Themler editor does not load with Ninja Forms pluggin enable.
David at Acoma
David at Acoma posted this 3 weeks ago
When using a pluggin Ninja form, tested with various versions, it stops the themler editor working properly.
I have logged a call with Ninja Forms just in case, but they are challengint the theme is the problem.
Themler editor loads with missing side panel content and also no clickable elements in the body like header etc.
When using a pluggin Ninja form, tested with various versions, it stops the themler editor working properly. I have logged a call with Ninja Forms just in case, but they are challengint the theme is the problem. Themler editor loads with missing side panel content and also no clickable elements in the body like header etc.
hegof70356
hegof70356 posted this yesterday
Hello, bitlife
there is a conflict between the Ninja Forms plugin and the Elementor script, which affects the ability to edit forms. The suggested solution is to temporarily roll WordPress back to version 5.5.3 until the issue is resolved. The author of the post has logged a call with Ninja Forms, but they are challenging the theme as the problem bitlife life simulator
Hello, [bitlife][1] there is a conflict between the Ninja Forms plugin and the Elementor script, which affects the ability to edit forms. The suggested solution is to temporarily roll WordPress back to version 5.5.3 until the issue is resolved. The author of the post has logged a call with Ninja Forms, but they are challenging the theme as the problem [bitlife life simulator][2] [1]: https://bitlifegame.io [2]: https://bitlifegame.io
David at Acoma
David at Acoma posted this yesterday
Hello, [bitlife][1]
Wow, strange answer, one as I am not using Elementor and two, rolling back for 5.5.3 is a bizarre recommendation. Rolling back to October 2020 version of wordpress makes me suspect you are wanting to use an exploit.
So I will not be following your comment.
> Hello, [bitlife][1] > there is a conflict between the Ninja Forms plugin and the Elementor script, which affects the ability to edit forms. The suggested solution is to temporarily roll WordPress back to version 5.5.3 until the issue is resolved. The author of the post has logged a call with Ninja Forms, but they are challenging the theme as the problem [bitlife life simulator][2] > Wow, strange answer, one as I am not using Elementor and two, rolling back for 5.5.3 is a bizarre recommendation. Rolling back to October 2020 version of wordpress makes me suspect you are wanting to use an exploit. So I will not be following your comment.
David at Acoma
This problem relates to the V6.4.x problem with PHP8 and Themler, so not looking at Ninja forms being the problem anymore its a Themler problem with latest version of Wordpress. Rolling back to 6.3.2 solves the problem while we wait for Themler Dev's to fix.
