When logging in to themler it opens. But after that I cant edit/select anything?
What do I need to do?
kind regards
Hi, When logging in to themler it opens. But after that I cant edit/select anything? What do I need to do? kind regards
kind regards
Hi, When logging in to themler it opens. But after that I cant edit/select anything? What do I need to do? kind regardsSame as this ticket and another
https://answers.themler.io/questions/224026/themler-wordpress-editor-screen-side-panel-does-not-appear-and-edited-functions-to-not-function/224029#post-224029
and
https://answers.themler.io/questions/224018/problem-with-editing-the-website-template
Vote each one of these so the dev's can see multiple tickets with the same problem.
Same as this ticket and another https://answers.themler.io/questions/224026/themler-wordpress-editor-screen-side-panel-does-not-appear-and-edited-functions-to-not-function/224029#post-224029 and https://answers.themler.io/questions/224018/problem-with-editing-the-website-template Vote each one of these so the dev's can see multiple tickets with the same problem.Using a pluggin called "WP Downgrade" and tested returning to 6.3.2, it worked, I have full control over themler again. Tested on a 2nd site, with 17 pluggins all running perfectly. So this editor conflict is in 6.4.1 vs themler 559+.
Rolling back others until this problem is resolved. But this is a way out of the rubbish for the time being.
I have also popped php back to 7.4 just in case.
You need to confirm your email to be able to perform suika other operations, please check the email inbox you entered when registering your account.
You need to confirm your email to be able to perform [suika][1] other operations, please check the email inbox you entered when registering your account. [1]: https://suikagame2.ioLast edited 20 November 2023 by brownsunny148
yes.. the same... very bad...
i will also try for quick solution to downgrade wp...
this is only with themler 559 or also in new 567 ?
I'm afraid nothing was done in the update about compatibility with Wordpress
Both Themler version has the problem and the downgrade in wordpress has solved this in 8 different sites so far
> yes.. the same... very bad... > > i will also try for quick solution to downgrade wp... > > this is only with themler 559 or also in new 567 ? > I'm afraid nothing was done in the update about compatibility with Wordpress > Both Themler version has the problem and the downgrade in wordpress has solved this in 8 different sites so farok thanks for the info
yes, downgrade solves - but is not solution for the future, only temporary.
@support
i am long customer... but i not buy now a renew licence when bring not more development for themler and fixes was for both cms
please quick response in the next 4 days !
when you bring fixes for wp and php 8.x and you can say me you make more fixes oder again develope this software, maybe i buy in the black fridays weekend and i am also longer customer for themler + nicepage
or give me the new fixes for free one time please
but i buy not anymore both systems when you not better support themler.
nicepage is not an good template-builder now, is an webpage/content-builder with many many bugs and themler was better to work and full template maker.
I agree with @ITS words.
I am preparing a replacement approach, just in case Themler team do not do anything. But I hope they do.
So new sites I am currently using Wordpress V.6.3.2 with PHP 7.4 and Themler 567.
Hi, I had a similar issue where I could log in but nothing was selectable or editable. It helped me to clear my browser cache and try a different browser. Also, sometimes permissions or extensions can block editing. By the way, while researching for a project on leyes de armas en rhode island, I realized how important it is to have everything working smoothly to get the info you need. Hopefully, this helps!
Hi, I had a similar issue where I could log in but nothing was selectable or editable. It helped me to clear my browser cache and try a different browser. Also, sometimes permissions or extensions can block editing. By the way, while researching for a project on [leyes de armas en rhode island][1], I realized how important it is to have everything working smoothly to get the info you need. Hopefully, this helps! [1]: https://thelawreference.com/leyes-de-armas-en-rhode-island/Child support laws are designed to ensure that children receive the same standard of living they would have if both parents lived together. The Florida Child Support Calculator helps enforce this principle by applying uniform guidelines across all cases. Judges and attorneys often rely on this calculator during proceedings to recommend or determine support amounts, which helps remove subjectivity and personal bias from the decision-making process florida child support calculator 2025. This consistent application of the law strengthens public trust in the family court system and promotes more equitable outcomes for children.
Child support laws are designed to ensure that children receive the same standard of living they would have if both parents lived together. The Florida Child Support Calculator helps enforce this principle by applying uniform guidelines across all cases. Judges and attorneys often rely on this calculator during proceedings to recommend or determine support amounts, which helps remove subjectivity and personal bias from the decision-making process [florida child support calculator 2025][1]. This consistent application of the law strengthens public trust in the family court system and promotes more equitable outcomes for children. [1]: https://floridachildsupportcalculator.us/Using a pluggin called "WP Downgrade" and trying to roll back to 6.3.2, it works, I have full control over themler again. Tested on 2nd site spanish dictionary, with 17 pluggins all running perfectly.
Using a pluggin called "WP Downgrade" and trying to roll back to 6.3.2, it works, I have full control over themler again. Tested on 2nd site [spanish dictionary][1], with 17 pluggins all running perfectly. [1]: https://spanishdictionary.cchttps://japanbamboo.pixnet.net/blog
https://bothbest.tistory.com
https://bothbest.seesaa.net
https://bothbest.mystrikingly.com
https://blog.libero.it/wp/bothbestbamboo
https://bothbest.weebly.com
https://bamboochopsticks.storeinfo.jp
https://hssolar.tawk.help
https://bothbestbambooflooring.tawk.help
https://chinabamboo.therestaurant.jp/
https://bamboodecking.themedia.jp/
https://bambooplywood.localinfo.jp/
https://bambooflooring.univer.se/
https://bambooflooring.theblog.me/
https://japanbamboo.storeinfo.jp/
https://bambooflooring.omeka.net/
https://bothbest.amebaownd.com
https://bambooflooring.shopinfo.jp
https://bambooflooring.notion.site/bothbest-26f41b6b363980b0865fd008cf78ea7a
If you suddenly can’t edit your theme anymore, it’s usually because the platform has changed permissions, updated its editor, or restricted customization on your current plan. For example, on site builders like WordPress, theme editing may be limited if you’re using a locked cin takvimi or premium theme, while platforms such as Shopify require certain plans or admin access to modify theme files.
If you suddenly can’t edit your theme anymore, it’s usually because the platform has changed permissions, updated its editor, or restricted customization on your current plan. For example, on site builders like WordPress, theme editing may be limited if you’re using a locked [cin takvimi][1] or premium theme, while platforms such as Shopify require certain plans or admin access to modify theme files. [1]: https://cintakvimi.tr/Hi, I understand your problem and it can be really frustrating. Try refreshing the page, clearing your browser cache, or using a different browser, and also check if any extensions are blocking the editing tools, as this can often prevent theme options from working. Sometimes simple fixes can quickly fix it. You can also check out helpful resources like Delta Exploit Android which can guide you through similar tools and issues related to Delta Exploit Android. Hopefully this will help you get your theme editing working again.
Hi, I understand your problem and it can be really frustrating. Try refreshing the page, clearing your browser cache, or using a different browser, and also check if any extensions are blocking the editing tools, as this can often prevent theme options from working. Sometimes simple fixes can quickly fix it. You can also check out helpful resources like Delta Exploit Android which can guide you through similar tools and issues related to [Delta Exploit Android][1]. Hopefully this will help you get your theme editing working again. [1]: https://delta-executors.com.mx/delta-exploit/
