Some of my pages are showing lines of this error. My PHP Version is 8 With Joomla 3.10.11
What's the solution
Some of my pages are showing lines of this error. My PHP Version is 8 With Joomla 3.10.11 What's the solution
What's the solution
Some of my pages are showing lines of this error. My PHP Version is 8 With Joomla 3.10.11 What's the solutionSolved. Set the error reporting in Global Configuration to System Default.
Solved. Set the error reporting in Global Configuration to System Default.But this is no Solutions or Fix for this - only for the Frontend.
In the PHP Error Logs you have many Errors.
Have the same Problem.
You can Setting in Joomla "Errors none" and you have maybe also no Error Logs.
But this is not recommended
This need a Fix Update for PHP 8.x from Themler Developers
[edit]
maybe i have fix this.
in attach found the fixed shortcodes.php in /plugins/content/themlercontent/lib
but must try..
But this is no Solutions or Fix for this - only for the Frontend. In the PHP Error Logs you have many Errors. Have the same Problem. You can Setting in Joomla "Errors none" and you have maybe also no Error Logs. But this is not recommended **This need a Fix Update for PHP 8.x from Themler Developers** [edit] maybe i have fix this. in attach found the fixed shortcodes.php in /plugins/content/themlercontent/lib but must try..Last edited 04 October 2023 by @ITS
Themler, a program for developing and generating themes and templates for Linux-based geometry dash, has released a new version, Themler 567. Unfortunately, there isn't much documentation available regarding the changes or additions made to the 567 update.
Themler, a program for developing and generating themes and templates for Linux-based [geometry dash](https://geometrydash-online.io), has released a new version, Themler 567. Unfortunately, there isn't much documentation available regarding the changes or additions made to the 567 update.
