-twist.co/ [5]: https://buildnow-gg.org/ [6]: https://capybara-clicker.co/ [7]: https://play-retro-bowl.com/
