Hello friends!
You can import the Themler a theme that was created in Artisteer (artx)?
Thank you!
Hello friends! You can import the Themler a theme that was created in Artisteer (artx)? Thank you!
Hello friends!
Thank you!
Hello friends! You can import the Themler a theme that was created in Artisteer (artx)? Thank you!Yes, choose export, then themeler then pick Wordpress or joomla these are the only 2 supported at the moment.
X5tuts
Yes, choose export, then themeler then pick Wordpress or joomla these are the only 2 supported at the moment. X5tutsI'm not getting, are you sure you can import a Artisteer file into the Themler?
Thank you!
I'm not getting, are you sure you can import a Artisteer file into the Themler? Thank you!Yes, choose export, then themeler then pick Wordpress or joomla these are the only 2 supported at the moment.
X5tuts
Hi there I am trying to work this out also I have Artisteer 4.3 standard and under export there is no Themler
> Yes, choose export, then themeler then pick Wordpress or joomla these are the only 2 supported at the moment. > > X5tuts Hi there I am trying to work this out also I have Artisteer 4.3 standard and under export there is no ThemlerDownload the artisteer update from here https://answers.themler.com/questions/19108/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 for themeler support.
X5tuts
Download the artisteer update from here https://answers.themler.com/questions/19108/themler-v1-0-59-desktop-installation-updated-and-joomla-artx-support-added-10-aug-2015 for themeler support. X5tutsWhen I try import Artisteer theme (Wordpress) to Themler:
Import Failed!
Only Themler Themes are supported.
When I try import Artisteer theme (Wordpress) to Themler: Import Failed! Only Themler Themes are supported. :(Ok bear with me and I will look into this on my themeler version.
Ok bear with me and I will look into this on my themeler version.Oh, now I understand. What happens is that although it is not available in Artisteer site, a new version of Artisteer (4.3.0.60858) that exports to Themler for two CMS: Joomla and Wordpress.
File to download provided by support team: http://files4.artisteer.com/Artisteer.4.3.0.60858.exe
Thank you, now works perfectly :)
Oh, now I understand. What happens is that although it is not available in Artisteer site, a new version of Artisteer (4.3.0.60858) that exports to Themler for two CMS: Joomla and Wordpress. File to download provided by support team: http://files4.artisteer.com/Artisteer.4.3.0.60858.exe Thank you, now works perfectly :)Glad you got it working eventually.
Enjoy
X5tuts
Glad you got it working eventually. Enjoy X5tutsIs there any attempt to facilitate export from artisteer to themeler for drupal created themes. Currently is only shows Joomla and WordPress.
Is there any attempt to facilitate export from artisteer to themeler for drupal created themes. Currently is only shows Joomla and WordPress.Hello,
Currently the latest Artisteer update allows to export to Themler for Wordpress, Joomla and HTML:
It is not possible to export to Themler for Drupal at the moment. We will add your suggestion to our Wishlist.
Sincerel,y
It is not possible to export to Themler for Drupal at the moment. We will add your suggestion to our Wishlist.Sincerel,y
Thank you for your help.
In fact I was sorry for team "theoretically" have discontinued Artisteer, because I did not like one bit of Themler. Although more resources, it was heavy, slow, very bad. (translated by Google from Portuguese)
> Hello, > > Currently the latest Artisteer update allows to export to Themler for Wordpress, Joomla and HTML: > www.artisteer.com/media/p4/files/Artisteer.4.3.0.60928.exe > It is not possible to export to Themler for Drupal at the moment. We will add your suggestion to our Wishlist. > > Sincerel,y > Nettie, > BillionDigital Team Thank you for your help. In fact I was sorry for team "theoretically" have discontinued Artisteer, because I did not like one bit of Themler. Although more resources, it was heavy, slow, very bad. (translated by Google from Portuguese)Hi,
If you have any issues or questions regarding Themler, feel free to contact us.
When can we export artx file to Themler and create a DNN theme from it? Please advise. Thanks!
When can we export artx file to Themler and create a DNN theme from it? Please advise. Thanks!Hi,
We do not expect such option.
But this is available for other CMS in Themler.
Export .artx to themler and create WP themes etc.
Still we can not export the content as separate content to DNN and the content is also on the skin. We can not expect it as a skin and it is like an HTML file which is loading in a DNN site.
Please, complete this first since this is the most important thing for DNN with your product.
I bought your product. But still I didn't create any commercial Skin because of this issue.
Please advise.
> Hi, > > We do not expect such option. > > Sincerely, > Hella But this is available for other CMS in Themler. Export .artx to themler and create WP themes etc. Still we can not export the content as separate content to DNN and the content is also on the skin. We can not expect it as a skin and it is like an HTML file which is loading in a DNN site. Please, complete this first since this is the most important thing for DNN with your product. I bought your product. But still I didn't create any commercial Skin because of this issue. Please advise.Hello,
I'm sorry but now it's not in our plans to create import from Artisteer to Themler DNN themes.
Only WordPress, Joomla and HTML convert from Artisteer are available
Ok fine then.
So what about this?
Thanks!
Ok fine then. So what about this? Still we can not export the content as separate content to DNN and the content is also on the skin. We can not expect it as a skin and it is like an HTML file which is loading in a DNN site. Please, complete this first since this is the most important thing for DNN with your product. I bought your product. But still I didn't create any commercial Skin because of this issue. Thanks!
