Display issue - "expired" label on Blog view
Pierre665
Pierre665 posted this 06 February 2023
An "Expired" label appears on the Blog view. This is from themler because it doesn't display with Joomla's default template.
Can you tell me how to fix this bug?
Pierre
Hello, An "Expired" label appears on the Blog view. This is from themler because it doesn't display with Joomla's default template. Can you tell me how to fix this bug? Regards, Pierre
11 Comments
stickmanhook2.org
stickmanhook2.org posted this 02 June 2025
Noticed the “expired” label Stickman Hook showing up on Blog view—might need a quick fix!
Noticed the “expired” label [Stickman Hook][1] showing up on Blog view—might need a quick fix! [1]: https://stickmanhook2.org
emmataylor.he
emmataylor.he posted this 02 June 2025
Sprint like nobody's watching—or like everyone is. In Speed Stars Game , the pressure is real, the stakes are high, and victory is just a few perfect taps away. Download now and chase that digital gold!
Sprint like nobody's watching—or like everyone is. In [Speed Stars Game](https://speedstarsgame.io) , the pressure is real, the stakes are high, and victory is just a few perfect taps away. Download now and chase that digital gold!
deyexe8189
deyexe8189 posted this 09 June 2025
Hi Pierre, it sounds like the "Expired" label is being injected by the Themler template itself, possibly through its article overrides or blog layout files. One quick fix you can try is checking the template's override files under /templates/your_template/html/com_content/category/ and look for any code that outputs JHTML::_('date', $this->item->publish_down, ...) or similar. You could either comment that out or add a conditional check to suppress the label. If you're not comfortable editing the PHP files, it might be worth reaching out to Themler support or switching to a more lightweight override temporarily. Hope that helps! golf hit
Hi Pierre, it sounds like the "Expired" label is being injected by the Themler template itself, possibly through its article overrides or blog layout files. One quick fix you can try is checking the template's override files under `/templates/your_template/html/com_content/category/` and look for any code that outputs `JHTML::_('date', $this->item->publish_down, ...)` or similar. You could either comment that out or add a conditional check to suppress the label. If you're not comfortable editing the PHP files, it might be worth reaching out to Themler support or switching to a more lightweight override temporarily. Hope that helps! [golf hit](https://golf-hit.io/)
baronassume
baronassume posted this 22 July 2025
Actually if it comes to geometry dash membership then renewal is mandatory. Display is important for you to access and use the tool or application effectively. Follow the programs with maximum utility updates. With PHP files content is really important for updates and more advanced experience.
Actually if it comes to [geometry dash][1] membership then renewal is mandatory. Display is important for you to access and use the tool or application effectively. Follow the programs with maximum utility updates. With PHP files content is really important for updates and more advanced experience. [1]: https://geometrydash3d.org
bloodmoneyfree.io
bloodmoneyfree.io posted this 30 September 2025
Enter Bloodmoney, a ruthless underworld where survival demands cunning, fortune favors betrayal, and every success is painted in red.
Enter [Bloodmoney][1], a ruthless underworld where survival demands cunning, fortune favors betrayal, and every success is painted in red. [1]: https://bloodmoneyfree.io/
trucalrofficial
trucalrofficial posted this 30 September 2025
Hello Pierre,
The “Expired” label is a known issue with Themler templates, as they sometimes interpret Joomla’s article date settings differently than the default template. To fix this, you can try the following:
Check Article Settings:
In Joomla, go to Content > Articles and verify that the “Finish Publishing” date is either empty or set to a future date. If it’s in the past, Themler will mark it as expired.
Template Overrides:
Open the Themler template settings and look for the Blog View layout. Some versions include a conditional tag that forces the “Expired” label. Removing or editing that condition can resolve it.
Update Themler:
If you’re running an older version of Themler, updating it may fix the bug, since newer builds improved compatibility with Joomla.
Go to TrueCaller Premium APK you will get premium version of TrueCaller app used for secure communication.
Regards!
Hello Pierre, The “Expired” label is a known issue with Themler templates, as they sometimes interpret Joomla’s article date settings differently than the default template. To fix this, you can try the following: Check Article Settings: In Joomla, go to Content > Articles and verify that the “Finish Publishing” date is either empty or set to a future date. If it’s in the past, Themler will mark it as expired. Template Overrides: Open the Themler template settings and look for the Blog View layout. Some versions include a conditional tag that forces the “Expired” label. Removing or editing that condition can resolve it. Update Themler: If you’re running an older version of Themler, updating it may fix the bug, since newer builds improved compatibility with Joomla. Go to [TrueCaller Premium APK][1] you will get premium version of TrueCaller app used for secure communication. Regards! [1]: https://truecalrmodapk.com/
xielili588
xielili588 posted this 09 November 2025
Navigate treacherous tracks with precision, commanding nimble cars and powerful trucks through a world governed by physics, where every move determines your vehicle's final stance in the Drive Mad unblocked.
Navigate treacherous tracks with precision, commanding nimble cars and powerful trucks through a world governed by physics, where every move determines your vehicle's final stance in the [Drive Mad unblocked](https://drivemadgame.cc/).
coleharry246
coleharry246 posted this 10 November 2025
Aim to survive for as long as you can as the difficulty increases, allowing for repetitive escape road gameplay.
Aim to survive for as long as you can as the difficulty increases, allowing for repetitive [escape road][1] gameplay. [1]: https://escaperoad.io/
avbgamenet
avbgamenet posted this 18 November 2025
Ringtone addicts, unite! 🤩 You need to save the site dobrevyzvaneni.mobi! They have every genre you can think of—from chart-toppers to R&B and chill tunes. Super fast download, absolutely free. Your phone deserves a fresh new sound!
Ringtone addicts, unite! 🤩 You need to save the site [dobrevyzvaneni.mobi][1]! They have every genre you can think of—from chart-toppers to R&B and chill tunes. Super fast download, absolutely free. Your phone deserves a fresh new sound! [1]: https://dobrevyzvaneni.mobi/
dajah60378
dajah60378 posted this 26 December 2025
It looks like you might be running into a metadata or caching glitch where the "expired" label is triggering incorrectly on your blog layout. While you're troubleshooting the display settings, it's worth checking if a plugin or theme update is causing the conflict, much like how a precise fit is required when installing a BAKFlip tonneau cover to ensure full functionality. Once you've ruled out CSS styling errors, a quick refresh of your site’s permalinks or clearing the cache usually clears up those stubborn labels.
It looks like you might be running into a metadata or caching glitch where the "expired" label is triggering incorrectly on your blog layout. While you're troubleshooting the display settings, it's worth checking if a plugin or theme update is causing the conflict, much like how a precise fit is required when installing a [BAKFlip][1] tonneau cover to ensure full functionality. Once you've ruled out CSS styling errors, a quick refresh of your site’s permalinks or clearing the cache usually clears up those stubborn labels. [1]: https://bakflipstore.com/
thoughtful.hare.yxwo
thoughtful.hare.yxwo posted this 4 weeks ago
The rewards that appear along the way in Snow Rider 3D not only create more appealing goals but also provide motivation for players to continue conquering increasingly longer distances.
The rewards that appear along the way in [Snow Rider 3D][1] not only create more appealing goals but also provide motivation for players to continue conquering increasingly longer distances. [1]: https://snowrideronline.io
