Problems with Joomla 4 after migration
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 02 February 2023
Hello.
I have the problem that I cannot open Themler Beta for Joomla 4 after migrating from Joomla 3rd to 4th.
The 'Edit' button does not click and therefore Themler does not start.
I've tried it in different ways.
I use the latest versions everywhere.
Does anyone else have these problems?
Hello. I have the problem that I cannot open Themler Beta for Joomla 4 after migrating from Joomla 3rd to 4th. The 'Edit' button does not click and therefore Themler does not start. I've tried it in different ways. I use the latest versions everywhere. Does anyone else have these problems?
13 Comments
rein
rein posted this 03 February 2023
As far as I know no one can.
It only works in a new blank Joomla4.
And then I use JMigrator, works pretty well
As far as I know no one can. It only works in a new blank Joomla4. And then I use JMigrator, works pretty well
Werbeagentur Schulz-Design posted this 03 February 2023
This is absolutely unacceptable! It's a shame how we're treated here!
Thanks for the tip.
How do you go about it? Do you install a fresh J4 first, then create the template with Themler first and then use JMigrator for the content?
This is absolutely unacceptable! It's a shame how we're treated here! > And then I use JMigrator, works pretty well Thanks for the tip. How do you go about it? Do you install a fresh J4 first, then create the template with Themler first and then use JMigrator for the content?
rein
rein posted this 04 February 2023
  1. frise joomla4 (create a new administrator otherwise you will get JMigrator overwriting the old one and it won't work properly)
  2. make 3 pages (with some content)
  3. create 3 menu buttons for those pages (otherwise Themler won't work as it should)
  4. then install the latest blank template from Themler (check if the template works properly and adjust it if necessary)
  5. then you can install and use JMigrator (you must first set and save the settings in JMigrator)
  6. If all goes well, the old administrator account will still work
    good luck
1. frise joomla4 (create a new administrator otherwise you will get JMigrator overwriting the old one and it won't work properly) 2. make 3 pages (with some content) 3. create 3 menu buttons for those pages (otherwise Themler won't work as it should) 4. then install the latest blank template from Themler (check if the template works properly and adjust it if necessary) 5. then you can install and use JMigrator (you must first set and save the settings in JMigrator) 5. If all goes well, the old administrator account will still work good luck
donnalillyexpert
donnalillyexpert posted this 05 February 2023
hey, i am new.
hey, i am new.
teempade
teempade posted this 05 February 2023
Before upgrading as always take a full backup of the website. Navigate to System > Global configurations > Server > Error Report > Maximum. ... Navigate to Components > Joomla updates > Options. Set the Upgrade to Joomla Next. Click on updates to see Joomla 4 update notification.
Werbeagentur Schulz-Design posted this 06 February 2023
Thanks for your tips.
It would be much easier if Themler worked properly after the migration. I think it wouldn't be that much of a hassle for the programmers to make the edit button clickable.
Hello Support?
Will this still be realized?
Thanks for your tips. It would be much easier if Themler worked properly after the migration. I think it wouldn't be that much of a hassle for the programmers to make the edit button clickable. Hello Support? Will this still be realized?
teempade
teempade posted this 24 February 2023
i am new. verizon internet login
mobdro app
i am new. [verizon internet login][1] [mobdro app][2] [1]: https://myfiosgateway.one/ [2]: https://tutuappvip.co/mobdro-download
webalen680
webalen680 posted this 24 April 2024
As always, make a complete backup of the website before upgrading basket random. Go to Server > Error Report > Maximum under System > Global Configurations. Go to Components > Updates for Joomla > Options.
As always, make a complete backup of the website before upgrading [basket random](https://basketrandom.io). Go to Server > Error Report > Maximum under System > Global Configurations. Go to Components > Updates for Joomla > Options.
frautim68
frautim68 posted this 03 May 2024
Outstanding article, thank you for consistently providing valuable insights. Solar
Outstanding article, thank you for consistently providing valuable insights. [Solar][1] [1]: https://medium.com/@solar-power-systems/the-advantages-and-disadvantages-of-solar-energy-in-henderson-nevada-dadbac2fd385
Werbeagentur Schulz-Design posted this 15 May 2024
Now I have the same problem when I want to migrate from Joomla 4 to Joomla 5:
After the successful migration from J4 to J5, I can click the button: Edit Template, but nothing happens.
When I try to start the template from the URL I get an error message (500).
With a new Joomla 5 installation it works with the same template.
But I need a way to migrate a J4 to J5.
However, the hope that someone from support will respond is nil, so I hope there is another user here who has an idea on how I can fix the problem.
Many thanks and kind regards
Thorsten
Now I have the same problem when I want to migrate from Joomla 4 to Joomla 5: After the successful migration from J4 to J5, I can click the button: Edit Template, but nothing happens. !2024-05-15-Templates-Stil-bearbeiten---Hannover-Meeting-2024---Administration.jpg! When I try to start the template from the URL I get an error message (500). With a new Joomla 5 installation it works with the same template. But I need a way to migrate a J4 to J5. However, the hope that someone from support will respond is nil, so I hope there is another user here who has an idea on how I can fix the problem. Many thanks and kind regards Thorsten [Werbeagentur Schulz-Design][1] [1]: https://www.schulzdesign.info/
toniafodakuta
toniafodakuta posted this 05 August 2024
I'm so happy with Payvantage. I needed a new phone but was concerned about my credit. Their no-credit approval process was super fast and easy. I got the latest Android phone without any stress, and the payment plan is very manageable. Highly recommend!
I'm so happy with [Payvantage][1]. I needed a new phone but was concerned about my credit. Their no-credit approval process was super fast and easy. I got the latest Android phone without any stress, and the payment plan is very manageable. Highly recommend! [1]: https://mypayvantage.com/
toniafodakuta
toniafodakuta posted this 10 August 2024
Discover the wonderful world of Alphabet Trains, where US-made sensory toys and personalized children’s products inspire creativity and support early learning. The Maple Landmarks Name Train is a fantastic toy for encouraging imaginative play, personalized step stools add a unique and personal touch to any child’s space, and the vibrant classroom rugs enhance the learning experience. Alphabet Trains is dedicated to providing high-quality products that enrich children’s developmental journey.https://alphabet-trains.com/
Discover the wonderful world of Alphabet Trains, where US-made sensory toys and personalized children’s products inspire creativity and support early learning. The Maple Landmarks Name Train is a fantastic toy for encouraging imaginative play, personalized step stools add a unique and personal touch to any child’s space, and the vibrant classroom rugs enhance the learning experience. Alphabet Trains is dedicated to providing high-quality products that enrich children’s developmental journey.[https://alphabet-trains.com/][1] [1]: https://alphabet-trains.com/
toniafodakuta
toniafodakuta posted this 30 April 2025
Space Landscape Designs shows exactly why they’re considered one of the best landscape architect firms in Sydney. Their thoughtful designs truly enhance your property while maintaining timeless appeal.
Space Landscape Designs shows exactly why they’re considered one of the [best landscape architect firms in Sydney][1]. Their thoughtful designs truly enhance your property while maintaining timeless appeal. [1]: https://www.spacedesigns.com.au/
