themler doesn't work with php8.1 and php 8.2
Xixion
Xixion posted this 20 November 2023
When I select php8.1 of php8.2 themler gives an error: PHP-message - Joomla4
@ITS
@ITS posted this 22 November 2023
Wich Themler Version use you ?
Is the same Problem with the new Update ?
Wich Themler Version use you ? Is the same Problem with the new Update ?
Xixion
Xixion posted this 22 November 2023
version 1.0.319 (fe25b) for mac. I use the new template on a clean joomla 5 installation.
Support Team posted this 24 November 2023
Unfortunately, Themler for Mac doesn't include an installation for Joomla 5 yet. However if the issue is reproducible on a new Joomla 5 with the latest v.567 theme for you, could you please create a new private topic and provide access to your website admin panel there? Or let us know if we can move this one to private to continue here.
Hello, Unfortunately, Themler for Mac doesn't include an installation for Joomla 5 yet. However if the issue is reproducible on a new Joomla 5 with the latest v.567 theme for you, could you please create a new private topic and provide access to your website admin panel there? Or let us know if we can move this one to private to continue here. Sincerely, Nettie
paricke
paricke posted this 25 November 2023
Hello Xixion,
If Themler, a website design software, is not working with PHP 8.1 and PHP 8.2, it's likely due to compatibility issues. PHP 8.x introduced significant changes and deprecations that can affect older software. Here are steps you can take to address this issue:
  1. Check Themler's Compatibility
    Visit Themler's official website or contact their support to confirm the PHP versions they currently support.
    Look for any announcements or documentation about their compatibility with PHP 8.1 and PHP 8.2.
  2. Seek Updates
    If Themler has updates available that support PHP 8.1 or 8.2, update your glance.intuit.com Themler software.
    Ensure that all associated plugins or add-ons are also updated.
  3. Use Compatible PHP Version
    If Themler does not support PHP 8.1 or 8.2, you may need to downgrade to a PHP version that is compatible with Themler.
    Contact your hosting provider to switch back to a compatible PHP version, such as PHP 7.4.
Hello Xixion, If Themler, a website design software, is not working with PHP 8.1 and PHP 8.2, it's likely due to compatibility issues. PHP 8.x introduced significant changes and deprecations that can affect older software. Here are steps you can take to address this issue: 1. Check Themler's Compatibility Visit Themler's official website or contact their support to confirm the PHP versions they currently support. Look for any announcements or documentation about their compatibility with PHP 8.1 and PHP 8.2. 2. Seek Updates If Themler has updates available that support PHP 8.1 or 8.2, update your [glance.intuit.com][1] Themler software. Ensure that all associated plugins or add-ons are also updated. 3. Use Compatible PHP Version If Themler does not support PHP 8.1 or 8.2, you may need to downgrade to a PHP version that is compatible with Themler. Contact your hosting provider to switch back to a compatible PHP version, such as PHP 7.4. [1]: https://cellossoftware.com/
0pflfcr10t
0pflfcr10t posted this 09 October 2024
Hello Xixion,
  2. Seek Updates Drift Boss
Consider a Staging Server: If downgrading your live server's PHP version isn't ideal, you could create a staging server with a compatible PHP version specifically for using Themler. This allows you to develop and test your website without impacting the live version.
> Hello Xixion, > > If Themler, a website design software, is not working with PHP 8.1 and PHP 8.2, it's likely due to compatibility issues. PHP 8.x introduced significant changes and deprecations that can affect older software. Here are steps you can take to address this issue: > > 1. Check Themler's Compatibility > Visit Themler's official website or contact their support to confirm the PHP versions they currently support. > Look for any announcements or documentation about their compatibility with PHP 8.1 and PHP 8.2. > 2. Seek Updates [Drift Boss](https://driftboss2.org) > If Themler has updates available that support PHP 8.1 or 8.2, update your [glance.intuit.com][1] Themler software. > Ensure that all associated plugins or add-ons are also updated. > 3. Use Compatible PHP Version > If Themler does not support PHP 8.1 or 8.2, you may need to downgrade to a PHP version that is compatible with Themler. > Contact your hosting provider to switch back to a compatible PHP version, such as PHP 7.4. > > > [1]: https://cellossoftware.com/ Consider a Staging Server: If downgrading your live server's PHP version isn't ideal, you could create a staging server with a compatible PHP version specifically for using Themler. This allows you to develop and test your website without impacting the live version.
