I have defined the table settings in the template - works great. But if I add a table through the editor, I cant seem to be able to override the template's table background settings. So in this case, the first row is grey. When I add a "hidden" table, then I would rather not see the grey box. Is there a way to override it?
Adding a style to the table through the editor seems to have no effect.
thanks
Hi, I have defined the table settings in the template - works great. But if I add a table through the editor, I cant seem to be able to override the template's table background settings. So in this case, the first row is grey. When I add a "hidden" table, then I would rather not see the grey box. Is there a way to override it? Adding a style to the table through the editor seems to have no effect. thanks
