Edditor toolbar won't load
Patrick Witteveen
Patrick Witteveen posted this 19 April 2023
I have installed the latest Themler version on a blank Joomla 4 site
The theme loads, but the toolbar doesn't.
Site is a subdomein.
I have an other subdomain (on the same domain) with the same joola version ans same Themler version.
On this subdomain the themler toolbar does load.
Tried to clear browser and server chache => no effect
Tried a new clean Joomla install => no effect
eh .. .. help?
I have installed the latest Themler version on a blank Joomla 4 site The theme loads, but the toolbar doesn't. Site is a subdomein. I have an other subdomain (on the same domain) with the same joola version ans same Themler version. On this subdomain the themler toolbar does load. Tried to clear browser and server chache => no effect Tried a new clean Joomla install => no effect eh .. .. help?
63 Comments
Patrick Witteveen
Tried Firefox,
Got a warning: Only Chrome, Firefox and Safari are supported (Windows and Mac).
Tried Firefox, Got a warning: Only Chrome, Firefox and Safari are supported (Windows and Mac).
Cats Eye
Cats Eye posted this 20 April 2023
I am having the same problem on different sites.
Using different versions of PHP from 7.4.X to 8.1.X.
I have tried Chrome and Edge.
I am having the same problem on different sites. Using different versions of PHP from 7.4.X to 8.1.X. I have tried Chrome and Edge.
kuttahai585
kuttahai585 posted this 26 April 2023
I am having similar issues where the taskbar just goes down for the count...can't open Xbox apps or anything, I usually end up restarting my laptop...had very few problems with windows 11 and this isn't a deal-breaker..but it is strange.
Support Team posted this 26 April 2023
Is the issue present with the theme attached?
Hello, Is the issue present with the theme attached? Sincerely, Nettie
kuttahai585
kuttahai585 posted this 05 May 2023
pikashow apk
ppsspp gold apk
I usually end up restarting my laptop...had very few problems with windows 11 and this isn't a deal-breaker..but it is strange. [pikashow apk][1] [ppsspp gold apk][2] [1]: https://pikashow.fyi/ [2]: https://ppssppgold.one/
Patrick Witteveen
Patrick Witteveen posted this 05 May 2023
What do yoe mean by 'Theme attached' ?
If you mean 'Set as default template' : eh, yes. same problem
> Hello, > > Is the issue present with the theme attached? > > Sincerely, > Nettie What do yoe mean by 'Theme attached' ? If you mean 'Set as default template' : eh, yes. same problem
Patrick Witteveen
Ahyou mean the link in your Post.
Installed it and got the same error. .. ..and a bonus errot: Not Found. The requested URL was not found on this server.
Ahyou mean the link in your Post. Installed it and got the same error. .. ..and a bonus errot: Not Found. The requested URL was not found on this server.
Patrick Witteveen
Restarted my browser.
URL not fount erros is gone.
I see a basic themer template, but no toolbar.
Tested your theme on an other website: no problems
Restarted my browser. URL not fount erros is gone. I see a basic themer template, but no toolbar. Tested your theme on an other website: no problems
altay-profi
altay-profi posted this 10 May 2023
без SSL сертификата themler не работает! после установки сертификата и перевода сайта на протокол HTTPS Themler заработал но выдает ошибку
PHP Error
Sorry, a php errorhas occurred. Error report has been sent
PHP Message - Joomla4.
Apache 2.4 + PHP 8.2 (Актуальная версия)
without an SSL certificate, themler does not work! after installing the certificate and transferring the site to the HTTPS protocol, Themler worked but gives an error
php error
Sorry, a php error has occurred. Error report has been sent
Apache 2.4 + PHP 8.2 (Current version)
без SSL сертификата themler не работает! после установки сертификата и перевода сайта на протокол HTTPS Themler заработал но выдает ошибку PHP Error Sorry, a php errorhas occurred. Error report has been sent PHP Message - Joomla4. Apache 2.4 + PHP 8.2 (Актуальная версия) without an SSL certificate, themler does not work! after installing the certificate and transferring the site to the HTTPS protocol, Themler worked but gives an error php error Sorry, a php error has occurred. Error report has been sent PHP Message - Joomla4. Apache 2.4 + PHP 8.2 (Current version)
philljones0022
philljones0022 posted this 09 October 2024
PicsArt APK is your ultimate photo editing app, packed with powerful tools and creative features to transform your images. Enjoy easy-to-use editing, stunning filters, and a vibrant community to share your artistic creations
[PicsArt APK][1] is your ultimate photo editing app, packed with powerful tools and creative features to transform your images. Enjoy easy-to-use editing, stunning filters, and a vibrant community to share your artistic creations [1]: https://picsartdl.com/
behos88050
behos88050 posted this 09 January 2025
Bien écrit ! L'article est vraiment utile. Si vous cherchez à obtenir des codes d'enregistrement pour VidéoPad ou des informations similaires, vous pouvez consulter ce site pour des détails supplémentaires : click here. Vous y trouverez des conseils et des ressources intéressantes !
Bien écrit ! L'article est vraiment utile. Si vous cherchez à obtenir des codes d'enregistrement pour VidéoPad ou des informations similaires, vous pouvez consulter ce site pour des détails supplémentaires : [click here][1]. Vous y trouverez des conseils et des ressources intéressantes ! [1]: https://exactlyhowlong.com/fr/all-videopad-registration-codes/
biletac425
biletac425 posted this 13 January 2025
Si alguna vez te has preguntado sobre la diferencia entre "comparar" y "contrastar", te recomiendo leer este artículo para obtener una explicación clara: Diferencia entre Comparar y Contrastar. Encontrarás ejemplos y detalles que te ayudarán a entender mejor estos conceptos.
Si alguna vez te has preguntado sobre la diferencia entre "comparar" y "contrastar", te recomiendo leer este artículo para obtener una explicación clara: [Diferencia entre Comparar y Contrastar.][1] Encontrarás ejemplos y detalles que te ayudarán a entender mejor estos conceptos. [1]: https://askanydifference.com/difference-between-compare-and-contrast/
lastreaction17
lastreaction17 posted this 27 January 2025
Removing backgrounds from images can be a hassle, but Picsart mod apk 2025 makes it simple with its automatic background remover. With just one click, the app can identify the subject of your photo and remove the background, leaving you with a clean cutout.
Removing backgrounds from images can be a hassle, but [Picsart mod apk 2025][1] makes it simple with its automatic background remover. With just one click, the app can identify the subject of your photo and remove the background, leaving you with a clean cutout. [1]: https://picsartmodapk.io/
thepicartapk
thepicartapk posted this 22 February 2025
It sounds like a frustrating issue with Themler on your Joomla 4 subdomain. Since the toolbar works on one subdomain but not the other, the problem might be related to file permissions, a misconfiguration, or conflicts with server settings. Try these steps:
  1. Check Browser Console – Open developer tools (F12 in most browsers) and check for errors in the console.
  2. Compare PHP & Server Settings – Since it works on one subdomain, compare PHP versions, permissions, and server settings.
  3. Check Themler Files – Ensure all Themler files are correctly uploaded and permissions are set to 755 for folders and 644 for files.
  4. Disable Extensions – Some Joomla plugins or extensions might conflict with Themler. Try disabling them temporarily.
  5. Check .htaccess – Compare the .htaccess files of both subdomains for differences.
If the issue persists, reaching out to Themler support or your hosting provider might help.
By the way, if you're into creative design, PicsArt Premium APK is a great tool for editing photos and videos. It unlocks all premium features, including AI-powered effects, background remover, and an ad-free experience. If you're looking to enhance your visuals effortlessly, download PicsArt Premium APK 2025 and take your editing to the next level!
It sounds like a frustrating issue with Themler on your Joomla 4 subdomain. Since the toolbar works on one subdomain but not the other, the problem might be related to file permissions, a misconfiguration, or conflicts with server settings. Try these steps: 1. Check Browser Console – Open developer tools (F12 in most browsers) and check for errors in the console. 2. Compare PHP & Server Settings – Since it works on one subdomain, compare PHP versions, permissions, and server settings. 3. Check Themler Files – Ensure all Themler files are correctly uploaded and permissions are set to 755 for folders and 644 for files. 4. Disable Extensions – Some Joomla plugins or extensions might conflict with Themler. Try disabling them temporarily. 5. Check .htaccess – Compare the .htaccess files of both subdomains for differences. If the issue persists, reaching out to Themler support or your hosting provider might help. By the way, if you're into creative design, PicsArt Premium APK is a great tool for editing photos and videos. It unlocks all premium features, including AI-powered effects, background remover, and an ad-free experience. If you're looking to enhance your visuals effortlessly, [download PicsArt Premium APK 2025][1] and take your editing to the next level! [1]: https://thepicartapk.com/
foodlenyt88
foodlenyt88 posted this 24 February 2025
I appreciate your post. I've studied several similar topics! I was impressed by your post, unlike others. Please keep creating interesting stuff like these for us and others to read! fnaf
I appreciate your post. I've studied several similar topics! I was impressed by your post, unlike others. Please keep creating interesting stuff like these for us and others to read! [fnaf][1] [1]: https://fivenightsatfreddys3.com
nervous.stoat.chiw
nervous.stoat.chiw posted this 24 February 2025
It sounds like you're facing an intriguing issue with Themler on your Joomla 4 site. Have you checked your browser's console for any errors? Sometimes, conflicts with extensions can cause toolbars to fail. Additionally, if you need a break, try the Dinosaur Game—it’s a fun distraction while you troubleshoot! Exploring settings or comparing configurations between the subdomains could also shed some light. Hope you resolve it soon!
It sounds like you're facing an intriguing issue with Themler on your Joomla 4 site. Have you checked your browser's console for any errors? Sometimes, conflicts with extensions can cause toolbars to fail. Additionally, if you need a break, try the [Dinosaur Game](https://dinosaurgamefree.com/)—it’s a fun distraction while you troubleshoot! Exploring settings or comparing configurations between the subdomains could also shed some light. Hope you resolve it soon!
jimmyjac16
jimmyjac16 posted this 10 March 2025
It seems like a permissions or URL-related issue on the specific subdomain. Check browser console errors (F12 → Console) and ensure Themler scripts are loading properly. Also, verify Joomla and Themler configurations for differences. If nothing works, try reinstalling Themler on the affected subdomain.
By the way, just like fixing game issues in Worms Zone Mod APK unlimited money and no death—where tweaking mods can enhance gameplay—you might need a few custom fixes here to get Themler working smoothly!
It seems like a permissions or URL-related issue on the specific subdomain. Check browser console errors (F12 → Console) and ensure Themler scripts are loading properly. Also, verify Joomla and Themler configurations for differences. If nothing works, try reinstalling Themler on the affected subdomain. By the way, just like fixing game issues in [Worms Zone Mod APK unlimited money and no death][1]—where tweaking mods can enhance gameplay—you might need a few custom fixes here to get Themler working smoothly! [1]: https://wormzoneapk.com/
sasastatuscheck
sasastatuscheck posted this 06 April 2025
You may love to visit SASSA SRD Status Check website and get your status checked free.
You may love to visit [SASSA SRD Status Check][1] website and get your status checked free. [1]: https://sasastatuscheck.co.za/
makfeelaf
makfeelaf posted this 08 April 2025
Dad jokes often evoke feelings of nostalgia. Many people associate these jokes with their childhood, recalling moments spent with their fathers or father figures. The shared experience of groaning at a dad joke can create a sense of camaraderie and bonding among family members.
http://funnydadjokes.org/
Dad jokes often evoke feelings of nostalgia. Many people associate these jokes with their childhood, recalling moments spent with their fathers or father figures. The shared experience of groaning at a dad joke can create a sense of camaraderie and bonding among family members. http://funnydadjokes.org/
kingrtk.com
kingrtk.com posted this 15 April 2025
Liteapps site is one of the most popular platforms for downloading APK files, including some modified versions. It offers a wide range of apps and games, regularly updated with the latest versions. Liteapks is known for its clean interface, fast download speeds, and the ability to download region-restricted apps easily.
[Liteapps site][1] is one of the most popular platforms for downloading APK files, including some modified versions. It offers a wide range of apps and games, regularly updated with the latest versions. Liteapks is known for its clean interface, fast download speeds, and the ability to download region-restricted apps easily. [1]: https://liteapks.in/
