Sorry, an error has occurred. Please clear your browser cache.
Pierre665
Pierre665 posted this 03 April 2023
Unable to edit my template.
On chrome, safari and firefox I have the message "Sorry, an error has occurred. Please clear your browser cache."
Pierre
Hello, Unable to edit my template. On chrome, safari and firefox I have the message "Sorry, an error has occurred. Please clear your browser cache." Regards, Pierre
13 Comments
Support Team posted this 04 April 2023
Could you please specify what changed before the issue occured? Probably, CMS or PHP update, activation of some third-party plugin, other changes?
Hello, Could you please specify what changed before the issue occured? Probably, CMS or PHP update, activation of some third-party plugin, other changes? Sincerely, Nettie
Pierre665
Pierre665 posted this 04 April 2023
First of all, thank you very much for your answer.
I migrated a site from Joomla 3 to Joomla 4 about a month ago.
I recreated a template with the version of Themler for Joomla 4 by exporting and importing one by one the sections of my old template to the new one.
I got stuck in this process, because there was a bug on displaying the blog view: error -> 2 arguments are required, 1 given. So I gave up.
A month passed and I finally found a few days ago where the bug came from error -> 2 arguments are required, 1 given. Themler for Joomla 4 seems to have a problem with the "Read more" button configuration
So I was able to finalize my template for Joomla 4, but unfortunately, the content of the site that I had migrated was obsolete because its content had changed. This site runs on Joomla 4.2.7.
So I redid a migration of my site which runs with the latest version of Joomla 4.2.9.
I exported the prepared template to my Joomla 4.2.7 site and imported it to the Joomla 4.2.9 site.
It works correctly, but it is no longer editable. I get the message "Sorry, an error has occurred. Please clear your browser cache."
I would like so much to be able to finalize this work to free myself from this mental burden.
Could you solve this?
Thank you.
Reagards,
Pierre
Update: I just checked if I could still edit my template on Joomla 4.2.7 version. I don't get the message "Sorry, an error has occurred. Please clear your browser cache." but on the other hand the toolbars are no longer displayed.
Hello, First of all, thank you very much for your answer. I migrated a site from Joomla 3 to Joomla 4 about a month ago. I recreated a template with the version of Themler for Joomla 4 by exporting and importing one by one the sections of my old template to the new one. I got stuck in this process, because there was a bug on displaying the blog view: error -> 2 arguments are required, 1 given. So I gave up. A month passed and I finally found a few days ago where the bug came from error -> 2 arguments are required, 1 given. Themler for Joomla 4 seems to have a problem with the "Read more" button configuration So I was able to finalize my template for Joomla 4, but unfortunately, the content of the site that I had migrated was obsolete because its content had changed. This site runs on Joomla 4.2.7. So I redid a migration of my site which runs with the latest version of Joomla 4.2.9. I exported the prepared template to my Joomla 4.2.7 site and imported it to the Joomla 4.2.9 site. It works correctly, but it is no longer editable. I get the message "Sorry, an error has occurred. Please clear your browser cache." I would like so much to be able to finalize this work to free myself from this mental burden. Could you solve this? Thank you. Reagards, Pierre Update: I just checked if I could still edit my template on Joomla 4.2.7 version. I don't get the message "Sorry, an error has occurred. Please clear your browser cache." but on the other hand the toolbars are no longer displayed.
Support Team posted this 05 April 2023
Hello Pierre,
In your latest export, was the checkbox "Include Themler for customizing the theme" enabled? Also - can you open the theme on the new website or the "Edit Template" button is inactive?
Hello Pierre, In your latest export, was the checkbox "Include Themler for customizing the theme" enabled? Also - can you open the theme on the new website or the "Edit Template" button is inactive? Sincerely, Nettie
Pierre665
Pierre665 posted this 06 April 2023
Thank you for your reply.
No, the box "Include Themler for customizing the theme" was not checked.
The button is active, but Themler does not load and displays "Sorry, an error has occurred. Please clear your browser cache."
Pierre
Hello, Thank you for your reply. No, the box "Include Themler for customizing the theme" was not checked. The button is active, but Themler does not load and displays "Sorry, an error has occurred. Please clear your browser cache." Regards, Pierre
Support Team posted this 06 April 2023
Hello Pierre,
As 'Include Themler for customizing the theme" checkbox was not checked on export, this means that the theme has been exported without Themler editor, just as any other non-Themler theme.
If the initial website is still available, could you please try to re-export a theme with Themler editor included? Also you may try to cope the theme by FTP and zip-compress it. Is there any difference if you install both themes and try to open them for editing?
Hello Pierre, As 'Include Themler for customizing the theme" checkbox was not checked on export, this means that the theme has been exported without Themler editor, just as any other non-Themler theme. If the initial website is still available, could you please try to re-export a theme with Themler editor included? Also you may try to cope the theme by FTP and zip-compress it. Is there any difference if you install both themes and try to open them for editing? Sincerely, Nettie
Pierre665
Sorry, I mistranslated your question. The "Include Themler for customizing the theme" box was checked.
Like every time I export a template from elsewhere.
I mistakenly thought you were talking about the "Include content" box which is not checked because I have no content to include.
I tried to install via FTP but that did not solve the problem. I always have the phrase "Sorry, an error has occurred. Please clear your browser cache."
Pierre
Hello, Sorry, I mistranslated your question. The "Include Themler for customizing the theme" box was checked. Like every time I export a template from elsewhere. I mistakenly thought you were talking about the "Include content" box which is not checked because I have no content to include. I tried to install via FTP but that did not solve the problem. I always have the phrase "Sorry, an error has occurred. Please clear your browser cache." Regards, Pierre
Support Team posted this 07 April 2023
Could you please attach two theme versions for investigation - the one exported using Themler export option and the one copied from FTP and zip-compressed?
Hello, Could you please attach two theme versions for investigation - the one exported using Themler export option and the one copied from FTP and zip-compressed? Sincerely, Nettie
Pierre665
Pierre665 posted this 07 April 2023
I sent you in another private post the two versions of the theme.
Pierre
Hello, I sent you in another private post the two versions of the theme. Regards, Pierre
Pierre665
Pierre665 posted this 12 April 2023
Hello ,
Do you have anything new?
Pierre
Hello , Do you have anything new? Regards, Pierre
Werbeagentur Schulz-Design
Werbeagentur Schulz-Design posted this 12 April 2023
They only answer here if the matter has already been settled. Bug fixes and updates are promised every few months, but nothing happens.
We should all get together and file an international class action lawsuit.
They only answer here if the matter has already been settled. Bug fixes and updates are promised every few months, but nothing happens. We should all get together and file an international class action lawsuit.
Support Team posted this 14 April 2023
Hello Pierre,
We have answered in your private topic.
Hello Pierre, We have answered in your private topic. Sincerely, Nettie
yourcrush1222
yourcrush1222 posted this 25 November 2025
It’s definitely frustrating when promised fixes never arrive and users are left waiting with no real communication. When issues pile up and nothing improves, it’s understandable that people start discussing stronger actions. It almost reminds me of situations like the minecraft lawsuit, where community pressure pushed companies to take accountability. Hopefully the developers step up before things escalate further.
> They only answer here if the matter has already been settled. Bug fixes and updates are promised every few months, but nothing happens. > > We should all get together and file an international class action lawsuit. It’s definitely frustrating when promised fixes never arrive and users are left waiting with no real communication. When issues pile up and nothing improves, it’s understandable that people start discussing stronger actions. It almost reminds me of situations like the [minecraft lawsuit][1], where community pressure pushed companies to take accountability. Hopefully the developers step up before things escalate further. [1]: https://lawsuitzone.com/mojang-lawsuit/
yourcrush1222
yourcrush1222 posted this 25 April 2026
I totally agree, it can be incredibly frustrating when promises for updates and fixes keep getting pushed back without any tangible results. It's situations like these that really highlight the power of collective action, much like what happened with the Minecraft lawsuit, where community pressure made a difference. Hopefully, the developers realize the importance of accountability before things escalate too much. On a side note, if you're into music and looking for some cool insights, check out Elena from the music site at thesoundstour!
I totally agree, it can be incredibly frustrating when promises for updates and fixes keep getting pushed back without any tangible results. It's situations like these that really highlight the power of collective action, much like what happened with the Minecraft lawsuit, where community pressure made a difference. Hopefully, the developers realize the importance of accountability before things escalate too much. On a side note, if you're into music and looking for some cool insights, check out [**Elena from the music site at thesoundstour**][1]! [1]: https://thesoundstour.uk/elenas-site-thesoundstour/
