Hi there
how can I insert and STYLE a vertical menu like in artisteer.. ????
thanks for your help
claudia
Hi there how can I insert and STYLE a vertical menu like in artisteer.. ???? thanks for your help claudia
Hi there
claudia
Hi there how can I insert and STYLE a vertical menu like in artisteer.. ???? thanks for your help claudiaHello,
http://answers.themler.com/articles/6643/how-to-create-vertical-menus-in-joomla
Hey Claudiah,
I have been looking for the same thing.
Interesting thing... If you export an Artisteer zip file that has a vertical menu in it, and you then open the file in Themler... Not only will your vertical menu be in there, but there will be a new dialog box with all these built-in vertical menu features you can use to edit with.
As far as I know, at this time, there is no other way to access the vertical menu features in Themler.
Hey Claudiah, I have been looking for the same thing. Interesting thing... If you export an Artisteer zip file that has a vertical menu in it, and you then open the file in Themler... Not only will your vertical menu be in there, but there will be a new dialog box with all these built-in vertical menu features you can use to edit with. As far as I know, at this time, there is no other way to access the vertical menu features in Themler.Last edited 02 September 2015 by christopher
And now... Some how... The vertical menu dialog box has shown-up.
Click the "STYLES" icon for the "Default Styles", toward the bottom under "WIDGETS" I now have a "Vertical Menu" styling option.
Weird.
This program needs a User's Manual!
And now... Some how... The vertical menu dialog box has shown-up. Click the "STYLES" icon for the "Default Styles", toward the bottom under "WIDGETS" I now have a "Vertical Menu" styling option. Weird. This program needs a User's Manual!But this doesent´t work in Joomla and a Menu Header is missing
Even if you write the " vmenu" in Modul :-(
To create an new Template with vertical Menu in Desktop Version, you have to follow these instructions:
http://answers.themler.com/questions/2456/joomla-vertical-menu
But this doesent´t work in Joomla and a Menu Header is missing Even if you write the " vmenu" in Modul :-( To create an new Template with vertical Menu in Desktop Version, you have to follow these instructions: http://answers.themler.com/questions/2456/joomla-vertical-menuLast edited 08 September 2015 by Bayern
You need to make sure that the block header was enabled. In any case, you can create a private ticket and provide an access to the back end so we could see the theme.
Sorry,
when follow the instructions of the Link, than the Header is also editable
Sorry, when follow the instructions of the Link, than the Header is also editableHi,
Please let us know if you need our further help.
