wordpress primary wiget area not working on pages
kerk_hof
kerk_hof posted this 13 February 2024
I put a primary widget area in the header, which should be in all templates. The widget contains a menu to the pages.
Now on the homepage the widget is fine, but on the rest of the pages (shared in all templates?) the menu is not showing the
links to the pages, only the the titles of the pages. I cannot navigate from any of the pages, except from my homepage only.
How can I fix this?
Thank you.
Hello I put a primary widget area in the header, which should be in all templates. The widget contains a menu to the pages. Now on the homepage the widget is fine, but on the rest of the pages (shared in all templates?) the menu is not showing the links to the pages, only the the titles of the pages. I cannot navigate from any of the pages, except from my homepage only. How can I fix this? Thank you.
kerk_hof
Never mind, alreay fixed it. The sections were overlapping ahem
Never mind, alreay fixed it. The sections were overlapping *ahem*
thomasfrank1803
thomasfrank1803 posted this 13 February 2025
Check your widget visibility settings in Appearance → Widgets to ensure it's set to show on all Chill Guy Clicker pages. Verify that your menu is correctly assigned in Appearance → Menus and that all pages are included.
Check your widget visibility settings in Appearance → Widgets to ensure it's set to show on all [Chill Guy Clicker][1] pages. Verify that your menu is correctly assigned in Appearance → Menus and that all pages are included. [1]: https://chillguygame.io
