I understand that you are facing an issue with Themler Beta while using Joomla 4. It seems like you are unable to edit each page individually with Themler because the "Article" section is missing. You have tried using "Post," but the same content is displayed on all pages, which is not what you want.
To resolve this issue, you can try the following steps:
Check if the Themler Beta version you are using is compatible with Joomla 4. If it is not compatible, then you may need to use a different version of Themler that is compatible with Joomla 4.
Try using the "Custom HTML" module in Joomla 4 to add the Themler template to each page individually. This will allow you to customize the content for each page.
If the above solutions do not work, you can consider using a different Joomla template that is compatible with Joomla 4 and allows you to edit each page individually.
I hope this helps. Let me know if you have any further questions.
