Hello, the cart page in themler - virtuemart 4 - joomla 4 - php8 template gives the following error
0 - Call to undefined method Joomla\CMS\Application\SiteApplication::isSite()
The error message you’re encountering—0 - Call to undefined method Joomla\CMS\Application\SiteApplication::isSite()—indicates that there’s an issue with a method call related to the SiteApplication class in Joomla. Let’s address this:
Method Compatibility:
The method isSite() has been removed in Joomla 4.
Instead, use isClient() (available from Joomla 3.7) to determine whether the application is running in the site context.
Update Extensions:
Check if any extensions (plugins, modules, or components) are calling the deprecated method.
Update these extensions to versions compatible with Joomla 4.
Debugging:
Enable debugging mode in Joomla to get more detailed information about where the error occurs.
Look for the specific file and line number causing the issue.
Best Regard,
Gregory Chavez
MyDestinyCard Com
The error "Call to undefined method Joomla\CMS\Application\SiteApplication::isSite()" usually occurs when you are using a newer version of Joomla (e.g. Joomla 4) with an older template or component (e.g. VirtueMart 4) is not compatible with new Joomla versions.
To resolve this issue, you can try the following steps:
Check that you are using a version of VirtueMart 4 that is compatible with Joomla 4. If not, update to a newer version of VirtueMart.
Check that you are using a Joomla 4 compatible template. If not, update to a newer Joomla 4 compatible template.
If you still get the error, you can try modifying the template or VirtueMart component code file directly to use the Joomla 4 compatible method.
For example, you can replace $app->isSite() with $app->isClient('site') in the relevant code file.
Bubble shooter
If you are still having problems, you can seek support from the Joomla community or contact the template or component provider VirtueMart for further assistance.
