Joomla 4 - Blank template starting with "Not Found"
d.vangelder
d.vangelder posted this 18 May 2023
I have a clean Joomla 4.3.1 installed.
A new blank Joomla 4 theme installed.
The version of the theme is 544.
When I want to edit the template there is shortly a themler logo visible and then a Not Found message appears.
The frontpage shows the default Joomla Template form Themler.
Because it is a test i do not have a https certificat installed.
Someone has the same issue?
Danny
Hi, I have a clean Joomla 4.3.1 installed. A new blank Joomla 4 theme installed. The version of the theme is 544. When I want to edit the template there is shortly a themler logo visible and then a **Not Found** message appears. The frontpage shows the default Joomla Template form Themler. Because it is a test i do not have a https certificat installed. Someone has the same issue? Danny
lennyburkdoll
lennyburkdoll posted this 18 May 2023
It seems that there is an issue with editing the template in Joomla 4.3.1 using the Themler theme. A "Not Found" message appears after a brief Themler logo display. Check if others have encountered the same problem for potential solutions.
Best regard,
PFMLogin.com
Hello, It seems that there is an issue with editing the template in Joomla 4.3.1 using the Themler theme. A "Not Found" message appears after a brief Themler logo display. Check if others have encountered the same problem for potential solutions. Best regard, [PFMLogin.com][1] [1]: https://www.pfmlogin.org/
ra.m.onfergusonw55005
ra.m.onfergusonw55005 posted this 23 June 2023
As i know ensure that the blank template files are placed in the correct location within your Joomla installation. Templates should be located in the /templates directory or make sure that the template files are fully uploaded to your server. Check that all the necessary files are present, including the template's XML file, index.php, and any other required files because sometimes, caching issues can cause problems with template loading. Go to the Joomla administrator area, navigate to "System" → "Clear Cache" and clear both the Joomla cache and the browser cache.
phanthanhhaikdb33
phanthanhhaikdb33 posted this 24 June 2023
Clear your browser cache: Sometimes, cached files can interfere with the loading of the template editor. Clear your browser cache and try accessing the template editor again.
Check file and folder permissions: Ensure that the necessary files and folders related to the template and the Themler extension have the correct permissions set. Incorrect permissions can prevent proper functioning.
Update the Themler extension: Make sure you have the latest version of the Themler extension installed. Check for any available updates and apply them if necessary.
UPSers Login
Disable conflicting extensions: Disable any other extensions that may be conflicting with the Themler extension. Temporarily disable all non-essential extensions and try accessing the template editor again.
Check error logs: Look for any error logs or error messages related to the Themler extension or the template editor. This can provide insights into the specific issue causing the "Not Found" message.
Clear your browser cache: Sometimes, cached files can interfere with the loading of the template editor. Clear your browser cache and try accessing the template editor again. Check file and folder permissions: Ensure that the necessary files and folders related to the template and the Themler extension have the correct permissions set. Incorrect permissions can prevent proper functioning. Update the Themler extension: Make sure you have the latest version of the Themler extension installed. Check for any available updates and apply them if necessary. [UPSers Login][1] Disable conflicting extensions: Disable any other extensions that may be conflicting with the Themler extension. Temporarily disable all non-essential extensions and try accessing the template editor again. Check error logs: Look for any error logs or error messages related to the Themler extension or the template editor. This can provide insights into the specific issue causing the "Not Found" message. [1]: https://www.upsers.app/
ra.m.onfergusonw55005 posted this 26 June 2023
Thanks for let me share this !! TargetPayandBenefits
> As i know ensure that the blank template files are placed in the correct location within your Joomla installation. Templates should be located in the /templates directory or make sure that the template files are fully uploaded to your server. Check that all the necessary files are present, including the template's XML file, index.php, and any other required files because sometimes, caching issues can cause problems with template loading. Go to the Joomla administrator area, navigate to "System" → "Clear Cache" and clear both the Joomla cache and the browser cache. > As i know ensure that the blank template files are placed in the correct location within your Joomla installation. Templates should be located in the /templates directory or make sure that the template files are fully uploaded to your server. Check that all the necessary files are present, including the template's XML file, index.php, and any other required files because sometimes, caching issues can cause problems with template loading. Go to the Joomla administrator area, navigate to "System" → "Clear Cache" and clear both the Joomla cache and the browser cache. Thanks for let me share this !! [TargetPayandBenefits][1] [1]: https://www.targetpayandbenefits.review/
maskeryulia
maskeryulia posted this 28 June 2023
amanda the adventurer potential need for something piques Riley's interest, and he becomes fixated on discovering what it is.
[amanda the adventurer][1] potential need for something piques Riley's interest, and he becomes fixated on discovering what it is. [1]: https://amandatheadventurer.io/
waderatke608
waderatke608 posted this 20 May 2024
Using the Themler theme to edit the Joomla 4.3.1 template looks to be problematic. A short Themler logo display is followed by a "Not Found" notice. whether you are looking for a solution to an issue, see whether anyone else has had it. geometry dash
Using the Themler theme to edit the Joomla 4.3.1 template looks to be problematic. A short Themler logo display is followed by a "Not Found" notice. whether you are looking for a solution to an issue, see whether anyone else has had it. [geometry dash][1] [1]: https://geometrygame.io/
AnthonyRichi
AnthonyRichi posted this 18 July 2024
Ensure your server's PHP version is compatible with a little to the left Joomla 4.3.1 and Themler; Joomla 4 requires PHP 7.2.5 or higher.
Ensure your server's PHP version is compatible with [a little to the left][1] Joomla 4.3.1 and Themler; Joomla 4 requires PHP 7.2.5 or higher. [1]: https://alittletotheleftgames.com
