Upgrade to Wordpress 6.4 and 6.4.1
Sifone Company
Sifone Company posted this 16 November 2023
Good afternoon.
I make the following report of a failure that is occurring in the Themler editor when upgrading to version 6.4 and 6.4.1 of WordPress, does not allow any editing on the site, it is completely blocked without being able to make any adjustment.
We urgently need an answer and solution on this failure that is occurring as we make several pages with this editor Themler, and we need to be updated to the latest version of WordPress, but this failure in the editor with this latest version of WordPress is preventing us.
Thank you.
Best regards.
Good afternoon. I make the following report of a failure that is occurring in the Themler editor when upgrading to version 6.4 and 6.4.1 of WordPress, does not allow any editing on the site, it is completely blocked without being able to make any adjustment. We urgently need an answer and solution on this failure that is occurring as we make several pages with this editor Themler, and we need to be updated to the latest version of WordPress, but this failure in the editor with this latest version of WordPress is preventing us. Thank you. Best regards.
28 Comments
David at Acoma
David at Acoma posted this 19 November 2023
Using a pluggin called "WP Downgrade" and tested returning to 6.3.2, it worked, I have full control over themler again. Tested on a 2nd site, with 17 pluggins all running perfectly. So this editor conflict is in 6.4.1 vs themler 559+.
Rolling back others until this problem is resolved. But this is a way out of the rubbish for the time being.
I have also popped php back to 7.4 just in case.
Using a pluggin called "WP Downgrade" and tested returning to 6.3.2, it worked, I have full control over themler again. Tested on a 2nd site, with 17 pluggins all running perfectly. So this editor conflict is in 6.4.1 vs themler 559+. Rolling back others until this problem is resolved. But this is a way out of the rubbish for the time being. I have also popped php back to 7.4 just in case.
sotolarsen1631545
sotolarsen1631545 posted this 20 November 2023
Good afternoon.
Thank you.
Best regards.
Hello, super mario 64
I'm not sure, but I might try:
Downgrade to WordPress 6.3.1: This is the most stable version of WordPress that works with Themler.
Use Themler's WordPress Compatibility Mode: This mode will disable some of Themler's features, but it may allow you to edit your site in WordPress 6.4 and 6.4.1.
Use a different WordPress editor: There are a number of other WordPress editors available, such as Elementor, Brizy, and Beaver Builder. These editors may not be as powerful as Themler, but they may be more compatible with WordPress 6.4 and 6.4.1.
> Good afternoon. > > I make the following report of a failure that is occurring in the Themler editor when upgrading to version 6.4 and 6.4.1 of WordPress, does not allow any editing on the site, it is completely blocked without being able to make any adjustment. > > We urgently need an answer and solution on this failure that is occurring as we make several pages with this editor Themler, and we need to be updated to the latest version of WordPress, but this failure in the editor with this latest version of WordPress is preventing us. > > Thank you. > > Best regards. Hello, [super mario 64][1] I'm not sure, but I might try: Downgrade to WordPress 6.3.1: This is the most stable version of WordPress that works with Themler. Use Themler's WordPress Compatibility Mode: This mode will disable some of Themler's features, but it may allow you to edit your site in WordPress 6.4 and 6.4.1. Use a different WordPress editor: There are a number of other WordPress editors available, such as Elementor, Brizy, and Beaver Builder. These editors may not be as powerful as Themler, but they may be more compatible with WordPress 6.4 and 6.4.1. [1]: https://supermario64.io
Orange Gorilla
Orange Gorilla posted this 21 November 2023
I've tried to reach the support via Nicepage. The only way they react to us.
@ITS
@ITS posted this 22 November 2023
Oh man... i have the same Problem. I cant Edit the Template/Content wit a priority Wordpress Page... WP Updated to 6.4.1 with Themler 559
@Support
PLEASE QUICK RESPONSE !
We need a Fix for this... is Version 567 compatible to Wordpress 6.4.x ???
Oh man... i have the same Problem. I cant Edit the Template/Content wit a priority Wordpress Page... WP Updated to 6.4.1 with Themler 559 @Support **PLEASE QUICK RESPONSE !** We need a Fix for this... is Version 567 compatible to Wordpress 6.4.x ???
Support Team posted this 24 November 2023
We have checked the newest Themler v.567 with the latest Wordpress and found one minor issue which will be fixed soon. Looks like you have a different issue. Could you please provide some details on the steps to reproduce it - is it content editing that doesn't work or doesn't the theme open in Themler at all, or anything different?
Hello, We have checked the newest Themler v.567 with the latest Wordpress and found one minor issue which will be fixed soon. Looks like you have a different issue. Could you please provide some details on the steps to reproduce it - is it content editing that doesn't work or doesn't the theme open in Themler at all, or anything different? Sincerely, Nettie
Sifone Company
Sifone Company posted this 24 November 2023
Good morning.
Indeed the content editing does not work, it does not allow any adjustment on the website design or any other functionality through Themler.
In the attached screenshots you can see that:
In the screenshot #1 you can see the editor when it is with WordPress Version 6.3.2.
In the screenshot #2 you can see the editor when it is with WordPress Version 6.4.1.> Hello,
Good morning. Indeed the content editing does not work, it does not allow any adjustment on the website design or any other functionality through Themler. In the attached screenshots you can see that: In the screenshot #1 you can see the editor when it is with WordPress Version 6.3.2. In the screenshot #2 you can see the editor when it is with WordPress Version 6.4.1.> Hello, > > We have checked the newest Themler v.567 with the latest Wordpress and found one minor issue which will be fixed soon. Looks like you have a different issue. Could you please provide some details on the steps to reproduce it - is it content editing that doesn't work or doesn't the theme open in Themler at all, or anything different? > > Sincerely, > Nettie
Could you please create a new private topic and provide temporary access to your website in Wordpress 6.4.1 for investigation? Let us know if you'd prefer that we move this one to private instead.
Hello, Could you please create a new private topic and provide temporary access to your website in Wordpress 6.4.1 for investigation? Let us know if you'd prefer that we move this one to private instead. Sincerely, Nettie
Sifone Company
Done, you can move it to private.
But it should be clarified that the Themler Editor error that does not allow any editing on the website happens with all installations of websites that are updated to WordPress 6.4.1.
> Hello, > > Could you please create a new private topic and provide temporary access to your website in Wordpress 6.4.1 for investigation? Let us know if you'd prefer that we move this one to private instead. > > Sincerely, > Nettie Done, you can move it to private. But it should be clarified that the Themler Editor error that does not allow any editing on the website happens with all installations of websites that are updated to WordPress 6.4.1.
@ITS
@ITS posted this 26 November 2023
Stop.. why private case ?
This is an Problem for ALL USERS and not individual problem !
Please check the Forum, many Threads...
Themler 559 is not compatible to Wordpress 6.4.1
I read the same is with 567 !?
but now i don't not buy more when not more Support and no longer develop themler
I am a long time customer (arstisteer - themler - nicepage). you can give me the fix update please.
now i and other users make a downgrade to can edit - this works for temporary
we all was very angry to not more develope themler and all resources to nicepage
Stop.. why private case ? This is an Problem for ALL USERS and not individual problem ! Please check the Forum, many Threads... **Themler 559 is not compatible to Wordpress 6.4.1** I read the same is with 567 !? but now i don't not buy more when not more Support and no longer develop themler I am a long time customer (arstisteer - themler - nicepage). you can give me the fix update please. now i and other users make a downgrade to can edit - this works for temporary we all was very angry to not more develope themler and all resources to nicepage
Sifone Company
Sifone Company posted this 27 November 2023
Good morning.
We need Themler to be updated to work correctly with WordPress version 6.4.1.
We demand that you please develop it and put it into production.
Thank you.
> Stop.. why private case ? > > This is an Problem for ALL USERS and not individual problem ! > Please check the Forum, many Threads... > > **Themler 559 is not compatible to Wordpress 6.4.1** > > I read the same is with 567 !? > but now i don't not buy more when not more Support and no longer develop themler > I am a long time customer (arstisteer - themler - nicepage). you can give me the fix update please. > > now i and other users make a downgrade to can edit - this works for temporary > > we all was very angry to not more develope themler and all resources to nicepage > Good morning. We need Themler to be updated to work correctly with WordPress version 6.4.1. We demand that you please develop it and put it into production. Thank you.
svl1988
svl1988 posted this 27 November 2023
Also here a member from the beginning of Artisteer.
Themler is not working anymore on WP 6.4.1. The downgrade to 6.3.2 helps, but it is not the final solution and brings safety risks on the websites.
Can you please keep this topic public and get as soon as possible with a solution. I see a lot of people are dealing with this issue :(
Also here a member from the beginning of Artisteer. Themler is not working anymore on WP 6.4.1. The downgrade to 6.3.2 helps, but it is not the final solution and brings safety risks on the websites. Can you please keep this topic public and get as soon as possible with a solution. I see a lot of people are dealing with this issue :(
Der Webarchitekt
Der Webarchitekt posted this 04 December 2023
I found out what it was!!!!
It was in my installation the PLUGIN DISABLE GUTENBERG.
After i disabled it all works well.
So test it yourself - and disable plugins!!
Tested it on new installation - without these nice plugin - themler works well in the backend.
Its not the whole solution but you can edit and after edditing activate the plugin. So your content seems in frontend well.
**I found out what it was!!!!** It was in my installation the **PLUGIN DISABLE GUTENBERG**. After i disabled it all works well. So test it yourself - and disable plugins!! Tested it on new installation - without these nice plugin - themler works well in the backend. Its not the whole solution but you can edit and after edditing activate the plugin. So your content seems in frontend well.
Pascal Mariany
Pascal Mariany posted this 05 December 2023
I don't have the Gutenberg plugin in my list. So for me not a solution.
> **I found out what it was!!!!** > It was in my installation the **PLUGIN DISABLE GUTENBERG**. > After i disabled it all works well. > > So test it yourself - and disable plugins!! > > Tested it on new installation - without these nice plugin - themler works well in the backend. > > Its not the whole solution but you can edit and after edditing activate the plugin. So your content seems in frontend well. I don't have the Gutenberg plugin in my list. So for me not a solution.
Der Webarchitekt
Der Webarchitekt posted this 05 December 2023
Test: Disbale plugins step by step - Did today new wordpress installation with themler - all work well.
Sorry that it not work for you - :-(
Test: Disbale plugins step by step - Did today new wordpress installation with themler - all work well. Sorry that it not work for you - :-(
Support Team posted this 07 December 2023
We are sorr for the issues with Wordpress 6.4.x. The issue has come out after the latest Wordpress update. We are forking at the fixes and will include them into the next update.
In the meantime please consider temporarily use an older Wordpress version. I will also update this topic when the update is out.
Hello, We are sorr for the issues with Wordpress 6.4.x. The issue has come out after the latest Wordpress update. We are forking at the fixes and will include them into the next update. In the meantime please consider temporarily use an older Wordpress version. I will also update this topic when the update is out. Sincerely, Nettie
ernestrobinson156
ernestrobinson156 posted this 04 February 2024
Hi geometry dash lite
We need it, so please create it and put it into production.
Hi [geometry dash lite][1] We need it, so please create it and put it into production. [1]: https://geometrydash-lite.io
jasperwilde09
jasperwilde09 posted this 26 March 2024
Every day I choose a joy, choose back and forth, and finally I choose the enenagram test, one of the personal tests with extremely long origins that helps me understand more about myself.
Every day I choose a joy, choose back and forth, and finally I choose the [enenagram test][1], one of the personal tests with extremely long origins that helps me understand more about myself. [1]: https://enneagram-test.io/
foodlenyt88
foodlenyt88 posted this 10 April 2024
You must be familiar with New York only as a location in the United States, right? However, there is one more fantastic game type that you ought to try out, and that is: nytimes crossword
You must be familiar with New York only as a location in the United States, right? However, there is one more fantastic game type that you ought to try out, and that is: [nytimes crossword](https://nytimescrossword.io)
mystikcharmz
mystikcharmz posted this 21 August 2024
Author and beauty expert Jane Doe has published much material about skin cosmetics products. Her love of skincare started early, driving her to learn cosmetology and formulation. Jane covers everything from DIY skin-lightening treatments to the most recent developments in skin-brightening technologies. Her straightforward, doable advice on getting an even skin tone is well-known. Jane also stresses the need to avoid harsh chemicals that could harm the skin and choose cosmetics for different skin types.
Author and beauty expert Jane Doe has published much material about skin [cosmetics products][1]. Her love of skincare started early, driving her to learn cosmetology and formulation. Jane covers everything from DIY skin-lightening treatments to the most recent developments in skin-brightening technologies. Her straightforward, doable advice on getting an even skin tone is well-known. Jane also stresses the need to avoid harsh chemicals that could harm the skin and choose cosmetics for different skin types. [1]: https://www.vividshop.pk/product-category/cosmetics-products/
kimyong198111
kimyong198111 posted this 28 September 2024
광주출장마사지
언제 어디서나 편리하게 받을 수 있는 출장안마 서비스로 휴식을 최상의 휴식을 제공합니다(스팸링크를 피하려면 구글에서 “윈터출장샵" 검색해서찾아주세요)(알바생모집 25만원보장)(경력자우선)(나이20세~30) 100%후불제입니다
[광주출장마사지][1] [1]: https://www.winteranma.com/region-gwangju 언제 어디서나 편리하게 받을 수 있는 출장안마 서비스로 휴식을 최상의 휴식을 제공합니다(스팸링크를 피하려면 구글에서 “윈터출장샵" 검색해서찾아주세요)(알바생모집 25만원보장)(경력자우선)(나이20세~30) 100%후불제입니다
