Woocommerce mini-Cart is grey out
info32632
info32632 posted this 25 March 2024
Hello Themler Support Team,
I will add the widget woocommerce mini-cart to the site, but it is grey out, after an update from woocommerce.
They said, that the theme must be updated to use the mini-cart in the future.
Can you help me?
Antonio
Hello Themler Support Team, I will add the widget woocommerce mini-cart to the site, but it is grey out, after an update from woocommerce. They said, that the theme must be updated to use the mini-cart in the future. Can you help me? Thank you Antonio
23 Comments
donnajane1205
donnajane1205 posted this 09 September 2024
The retro graphics and smooth gameplay in Retro Bowl Unblocked make it a joy to play.
The retro graphics and smooth gameplay in [Retro Bowl Unblocked][1] make it a joy to play. [1]: https://retrobowl25.github.io/
cooleyomar4
cooleyomar4 posted this 17 October 2024
Hi Antonio,
It sounds like the issue with the greyed-out WooCommerce mini-cart widget is due to compatibility with your theme after the recent update. First, check if there’s an update available for your theme in Themler. Updating it may restore compatibility with the latest WooCommerce version. If your theme is already up to date and you’re still having issues, consider reaching out to Themler support directly for specific guidance or check their documentation for any adjustments you might need to make. Meanwhile, you could also explore using a different widget or plugin that offers similar functionality. Good luck!
Best,
ragdoll hit
Hi Antonio, It sounds like the issue with the greyed-out WooCommerce mini-cart widget is due to compatibility with your theme after the recent update. First, check if there’s an update available for your theme in Themler. Updating it may restore compatibility with the latest WooCommerce version. If your theme is already up to date and you’re still having issues, consider reaching out to Themler support directly for specific guidance or check their documentation for any adjustments you might need to make. Meanwhile, you could also explore using a different widget or plugin that offers similar functionality. Good luck! Best, [ragdoll hit](https://ragdollhit.io/)
blockblastgame.org
blockblastgame.org posted this 21 October 2024
Run 3 starts out quite easy, but as you progress, the challenges become more complex, with changing terrain and requiring the player to react faster.
[Run 3][1] starts out quite easy, but as you progress, the challenges become more complex, with changing terrain and requiring the player to react faster. [1]: https://run3d.io
Lyly.gm19
Lyly.gm19 posted this 02 January 2025
To use the WooCommerce mini-cart widget, update your Themler theme to the latest version for Agario compatibility with WooCommerce updates. If issues persist, contact Themler support for assistance.
Hi, To use the WooCommerce mini-cart widget, update your Themler theme to the latest version for [Agario][1] compatibility with WooCommerce updates. If issues persist, contact Themler support for assistance. [1]: https://agargame.io
ellie.bit03
ellie.bit03 posted this 09 January 2025
Feel the adrenaline rush as you lead your team to victory in retro bowl, where every touchdown is a testament to your skill and determination!
Feel the adrenaline rush as you lead your team to victory in [retro bowl](https://retrobowl25.io/), where every touchdown is a testament to your skill and determination!
jameswalterra8262
jameswalterra8262 posted this 01 May 2025
The WooCommerce mini-cart widget being greyed out is likely due to basement remodel atlanta changes in the latest WooCommerce update. As WooCommerce now requires theme support for this widget, your Themler theme needs to be updated to include compatibility.
The WooCommerce mini-cart widget being greyed out is likely due to [basement remodel atlanta](https://atlantabasementrenovations.com/) changes in the latest WooCommerce update. As WooCommerce now requires theme support for this widget, your Themler theme needs to be updated to include compatibility.
California Business Journal
California Business Journal posted this 16 May 2025
Find out who wrote the old testament and how various authors and scribes shaped its content across different time periods.
Find out [who wrote the old testament][1] and how various authors and scribes shaped its content across different time periods. [1]: https://calbizjournal.com/when-was-the-old-testament-written/
eyeglassd
eyeglassd posted this 11 June 2025
If your WooCommerce mini-cart is greyed out, it might be a theme or script conflict—kind of like trying to see clearly without the right rectangle eyeglasses. Check your console for errors!
If your WooCommerce mini-cart is greyed out, it might be a theme or script conflict—kind of like trying to see clearly without the right [rectangle eyeglasses][1]. Check your console for errors! [1]: https://eyeglassdirect.co.uk/glasses/rectangle/
lboy29175
lboy29175 posted this 11 June 2025
Tucson, AZ, is home to numerous skilled masonry contractors specializing in brick, block, and stonework. With over 15 years of experience, these professionals offer a range of services, including installations and repairs for residential and commercial projects. Many Masonry contractor Tucson AZ contractors provide free quotes and competitive pricing, ensuring quality craftsmanship tailored to client needs. Whether building retaining walls or custom fireplaces, Tucson masonry contractors are dedicated to enhancing the beauty and durability of structures throughout the region.
Tucson, AZ, is home to numerous skilled masonry contractors specializing in brick, block, and stonework. With over 15 years of experience, these professionals offer a range of services, including installations and repairs for residential and commercial projects. Many [Masonry contractor Tucson AZ][1] contractors provide free quotes and competitive pricing, ensuring quality craftsmanship tailored to client needs. Whether building retaining walls or custom fireplaces, Tucson masonry contractors are dedicated to enhancing the beauty and durability of structures throughout the region. [1]: https://masonrycontractortucsonaz.com/
muzikkon.info
muzikkon.info posted this 17 June 2025
Looks like a theme compatibility issue—just as an outdated lute instrument might need tuning or repair to play correctly, your theme may need an update to work smoothly with the latest WooCommerce mini-cart feature.
Looks like a theme compatibility issue—just as an outdated [lute instrument][1] might need tuning or repair to play correctly, your theme may need an update to work smoothly with the latest WooCommerce mini-cart feature. [1]: https://www.muzikkon.com/pages/lute/
immense.mandrill.foix
immense.mandrill.foix posted this 14 July 2025
It's frustrating when updates from plugins like WooCommerce cause compatibility issues with themes. I had a similar experience when trying to integrate new widgets while playing Run 3 during breaks to clear my mind! Updating the theme is usually the best solution, but sometimes temporary workarounds exist.
It's frustrating when updates from plugins like WooCommerce cause compatibility issues with themes. I had a similar experience when trying to integrate new widgets while playing [Run 3](https://run3gamefree.com) during breaks to clear my mind! Updating the theme is usually the best solution, but sometimes temporary workarounds exist.
excited.rook335
excited.rook335 posted this 12 September 2025
Bebder Game surprises with its mix of parody and adventure, giving a playful spin to pixel RPGs.
[Bebder Game][1] surprises with its mix of parody and adventure, giving a playful spin to pixel RPGs. [1]: https://bebdergame.fun/
kennethanderson3495
kennethanderson3495 posted this 15 September 2025
Each new update of Moto X3M introduces fresh levels, keeping the experience exciting even for longtime fans.
Each new update of [Moto X3M](https://motox3mgame.org/) introduces fresh levels, keeping the experience exciting even for longtime fans.
laciloh164
laciloh164 posted this 25 October 2025
Woocommerce mini-Cart is grey out to provide the best solutions that are bringing the solutions that we are required to resolve the issues we face. From the Top Central Coast Carpenter I got the best services that can make the things right to provide the desired results. It is good and can make the ideas we need.
Woocommerce mini-Cart is grey out to provide the best solutions that are bringing the solutions that we are required to resolve the issues we face. From the [Top Central Coast Carpenter][1] I got the best services that can make the things right to provide the desired results. It is good and can make the ideas we need. [1]: https://carpentercentralcoast.com.au/
techtoolsnational02
techtoolsnational02 posted this 27 October 2025
National Techtools is an Indian supplier of a wide range of tools, machines, and equipment based in Junagadh, Gujarat. Founded in 2014, the company sells its products both online and at a physical store, catering to professionals and DIY enthusiasts across various industries.
[National Techtools][1] is an Indian supplier of a wide range of tools, machines, and equipment based in Junagadh, Gujarat. Founded in 2014, the company sells its products both online and at a physical store, catering to professionals and DIY enthusiasts across various industries. [1]: http://nationaltechtools.com
xielili588
xielili588 posted this 08 November 2025
Master the art of high-speed cornering on vibrant, winding circuits in Drift Boss Game, where precision steering meets instant browser-based action for uninterrupted racing thrills.
Master the art of high-speed cornering on vibrant, winding circuits in [Drift Boss Game](https://www.drift-boss.cc/), where precision steering meets instant browser-based action for uninterrupted racing thrills.
Irrahsagittarian23
Irrahsagittarian23 posted this 08 November 2025
Hi Antonio, that usually happens when WooCommerce releases a major update and the theme’s widget compatibility hasn’t caught up yet. You might need to update or re-install the latest version of your Themler theme files. Before making any changes, it’s a good idea to back up your site data, I use https://teraprobox.com
for quick and secure backups.
Hi Antonio, that usually happens when WooCommerce releases a major update and the theme’s widget compatibility hasn’t caught up yet. You might need to update or re-install the latest version of your Themler theme files. Before making any changes, it’s a good idea to back up your site data, I use https://teraprobox.com for quick and secure backups.
luqmanq759
luqmanq759 posted this 05 January 2026
This is a common WooCommerce issue, and it’s great that it’s being discussed. A greyed-out mini-cart can often be caused by theme conflicts, caching plugins, or AJAX/cart fragment issues, and identifying the root cause is key to improving user experience and conversions. Clear solutions like this are really helpful for store owners. Just like users look for updated and reliable resources such as lista iptv m3u 2026, having accurate and up-to-date fixes for WooCommerce problems is extremely valuable. Thanks for sharing this insight!
This is a common WooCommerce issue, and it’s great that it’s being discussed. A greyed-out mini-cart can often be caused by theme conflicts, caching plugins, or AJAX/cart fragment issues, and identifying the root cause is key to improving user experience and conversions. Clear solutions like this are really helpful for store owners. Just like users look for updated and reliable resources such as [lista iptv m3u 2026][1], having accurate and up-to-date fixes for WooCommerce problems is extremely valuable. Thanks for sharing this insight! [1]: https://ativadorparapc.com/lista-iptv-gratis-definitiva/
ayaanshoaib730
ayaanshoaib730 posted this 16 January 2026
This post was a terrific read with lots of useful information. I am grateful you shared it with us. I will absolutely share it and follow your work.
https://activadorcrack.com/techsmith-snagit-2023-crack/
This post was a terrific read with lots of useful information. I am grateful you shared it with us. I will absolutely share it and follow your work. https://activadorcrack.com/techsmith-snagit-2023-crack/ https://activadorcrack.com/techsmith-snagit-2023-crack/
ayaanshoaib730
ayaanshoaib730 posted this 21 January 2026
It is quite beneficial to read this. I will surely keep that as a note for subsequent use. Good job!
https://pcfilehub.com/manycam-pro-crackeado/
It is quite beneficial to read this. I will surely keep that as a note for subsequent use. Good job! https://pcfilehub.com/manycam-pro-crackeado/ https://pcfilehub.com/manycam-pro-crackeado/ https://pcfilehub.com/manycam-pro-crackeado/ https://pcfilehub.com/manycam-pro-crackeado/
