If you're looking to change the separator image path in the Foods and Drinks Menu plugin, the location is often defined within the plugin's template files, settings files, or stylesheet references. A good starting point is to search the plugin directory for the current image filename or URL, which can help identify exactly where the path is being loaded from. Depending on how the plugin is built, you may be able to replace the image through plugin settings or by editing the relevant template file.
For comparison, many brands maintain consistent visual elements across their menus and promotions, similar to how a recognizable wendys frosty flavor helps create a familiar experience for customers.
For comparison, many brands maintain consistent visual elements across their menus and promotions, similar to how a recognizable [wendys frosty flavor][1] helps create a familiar experience for customers.
[1]: https://menuatwendys.com/wendys-frosty/
