I have install joomla 4.1 and i have install blank_themler_joomla4_theme. While i try to edit that i got an error see the attached file.
I have tried to change PHP version from 8 to 7.4 or 7.3 but it doesn't work.
thank you
Katia
thank you
Katia
Could you please try the theme in attachment?
yes that works.
thank you
Katia
Hello Katia,
Thanks for letting us know. This is the latest theme version at the moment. A new update with more fixes is expected yet.
While i was working i got a PHP error and from that moment when i try to import any section i can see only those things that are in the main page. If i choose anything from the side i got an empty window. See attached file.
thank you
Katia
Could you please try clearing cache and reloading the theme - is the issue still present?
Yes it works. the php error i while i am trying to upload an image.
I have login and log out and finally works.
thank you
Katia
Katia, you are welcome. Please feel free to contact us if our further assistance is needed.
I still have the problem with the import template in a section. I have delete the cache but still.
thank you
Katia
Hello Katia,
Do you get the error when trying to import the section from library? What is the error message?
i thing i find a solution for the above. If i choose from side bar to add a new section i have no problem.
But now i have another one. I got the attached error. And while i am adding a menu on the header is not working properly. It always change position and i can't move it up.
Katia
Hello i thing i find a solution for the above. If i choose from side bar to add a new section i have no problem. But now i have another one. I got the attached error. And while i am adding a menu on the header is not working properly. It always change position and i can't move it up. Katia
