Cannot redeclare theme_is_customizer()
MercurioWeb WebStudio
MercurioWeb WebStudio posted this 15 November 2023
Hi, when I try to open themler on my wordpress site, the error comes out:
"Cannot redeclare theme_is_customizer() (previously declared in /home/ccilxtbo/public_html/wp-content/themes/ciaoamiciitaly_2020/functions.php:31) - WordPress"
Hi, when I try to open themler on my wordpress site, the error comes out: "Cannot redeclare theme_is_customizer() (previously declared in /home/ccilxtbo/public_html/wp-content/themes/ciaoamiciitaly_2020/functions.php:31) - WordPress"
12 Comments
loyedbend2811
loyedbend2811 posted this 16 November 2023
How would you respond if there was an outbreak? I found this amazing game called monopoly online to pass the time during the cold winter. Right now, come with me.
How would you respond if there was an outbreak? I found this amazing game called [monopoly online][1] to pass the time during the cold winter. Right now, come with me. [1]: https://monopoly-online.io
wasiqshoaib087
wasiqshoaib087 posted this 03 August 2025
Hey there! The error "Cannot redeclare theme_is_customizer()" on your WordPress site suggests that the theme_is_customizer() function is defined multiple times, likely due to a conflict in your theme files (like in functions.php). This is a common issue when themes or plugins overlap. To fix it, you can try renaming the function in your theme’s functions.php file or disable any recently added plugins/themes via FTP by removing them from the wp-content/plugins or wp-content/themes folder. If you're not comfortable with FTP, contact your hosting support (e.g., via GoDaddy if that’s where your site is hosted) to assist.
On a fun note, if you’re into creative escapes, the toca boca mod apk lets you dive into a world of unlocked features for imaginative play—perfect for a break from troubleshooting! Let me know if you need more help with the error.
Hey there! The error "Cannot redeclare theme_is_customizer()" on your WordPress site suggests that the theme_is_customizer() function is defined multiple times, likely due to a conflict in your theme files (like in functions.php). This is a common issue when themes or plugins overlap. To fix it, you can try renaming the function in your theme’s functions.php file or disable any recently added plugins/themes via FTP by removing them from the wp-content/plugins or wp-content/themes folder. If you're not comfortable with FTP, contact your hosting support (e.g., via GoDaddy if that’s where your site is hosted) to assist. On a fun note, if you’re into creative escapes, the [toca boca mod apk][1] lets you dive into a world of unlocked features for imaginative play—perfect for a break from troubleshooting! Let me know if you need more help with the error. [1]: https://tocasbocasapk.com
milesles3978
milesles3978 posted this 04 December 2025
On a fun note, if you’re into creative escapes, the Toca Boca Mod APK is a fun and creative Android game experience that lets players explore open-ended worlds filled with imagination.
Hey there! The error "Cannot redeclare theme_is_customizer()" on your WordPress site suggests that the theme_is_customizer() function is defined multiple times, likely due to a conflict in your theme files (like in functions.php). This is a common issue when themes or plugins overlap. To fix it, you can try renaming the function in your theme’s functions.php file or disable any recently added plugins/themes via FTP by removing them from the wp-content/plugins or wp-content/themes folder. If you're not comfortable with FTP, contact your hosting support (e.g., via GoDaddy if that’s where your site is hosted) to assist. On a fun note, if you’re into creative escapes, the [Toca Boca Mod APK][1] is a fun and creative Android game experience that lets players explore open-ended worlds filled with imagination. [1]: http://tocaapk.com/
gabrielcarter2779
gabrielcarter2779 posted this 07 December 2025
On a fun note, if you’re into creative escapes, Toca Boca Mod APK brings a colorful, creative world where kids can explore, design, and play freely.
Hey there! The error "Cannot redeclare theme_is_customizer()" on your WordPress site suggests that the theme_is_customizer() function is defined multiple times, likely due to a conflict in your theme files (like in functions.php). This is a common issue when themes or plugins overlap. To fix it, you can try renaming the function in your theme’s functions.php file or disable any recently added plugins/themes via FTP by removing them from the wp-content/plugins or wp-content/themes folder. If you're not comfortable with FTP, contact your hosting support (e.g., via GoDaddy if that’s where your site is hosted) to assist. On a fun note, if you’re into creative escapes, Toca Boca Mod [APK][1] brings a colorful, creative world where kids can explore, design, and play freely. [1]: https://tocasbocasapk.com/toca-boca-houses/
xnxubdvpnapk56
xnxubdvpnapk56 posted this 15 January 2026
This error usually happens when WordPress loads the same PHP function twice — in this case, theme_is_customizer. Themeler often conflicts with the active theme or another plugin that declares the same function. Try switching to a default theme or disabling plugins to find the source of the conflict.
If you’re testing your site from mobile or working with Android tools, a lot of users use modded utilities through platforms like https://happymod.tr/ to manage or preview builds, but make sure you’re running updated and clean versions of any helper apps to avoid further conflicts.
This error usually happens when WordPress loads the same PHP function twice — in this case, theme_is_customizer. Themeler often conflicts with the active theme or another plugin that declares the same function. Try switching to a default theme or disabling plugins to find the source of the conflict. If you’re testing your site from mobile or working with Android tools, a lot of users use modded utilities through platforms like https://happymod.tr/ to manage or preview builds, but make sure you’re running updated and clean versions of any helper apps to avoid further conflicts.
wasiqshoaib087
wasiqshoaib087 posted this 09 June 2026
The “Cannot redeclare theme_is_customizer()” error usually occurs when the same function is defined more than once in a WordPress theme or plugin, causing a PHP conflict. Checking recently added code, theme files, or plugins can help identify and remove the duplicate declaration.
For more tech-related guides and troubleshooting tips, visit https://trafficridermodsapk.org
The “Cannot redeclare theme_is_customizer()” error usually occurs when the same function is defined more than once in a WordPress theme or plugin, causing a PHP conflict. Checking recently added code, theme files, or plugins can help identify and remove the duplicate declaration. For more tech-related guides and troubleshooting tips, visit [https://trafficridermodsapk.org][1] [1]: http://%20https://trafficridermodsapk.org
tiffanyscottofficial
tiffanyscottofficial posted this 16 June 2026
The "Cannot redeclare theme_is_customizer()" error usually occurs when the same function is defined more than once in a WordPress theme or plugin. Checking for duplicate function declarations, conflicting plugins, or repeated code inclusions can help resolve the issue quickly. For more tech guides, apps, and useful resources, visit [http://happymodi.net][1] and explore the latest updates and tools.
catherinecathedral5
catherinecathedral5 posted this 16 June 2026
The "Cannot redeclare theme_is_customizer()" error usually occurs when the same function is defined more than once in a theme or plugin file. Checking for duplicate function declarations and ensuring that custom code is loaded only once can often resolve the issue.
It's also a good practice to use conditional checks before declaring custom functions to avoid conflicts during updates or when multiple components interact. While troubleshooting your setup, you can also explore entertainment options with magis celular app and enjoy streaming content on your computer.
The "Cannot redeclare theme_is_customizer()" error usually occurs when the same function is defined more than once in a theme or plugin file. Checking for duplicate function declarations and ensuring that custom code is loaded only once can often resolve the issue. It's also a good practice to use conditional checks before declaring custom functions to avoid conflicts during updates or when multiple components interact. While troubleshooting your setup, you can also explore entertainment options with [magis celular app][1] and enjoy streaming content on your computer. [1]: http://themagis-tv.com.mx/apk/
elizablazeofficial
elizablazeofficial posted this 16 June 2026
The "Cannot redeclare theme_is_customizer()" error usually occurs when the same function is declared more than once, often due to duplicate code in themes or plugins. Checking for conflicts and ensuring functions are loaded only once can help resolve the issue, while developers often look for efficient solutions and resources such as Fire Kirin APK when exploring online platforms.
The "Cannot redeclare theme_is_customizer()" error usually occurs when the same function is declared more than once, often due to duplicate code in themes or plugins. Checking for conflicts and ensuring functions are loaded only once can help resolve the issue, while developers often look for efficient solutions and resources such as [Fire Kirin APK][1] when exploring online platforms. [1]: https://themagis-tv.com.mx/
sabrinamalvern9
sabrinamalvern9 posted this 16 June 2026
This is a helpful explanation of the "Cannot redeclare theme_is_customizer()" error. Duplicate function declarations are a common issue in WordPress development, especially when working with custom themes and plugins. Using conditional function checks and reviewing included files can save a lot of troubleshooting time. For those interested in Android apps and installation guides, check out orion stars 2 apk latest version download for android for useful resources and tutorials.
This is a helpful explanation of the "Cannot redeclare theme_is_customizer()" error. Duplicate function declarations are a common issue in WordPress development, especially when working with custom themes and plugins. Using conditional function checks and reviewing included files can save a lot of troubleshooting time. For those interested in Android apps and installation guides, check out [orion stars 2 apk latest version download for android][1] for useful resources and tutorials. [1]: https://getorionstarsapk.com/
sarwarkhanhoon
sarwarkhanhoon posted this 16 June 2026
Thanks for sharing this solution. Function redeclaration errors can be frustrating, especially when multiple themes or plugins are involved. Checking for duplicate function definitions and using proper conditional statements is usually the best fix. While looking for helpful online resources recently, I came across https://www.juwa777apk.download/juwa-777-on-pc/ , which provides a clear setup guide for new users and is worth checking out.
levinelorraine291
levinelorraine291 posted this 18 June 2026
This error usually happens when the same function is loaded more than once in WordPress. Checking for duplicate declarations and using proper conditional function checks can help resolve the issue quickly. For users looking for entertainment after troubleshooting, visit [download app][1] for gaming options and updates.
