i can't edit my aritcles
katia
katia posted this 27 January 2023
I am trying to edit my aticles from Themler side but every time i do that it deletes the previous i have create. It seems that i am receating page templete, and every time i create the page it deletes the pevious one.
thank you
Katia
Hello, I am trying to edit my aticles from Themler side but every time i do that it deletes the previous i have create. It seems that i am receating page templete, and every time i create the page it deletes the pevious one. thank you Katia
lordvaldek
lordvaldek posted this 28 January 2023
Hello, what do You mean? You are using wordpress or something else? Once you write about editing the page but first in the title about articles. I'm guessing it's the sides in wordpress. There may be several solutions. 1. You edit the default template, you should create a template for each page separately, and add another and another.... 2 you have CMS content enabled on templates and you edit it. 3. when you are adding blocks you put them in the wrong sections. You can insert a container and add blocks, columns, etc. to the container. Than add another ..but not to the header or Footer section.
I am not a programmer, but I encountered such problems at the beginning of creating templates. Regards. Thomas
Hello, what do You mean? You are using wordpress or something else? Once you write about editing the page but first in the title about articles. I'm guessing it's the sides in wordpress. There may be several solutions. 1. You edit the default template, you should create a template for each page separately, and add another and another.... 2 you have CMS content enabled on templates and you edit it. 3. when you are adding blocks you put them in the wrong sections. You can insert a container and add blocks, columns, etc. to the container. Than add another ..but not to the header or Footer section. I am not a programmer, but I encountered such problems at the beginning of creating templates. Regards. Thomas
katia
katia posted this 30 January 2023
Sorry i forgot to mention that i am using Joomla. I have edit my first aritle through themler but when i am trying to create a second one i can't beacause it changes the first one at the same time.
katia
Hello, Sorry i forgot to mention that i am using Joomla. I have edit my first aritle through themler but when i am trying to create a second one i can't beacause it changes the first one at the same time. katia
katia
Please reply beacause i can't finish my site or create a new one.
My problem is that i have folloe the instractions it doesn't work. I want o create new pages inside joomla edit them through Themler. When i do that it seems that is using a "page templete" and everytime i am making changes in a page it a change everything.
Please help me.
I am using joomla 4.1.0
thank you
Katia
Hello, Please reply beacause i can't finish my site or create a new one. My problem is that i have folloe the instractions it doesn't work. I want o create new pages inside joomla edit them through Themler. When i do that it seems that is using a "page templete" and everytime i am making changes in a page it a change everything. Please help me. I am using joomla 4.1.0 thank you Katia
katia
katia posted this 31 January 2023
My problem is that i have follow the instractions it doesn't work. I want o create new pages inside joomla edit them through Themler. When i do that it seems that is using a "page templete" and everytime i am making changes in a page it a change everything.
Please help me.
thank you
Katia
Hello, Please reply beacause i can't finish my site or create a new one. My problem is that i have follow the instractions it doesn't work. I want o create new pages inside joomla edit them through Themler. When i do that it seems that is using a "page templete" and everytime i am making changes in a page it a change everything. Please help me. I am using joomla 4.1.0 thank you Katia
katia
katia posted this 01 February 2023
I am still waiting for an answer.
Katia
Hello I am still waiting for an answer. Katia
