Themler for Joomla 4, 5 (Beta) - 1406 data too long
Karschten
Karschten posted this 25 January 2024
Hello there,
just installed blank theme as mentioned above and receiving following error when activating blank theme:
1406 - Data too long for column 'ip' at row 1
How can it be solved?
Running now Joomla 5.0.2 with PHP 8.2 and mysqli (MySQL 8.0). After many months of doing nothing on my J4 page (due to known issues of Themler) and some regrets as the first so called beta did not even work with blank and newly installed pages I just updated and start a new try.
Regarding history: Page was created with J3 originally as well with a Themler desktop app theme. After an update to J4 the necessary deinstallation of themler theme was properly done and some more apps got deleted. Now I am on J5, as I wanted to believe to the news that it might work again.
Thanks for any helpful answer
Greeting
Karsten
Hello there, just installed blank theme as mentioned above and receiving following error when activating blank theme: 1406 - Data too long for column 'ip' at row 1 How can it be solved? Running now Joomla 5.0.2 with PHP 8.2 and mysqli (MySQL 8.0). After many months of doing nothing on my J4 page (due to known issues of Themler) and some regrets as the first so called beta did not even work with blank and newly installed pages I just updated and start a new try. Regarding history: Page was created with J3 originally as well with a Themler desktop app theme. After an update to J4 the necessary deinstallation of themler theme was properly done and some more apps got deleted. Now I am on J5, as I wanted to believe to the news that it might work again. Thanks for any helpful answer Greeting Karsten
42 Comments
jamiemyy
jamiemyy posted this 08 March 2024
Hey, it seems that the 'ip' column in your Joomla database is receiving data that's longer than its defined length. Go to your database via a tool like phpMyAdmin. Look for the table that contains the 'ip' column, check the length defined for this column, it's likely defined as a VARCHAR with a certain length. I'd change the length to 128, or if its not defined as VARCHAR, change the definition to that and your issue should hopefully be solved. I had a similar issue on my unblocked games website, so consider myself an expert in this now, haha!
Hey, it seems that the 'ip' column in your Joomla database is receiving data that's longer than its defined length. Go to your database via a tool like phpMyAdmin. Look for the table that contains the 'ip' column, check the length defined for this column, it's likely defined as a VARCHAR with a certain length. I'd change the length to 128, or if its not defined as VARCHAR, change the definition to that and your issue should hopefully be solved. I had a similar issue on my [unblocked games][1] website, so consider myself an expert in this now, haha! [1]: https://www.hahagames.com
pabeta5868
pabeta5868 posted this 09 March 2024
Backup Your Database: Before making any changes, it's important to create a backup of your database to avoid any data loss in case something goes wrong during the process.
Check the Database Structure: Review the database structure to identify the 'ip' column in the table where the error is occurring. Check the data type and length of the 'ip' column to ensure it can accommodate the IP addresses.
Adjust the Column Length: If the 'ip' column is defined as VARCHAR or CHAR, you can try increasing the length of the column to ensure it can accommodate longer IP addresses. For example, you can alter the column to VARCHAR(255) to allow for longer IP addresses. driving directions
Backup Your Database: Before making any changes, it's important to create a backup of your database to avoid any data loss in case something goes wrong during the process. Check the Database Structure: Review the database structure to identify the 'ip' column in the table where the error is occurring. Check the data type and length of the 'ip' column to ensure it can accommodate the IP addresses. Adjust the Column Length: If the 'ip' column is defined as VARCHAR or CHAR, you can try increasing the length of the column to ensure it can accommodate longer IP addresses. For example, you can alter the column to VARCHAR(255) to allow for longer IP addresses. [driving directions][1] [1]: https://driving-directions.io
Karschten
Karschten posted this 09 March 2024
Hey,
first of all thanks to you both for these kind and informative answers.
I tried my best and failed, maybe due to missing knowledge. Nevertheless I used phpMyAdmin and the only entrance my eyes can find with "ip" is "ip_adress" in area "action_logs". There it is defined VARCHAR with a length of 40 - but changing VARCHAR(255) or VARCHAR(128) did not work or did not fix this issue. So maybe there is something else to find.
Using search function of phpMyAdmin I don't come to an end.
I might delete the old webpage completely and start at 0 with only an J5 installation. Maybe I can find the solution in database structure, when only Joomla5 and this "blank_themler_joomla4_theme" is installed.
Hey, first of all thanks to you both for these kind and informative answers. I tried my best and failed, maybe due to missing knowledge. Nevertheless I used phpMyAdmin and the only entrance my eyes can find with "ip" is "ip_adress" in area "action_logs". There it is defined VARCHAR with a length of 40 - but changing VARCHAR(255) or VARCHAR(128) did not work or did not fix this issue. So maybe there is something else to find. Using search function of phpMyAdmin I don't come to an end. I might delete the old webpage completely and start at 0 with only an J5 installation. Maybe I can find the solution in database structure, when only Joomla5 and this "blank_themler_joomla4_theme" is installed.
Karschten
Karschten posted this 10 March 2024
Update: Themler is not possible to use anymore - at least for me
I made the whole webspace and database area blank, later I installed new Joomla 5 and the "blank_themler_joomla4_theme". This more or less blank page runs and you can change template style standard to the Themler one. It works until you go for modifying the template...independently, if you use "Install Content Plugins" or if you go directly to "Run Theme Editor". And as long as you don't use "save" the webpage keeps running.
Until now 3 different errors appear (order in number of appearance):
0 - Class "Uri" not found
500 - Whoops, looks like something went wrong
by the way, just forgot:
PHP Version 8.2.15
System Linux
Webserver Apache 2.4.58 (Unix)
Server API CGI/FastCGI
mysql 10.6.15
Update: Themler is not possible to use anymore - at least for me I made the whole webspace and database area blank, later I installed new Joomla 5 and the "blank_themler_joomla4_theme". This more or less blank page runs and you can change template style standard to the Themler one. It works until you go for modifying the template...independently, if you use "Install Content Plugins" or if you go directly to "Run Theme Editor". And as long as you don't use "save" the webpage keeps running. Until now 3 different errors appear (order in number of appearance): 0 - Class "Uri" not found 1406 - Data too long for column 'ip' at row 1 500 - Whoops, looks like something went wrong by the way, just forgot: PHP Version 8.2.15 System Linux Webserver Apache 2.4.58 (Unix) Server API CGI/FastCGI mysql 10.6.15
sanskarishwetaroy
sanskarishwetaroy posted this 11 March 2024
Imagine the weave in your step strolling the rich streets of Delhi with Jannat; or participating in a fine supper inverse Pamela, perceiving what deduces whenever it's the best an entrance for desser. Unquestionably, life is better with a sweetheart. Permit us to sort out a couple of hours, or more, of refreshed reality. Our Escorts in Green Park are for the most part careful out in the open: refined, overall around styled at this point never conspicuous, they are ideal associates.
Imagine the weave in your step strolling the rich streets of Delhi with Jannat; or participating in a fine supper inverse Pamela, perceiving what deduces whenever it's the best an entrance for desser. Unquestionably, life is better with a sweetheart. Permit us to sort out a couple of hours, or more, of refreshed reality. Our [Escorts in Green Park][1] are for the most part careful out in the open: refined, overall around styled at this point never conspicuous, they are ideal associates. [1]: http://www.jannatzubair.in/green-park-call-girls.html
sanskarisumann
sanskarisumann posted this 23 March 2024
With us, you are promised to meet the most impressive Escorts Service in Saket, from home and overseas, and we are pleased to offer you a plethora of services, customized as per your specific needs and choices.
With us, you are promised to meet the most impressive [Escorts Service in Saket][1], from home and overseas, and we are pleased to offer you a plethora of services, customized as per your specific needs and choices. [1]: https://www.sanakhan.in/saket-call-girls.html
ayeshaakhanseo
ayeshaakhanseo posted this 25 April 2024
Hotel Vivanta by Taj Gurgaon Escort has extensive experience and is trained sensual experts, as well as being well-groomed and very personable. Their beauty draws people in; often becoming the centre of attention at parties and events due to their seducing body language of Escorts Service in Vivanta By Taj Hotel Gurgaon. Elite gentlemen from the highest circles of society typically seek beautiful women as the focus of their courting pursuits, hoping they'll help fulfill their sexual fantasies and fulfill intimate desires in life. Attractive babes provide these men with complete satisfaction in intimate affairs.
Hotel Vivanta by Taj Gurgaon Escort has extensive experience and is trained sensual experts, as well as being well-groomed and very personable. Their beauty draws people in; often becoming the centre of attention at parties and events due to their seducing body language of [Escorts Service in Vivanta By Taj Hotel Gurgaon](https://www.hotelescortsnearme.in/escorts-near-vivanta-by-taj-hotel-gurgaon.html). Elite gentlemen from the highest circles of society typically seek beautiful women as the focus of their courting pursuits, hoping they'll help fulfill their sexual fantasies and fulfill intimate desires in life. Attractive babes provide these men with complete satisfaction in intimate affairs.
frautim68
frautim68 posted this 03 May 2024
Stellar article, thank you for consistently delivering valuable insights. Solar
Stellar article, thank you for consistently delivering valuable insights. [Solar][1] [1]: https://medium.com/@joseph4ramos/everything-you-need-to-know-about-solar-community-in-tempe-arizona-265c2ef7cf1d
iampriyankapluss
iampriyankapluss posted this 11 May 2024
All these are the simplest Chawri Bazar High Profile Call Girls that you can hire. There are a number of Escort in Chawri Bazar who you can contact for your event. There are some agencies which allow you to call two or three girls for the price of one.
All these are the simplest Chawri Bazar High Profile Call Girls that you can hire. There are a number of [Escort in Chawri Bazar][1] who you can contact for your event. There are some agencies which allow you to call two or three girls for the price of one. [1]: https://www.julieoberoi.com/chawri-bazar-call-girls.html
foodlenyt88
foodlenyt88 posted this 17 May 2024
Essentially defined quordle is a brand-new word-puzzle game that operates similarly to Wordle but with a small difference.
Essentially defined [quordle](https://quordlegame.net) is a brand-new word-puzzle game that operates similarly to Wordle but with a small difference.
voipturks
voipturks posted this 19 May 2024
Smok e-sigara modelleri, ülkemizde özellikle elektronik sigara kullanmaya ilk defa başlayan kişilere tavsiye edilen en kullanışlı cihazlardan oluşmaktadır. Çin merkezli elektronik sigara şirketi olan Smok, son yıllarda ortaya koyduğu kaliteli ve ince işçiliğe sahip modelleri ile elektronik sigara endüstrisinin en çok tercih edilen ve en geniş satış hacimlerine ulaşan firmalarından biri olarak dikkatleri üzerine çekmektedir. Türkiye'de de Avrupa'nın pek çok ülkesinde olduğu gibi oldukça popüler olan Smok elektronik sigara markası, tecrübeli veya tecrübesiz tüm e-sigara tutkunlarına hitap eden cihazları ile yoğun talep görmeye devam etmektedir.
[Smok][1] e-sigara modelleri, ülkemizde özellikle elektronik sigara kullanmaya ilk defa başlayan kişilere tavsiye edilen en kullanışlı cihazlardan oluşmaktadır. Çin merkezli elektronik sigara şirketi olan Smok, son yıllarda ortaya koyduğu kaliteli ve ince işçiliğe sahip modelleri ile elektronik sigara endüstrisinin en çok tercih edilen ve en geniş satış hacimlerine ulaşan firmalarından biri olarak dikkatleri üzerine çekmektedir. Türkiye'de de Avrupa'nın pek çok ülkesinde olduğu gibi oldukça popüler olan Smok elektronik sigara markası, tecrübeli veya tecrübesiz tüm e-sigara tutkunlarına hitap eden cihazları ile yoğun talep görmeye devam etmektedir. [1]: https://buharkeyf01.com/smok-elektronik-sigara-satin-al
nehaaaduttt
nehaaaduttt posted this 23 January 2025
Delhi Escorts Service has been a game-changer for many looking for companionship. Our professional team ensures the highest standards of service, catering to all your needs. Whether you seek a night out or a more intimate experience, we’ve got you covered.
[Delhi Escorts][1] Service has been a game-changer for many looking for companionship. Our professional team ensures the highest standards of service, catering to all your needs. Whether you seek a night out or a more intimate experience, we’ve got you covered. [1]: https://www.meerachopra.co.in/
sapnamathur415
sapnamathur415 posted this 23 January 2025
I was hesitant to use Escort Service in Delhi at first, but I was pleasantly surprised. The experience was much more than just physical companionship. The escorts I met were charming and fun, which made it a truly memorable evening.
I was hesitant to use [Escort Service in Delhi][1] at first, but I was pleasantly surprised. The experience was much more than just physical companionship. The escorts I met were charming and fun, which made it a truly memorable evening. [1]: https://www.royalangels.in/
Lyly.gm19
Lyly.gm19 posted this 27 February 2025
The error occurs because the 'ip' column is too small; try changing its type to VARCHAR(45) in your database to support IPv6.
Stimulation Clicker
The error occurs because the 'ip' column is too small; try changing its type to VARCHAR(45) in your database to support IPv6. [Stimulation Clicker][1] [1]: https://stimulationclicker.com
leowang1934
leowang1934 posted this 04 March 2025
Hey Karsten, sorry to hear about the issue! That “1406 - Data too long” error can be a real pain. 🤔 Have you tried checking the column length in your database? Also, your mention of the blank theme made me think—just like a stimulation clicker helps refine training, maybe a fresh start on the database would help your site too! Good luck!
Hey Karsten, sorry to hear about the issue! That “1406 - Data too long” error can be a real pain. 🤔 Have you tried checking the column length in your database? Also, your mention of the blank theme made me think—just like a [stimulation clicker][1] helps refine training, maybe a fresh start on the database would help your site too! Good luck! [1]: https://stimulationclicker.site/
leowang1934
Hey Karsten, that error can be a bit tricky! Have you tried adjusting the column size for 'ip' in your database? Also, make sure your pixel path settings are updated—might help with compatibility!
Hey Karsten, that error can be a bit tricky! Have you tried adjusting the column size for 'ip' in your database? Also, make sure your [pixel path][1] settings are updated—might help with compatibility! [1]: https://pixelpath.net
leowang1934
Hey Karsten! That error’s a bummer 😕. Maybe try checking the database column sizes? Also, if you’re feeling a bit lost, a random Bible verse might bring some peace!
Hey Karsten! That error’s a bummer 😕. Maybe try checking the database column sizes? Also, if you’re feeling a bit lost, a [random Bible verse][1] might bring some peace! [1]: https://randombibleverse.top
mikeljorjin
mikeljorjin posted this 05 March 2025
This website https://t.me/london_club_y stands out with its clean design and effortless navigation. The high-quality visuals enhance its professional appearance, while fast loading speeds make browsing smooth. The responsive layout adapts seamlessly to any device. Information is easy to find thanks to the well-organized content. Elegant color schemes and fonts add a touch of sophistication. Overall, it’s a perfect combination of style and functionality.
annaeat02
annaeat02 posted this 26 March 2025
The streets are chaotic in escape road city 2. Each twist and turn presents a new danger, and only the fastest and most skilled can escape the city alive.
The streets are chaotic in [escape road city 2](https://escaperoadcity2.io/). Each twist and turn presents a new danger, and only the fastest and most skilled can escape the city alive.
BroderickHampton
BroderickHampton posted this 09 June 2025
Your Joomla site is running on MySQL 8 and PHP 8.2, which is fine, but the database schema for Joomla 5 (or leftover from Joomla 3/4) may have the ip field defined as VARCHAR(15) (which fits Unblocked Games G+ IPv4), but IPv6 addresses require up to 45 characters.
Your Joomla site is running on MySQL 8 and PHP 8.2, which is fine, but the database schema for Joomla 5 (or leftover from Joomla 3/4) may have the ip field defined as VARCHAR(15) (which fits [Unblocked Games G+][1] IPv4), but IPv6 addresses require up to 45 characters. [1]: https://unblockedgplusgames.com
