error after uploading theme to joomla
aidelakreyi
aidelakreyi posted this 20 August 2023
hello everyone
after i upload theme to joomla 4 i get error ( Attempted to call an undefined method named "isAdmin" of class "Joomla\CMS\Application\SiteApplication".)
you can see the error clearly in the attached screenshot
hello everyone after i upload theme to joomla 4 i get error ( Attempted to call an undefined method named "isAdmin" of class "Joomla\CMS\Application\SiteApplication".) you can see the error clearly in the attached screenshot
78 Comments
aidelakreyi
aidelakreyi posted this 21 August 2023
no answer ??
no answer ??
trankhoaitayto012
trankhoaitayto012 posted this 24 August 2023
Make sure that the theme you've uploaded is compatible with Joomla 4. Some themes might be designed for older Joomla versions and may not work correctly with Joomla 4. Ensure that your server is running a compatible version of PHP for Joomla 4. Joomla 4 requires PHP 7.2 or higher. Make sure you're not using an outdated PHP version. Sometimes, conflicts with third-party extensions can cause errors. Try temporarily disabling any installed extensions and see if the issue persists.
aidelakreyi
aidelakreyi posted this 24 August 2023
I just put blank joomla 4 template from themler and I upload to the system so I got that error and my php version is 8.0
trankhoaitayto012
trankhoaitayto012 posted this 25 August 2023
It seems like you're encountering an error after uploading a blank Joomla 4 template from Themler, and you're using PHP 8.0. PaybyPlateMa Invoice Upgrading to Joomla 4 is a significant step, and compatibility issues might arise with extensions, templates, and the PHP version you're using.
> Make sure that the theme you've uploaded is compatible with Joomla 4. Some themes might be designed for older Joomla versions and may not work correctly with Joomla 4. Ensure that your server is running a compatible version of PHP for Joomla 4. Joomla 4 requires PHP 7.2 or higher. Make sure you're not using an outdated PHP version. Sometimes, conflicts with third-party extensions can cause errors. Try temporarily disabling any installed extensions and see if the issue persists. It seems like you're encountering an error after uploading a blank Joomla 4 template from Themler, and you're using PHP 8.0. [PaybyPlateMa Invoice][1] Upgrading to Joomla 4 is a significant step, and compatibility issues might arise with extensions, templates, and the PHP version you're using. [1]: https://www.paybyplatema.ltd/
aidelakreyi
aidelakreyi posted this 04 September 2023
so what i need to do to sole such problem ?
SionCO
SionCO posted this 04 September 2023
Stop using Themler, it doesn't work with Joomla 4, and support has no interest in making it work. I did a fresh installation of Joomla 4 and imported a new template just downloaded and still I have an error when activating the menu, there is no way to put a menu unless you put a custom module with your links as a plain text, nothing functional . Themler's attitude towards his clients is unfortunate.
wheelworks
wheelworks posted this 21 November 2023
happy wheels Verify that the PHP version on your server is appropriate for Joomla 4. PHP 7.2 or later is required for Joomla 4. Verify that you are not running an out-of-date PHP version. If the issue still exists, try momentarily disabling any installed extensions.
[happy wheels][1] Verify that the PHP version on your server is appropriate for Joomla 4. PHP 7.2 or later is required for Joomla 4. Verify that you are not running an out-of-date PHP version. If the issue still exists, try momentarily disabling any installed extensions. [1]: https://happy-wheels.co
hanavi110795
hanavi110795 posted this 30 November 2023
I'd want to applaud you for sharing such useful information skribbl io
I'd want to applaud you for sharing such useful information [skribbl io][1] [1]: https://skribblio.online
angelaesper43
angelaesper43 posted this 07 May 2024
Consider checking compatibility of the theme with Joomla 4, updating granny sexdoll extensions, or consulting Joomla forums for assistance.
Consider checking compatibility of the theme with Joomla 4, updating [granny sexdoll][1] extensions, or consulting Joomla forums for assistance. [1]: https://www.sexdolltech.com/product-category/shop-by-categories/sex-doll-genre/milf-sex-dolls/
toniafodakuta
toniafodakuta posted this 15 May 2024
Attention, tech enthusiasts! I'm thrilled to unveil my latest tech discovery – a refurbished gadget acquired with precision and handled smartly. This device, though pre-owned, shines in performance and serves as a reminder of the importance of making educated decisions in our tech pursuits. Let's proceed with intellect and a commitment to choosing smartly.
Attention, tech enthusiasts! I'm thrilled to unveil my latest tech discovery – a refurbished gadget acquired with precision and handled smartly. This device, though pre-owned, shines in performance and serves as a reminder of the importance of making educated decisions in our tech pursuits. Let's proceed with intellect and a commitment to [choosing smartly][1]. [1]: https://smartimobile.com
voipturks
voipturks posted this 19 May 2024
Attention! Would you like to visit Turkey's best quality electronic cigarette site?
Türkiyenin en kaliteli elektronik sigara sitesini ziyaret etmek istermisiniz ?
Attention! Would you like to visit Turkey's best quality electronic cigarette site? Türkiyenin en kaliteli [elektronik sigara][1] sitesini ziyaret etmek istermisiniz ? [1]: https://buharkeyf01.com/elektronik-sigara-satin-al
teraboxmodorg
teraboxmodorg posted this 07 July 2024
Terabox MOD APK is a rare and latest management of the files in the cloud storage, as you know how important they are! It lets you store your files in the cloud
[Terabox MOD][1] APK is a rare and latest management of the files in the cloud storage, as you know how important they are! It lets you store your files in the cloud [1]: https://teraboxmod.org
teraboxmodorg
teraboxmodorg posted this 08 July 2024
Snap Insta is a tool for downloading Instagram videos, allowing the download of high-quality 1080p, 2k, 4k, 8k videos from Instagram (IG) online.
[Snap Insta][1] is a tool for downloading Instagram videos, allowing the download of high-quality 1080p, 2k, 4k, 8k videos from Instagram (IG) online. [1]: https://snapinstagram.net
happyriderreviews.com
happyriderreviews.com posted this 09 July 2024
Some time facing problem on wordpress iptv yolo
Some time facing problem on wordpress [iptv yolo][1] [1]: https://iptvyolo.com/
fisije9354
fisije9354 posted this 24 July 2024
Indian Bike Driving 3D are most popular game in india community because this game inspayred by GTA San Andreas. https://indianbikedriving3d.in/
fisije9354
Your are creater then you definitely need large amount of store. So you try this Terabox Mod Apk app because Terabox Mod Apk officially released version. Terabox Mod Apk provide 1Tb storage, ad free experience, premium features and more
https://teraboxapkmod.in/
Your are creater then you definitely need large amount of store. So you try this Terabox Mod Apk app because Terabox Mod Apk officially released version. Terabox Mod Apk provide 1Tb storage, ad free experience, premium features and more https://teraboxapkmod.in/
esther598smith
esther598smith posted this 30 July 2024
Check Theme Compatibility: Ensure that the theme you’ve uploaded is compatible with Joomla 4. Some older themes might not work seamlessly with the latest version. Official Site
Clear Cache: Clear your Joomla cache to ensure that any outdated data isn’t causing conflicts. You can do this by navigating to “System” > “Clear Cache” in your Joomla admin panel.
Review Extensions: Disable any third-party extensions or plugins temporarily and see if the error persists. Sometimes, incompatible extensions can lead to such issues.
Check Overrides: If you’ve made any template overrides, review them for any custom code related to the “isAdmin” method. Incorrect overrides can cause unexpected behavior.
Update Extensions and Joomla: Make sure that all your extensions (including the theme) are up to date. Also, ensure that you’re using the latest version of Joomla .
Debug Mode: Enable Joomla’s debug mode to get more detailed error information. You can do this by editing your configuration.php file and setting public $debug = true;.
Inspect the Code: Look into the theme files and check if there’s any direct call to the “isAdmin” method. If so, ensure it’s correctly defined.
Hello, Check Theme Compatibility: Ensure that the theme you’ve uploaded is compatible with Joomla 4. Some older themes might not work seamlessly with the latest version. [Official Site][1] Clear Cache: Clear your Joomla cache to ensure that any outdated data isn’t causing conflicts. You can do this by navigating to “System” > “Clear Cache” in your Joomla admin panel. Review Extensions: Disable any third-party extensions or plugins temporarily and see if the error persists. Sometimes, incompatible extensions can lead to such issues. Check Overrides: If you’ve made any template overrides, review them for any custom code related to the “isAdmin” method. Incorrect overrides can cause unexpected behavior. Update Extensions and Joomla: Make sure that all your extensions (including the theme) are up to date. Also, ensure that you’re using the latest version of Joomla . Debug Mode: Enable Joomla’s debug mode to get more detailed error information. You can do this by editing your configuration.php file and setting public $debug = true;. Inspect the Code: Look into the theme files and check if there’s any direct call to the “isAdmin” method. If so, ensure it’s correctly defined. [1]: https://www.mycenturahealth.com.co
contentc697
contentc697 posted this 14 September 2024
Loklok APK has become the preferred choice of its users due to its unconventional features and huge content library. It facilitates users with massive content from around the globe without charging any subscription fee. It also facilitates users with its offline and online watching experience. Unlike other streaming apps, it does not charge heavy monthly or weekly subscriptions and has no daily streaming limit. loklok apk download
Loklok APK has become the preferred choice of its users due to its unconventional features and huge content library. It facilitates users with massive content from around the globe without charging any subscription fee. It also facilitates users with its offline and online watching experience. Unlike other streaming apps, it does not charge heavy monthly or weekly subscriptions and has no daily streaming limit. [loklok apk download][1] [1]: https://lokapk.com/
Abbas Khan
Abbas Khan posted this 15 September 2024
There are different types of activities. Basic cartoon characters and fun games are for kids to understand the basic concepts such as addition, subtraction, multiplication and division on geometryspot. Moreover, to learn SSS, SAS, AAS, ASA, complex theorems, trigonometric formulas and equations and many other advanced concepts. Children can learn and build 3D shapes with toothpicks and pencils. Don’t wait and pay a visit at our platform.
There are different types of activities. Basic cartoon characters and fun games are for kids to understand the basic concepts such as addition, subtraction, multiplication and division on [geometryspot][1]. Moreover, to learn SSS, SAS, AAS, ASA, complex theorems, trigonometric formulas and equations and many other advanced concepts. Children can learn and build 3D shapes with toothpicks and pencils. Don’t wait and pay a visit at our platform. [1]: https://geometricspot.com/activities/
varunintern23
varunintern23 posted this 16 September 2024
ShikshaDe is an educational e-learning platform offering comprehensive information about colleges, courses, exams, and career guidance in India. It assists students in making informed decisions about their educational pursuits through valuable resources and personalized guidance.
ShikshaDe is an educational **[e-learning][1]** platform offering comprehensive information about colleges, courses, exams, and career guidance in India. It assists students in making informed decisions about their educational pursuits through valuable resources and personalized guidance. [1]: https://shikshade.com/
