Themler export import
Bayern
Bayern posted this 23 August 2015
I created an Joomla-Template with Artisteer and oh wonder, after a while, i was able to import in Themler and save as Themler Joomla Template.
I want this Template for Virtuemart but when i try to import in Virtuemart, there is a message
"Import failed. Only Themler Themes are supported."
But i want this Template for Virtuemart! Whats to do?
OK, i tried to import this Template for Wordpress and "File upload failed"
what does that mean?
If i want do have a Template in Static HTML, Joomla and Wordpress or Vituemart i have to create it for each one new?
best regards
Jürgen
I created an Joomla-Template with Artisteer and oh wonder, after a while, i was able to import in Themler and save as Themler Joomla Template. I want this Template for Virtuemart but when i try to import in Virtuemart, there is a message "Import failed. Only Themler Themes are supported." **But i want this Template for Virtuemart! Whats to do?** OK, i tried to import this Template for Wordpress and "File upload failed" what does that mean? If i want do have a Template in Static HTML, Joomla and Wordpress or Vituemart i have to create it for each one new? best regards Jürgen
8 Comments
lesergei
lesergei posted this 23 August 2015
Before the arrival of Themler, you had to export to CMS / HTML selected, it was not possible to import a template for Joomla in a Wordpress site. Need I say more? :)
Hello, Before the arrival of Themler, you had to export to CMS / HTML selected, it was not possible to import a template for Joomla in a Wordpress site. Need I say more? :)
Bayern
Before the arrival of Themler, i was able to export to HTML, Joomla, Wordpress and so on..
Yes need you say more! :D
And now?
Before the arrival of Themler, i was able to export to HTML, Joomla, Wordpress and so on.. Yes need you say more! :D And now?
lesergei
Ok, i begin ;)
With artisteer, this version :https://answers.themler.com/questions/19131/import-zip-joomla. (i suppose you already have it).
you can only export a Themler template for Joomla and Wordpress.
For Virtuemart, you can download the desktop version.
In Themler, if you start a template for Joomla or other, you can only export for Joomla, or other (i thlnk).
Hi, > Yes need you say more! :D Ok, i begin ;) With artisteer, this version :https://answers.themler.com/questions/19131/import-zip-joomla. (i suppose you already have it). you can only export a Themler template for Joomla and Wordpress. For Virtuemart, you can download the desktop version. In Themler, if you start a template for Joomla or other, you can only export for Joomla, or other (i thlnk).
Bayern
and that is the problem! (one of the Problems)
I need a Template for Joomla (Virtuemart is an extension for Joomla)
and i need for this extension a Template or Theme
Now I am forced to create two templates from scratch? It can not be true right?
By the way, I got the Desktop Version...
and that is the problem! (one of the Problems) I need a Template for Joomla (Virtuemart is an extension for Joomla) and i need for this extension a Template or Theme Now I am forced to create two templates from scratch? It can not be true right? By the way, I got the Desktop Version...
lesergei
You can download the template for Virtumart, an install it in Joomla. Have you try it?
http://themler.com/ clic download for cms
You can download the template for Virtumart, an install it in Joomla. Have you try it? http://themler.com/ clic download for cms
lesergei
After installing Virtuemart the products template was not available? Before installing the template for Virtuemart.
Bayern
i'll try tomorrow
thanks
i'll try tomorrow thanks
lesergei
OK, but it works, I installed Virtuemart, I created a menu link to a category, and then I'll edit my Joomla template that contains Themler. And I have not installed the template for VirtueMart.
