PHP update causes error
moordigital
moordigital posted this 16 February 2023
Hi Team Themler,
I am trying to update PHP version on a site and when I update to 8.0 or 8.1 (from 7.4) I get these errors - please advise.
Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 291
Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302
Many thanks in advance.
Angus
Hi Team Themler, I am trying to update PHP version on a site and when I update to 8.0 or 8.1 (from 7.4) I get these errors - please advise. Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 291 Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 291 Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302 Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302 Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302 Warning: Trying to access array offset on value of type null in /homepages/25/d790384314/htdocs/wp-content/plugins/themler-core/shortcodes/shortcodes-effects.php on line 302 Many thanks in advance. Angus
10 Comments
Support Team posted this 17 February 2023
Could you please try to update Themler version first to the latest v.559?
Hello, Could you please try to update Themler version first to the latest v.559? Sincerely, Nettie
moordigital
moordigital posted this 19 February 2023
Hi Nettie,
Thanks for getting back to me - I updated Themler to the latest version before updating PHP version.
That said, my Themler Core plugin is showing as version 0.2.22
Hi Nettie, Thanks for getting back to me - I updated Themler to the latest version before updating PHP version. That said, my Themler Core plugin is showing as version 0.2.22
SH707
SH707 posted this 19 February 2023
i have the same problem with version 0.2.22
Support Team posted this 20 February 2023
Could you please temporary switch to an older PHP version, open Themler theme and click Updates there? There the version should be 559.
Hello, Could you please temporary switch to an older PHP version, open Themler theme and click Updates there? There the version should be 559. Sincerely, Nettie
moordigital
moordigital posted this 21 February 2023
You bet - I currently have PHP version 7.4 but cannot see any option to update Themler?
moordigital
moordigital posted this 4 weeks ago
Hi, is there any further progress on this issue please?
What is the current Themler version for this theme? It can be checked in the top right corner in the Help section >> About.
Hello, What is the current Themler version for this theme? It can be checked in the top right corner in the Help section >> About. Sincerely, Nettie
moordigital
Hi Nettie,
It is showing Themler v.559
Hi Nettie, It is showing Themler v.559
This means the theme has already the latest version. Is the issue still reproducible if you now switch to PHP 8?
Hello, This means the theme has already the latest version. Is the issue still reproducible if you now switch to PHP 8? Sincerely, Nettie
moordigital
moordigital posted this 3 weeks ago
Looks like we are all good now. Many thanks.
