Advanced Custom Fields plugin probleme
deunsdenis
deunsdenis posted this 26 August 2015
hi,
I have a code to integrate in the file ( single.php) for display my field.
<?php the_field('titre'); ?>
where be it the place for my personalized field is found between the content and the comments of an article?
see attached file
thx
hi, I have a code to integrate in the file ( single.php) for display my field. <?php the_field('titre'); ?> where be it the place for my personalized field is found between the content and the comments of an article? see attached file thx
92 Comments
Is Solution
Stagger Lee posted this 26 August 2015
Try it this way.
How do you insert it ? It will work only with CMS Code control.
<?php
     if( function_exists('get_field')) {
         if(get_field('my_custom_field')) {
             echo '<p>' . get_field('my_custom_field') . '</p>';
Try it this way. How do you insert it ? It will work only with CMS Code control. <?php if( function_exists('get_field')) { if(get_field('my_custom_field')) { echo '<p>' . get_field('my_custom_field') . '</p>'; } } ?>
deunsdenis
deunsdenis posted this 27 August 2015
Thank you for your answer.
with theme fourteen i insert just after
`get_template_part( 'content', get_post_format() );`
 <?php
 * The Template for displaying all single posts
 * @package WordPress
 * @subpackage Twenty_Fourteen
 * @since Twenty Fourteen 1.0
get_header(); ?>
    <div id="primary" class="content-area">
        <div id="content" class="site-content" role="main">
            <?php
                // Start the Loop.
                while ( have_posts() ) : the_post();
                     * Include the post format-specific template for the content. If you want to
                     * use this in a child theme, then include a file called called content-___.php
                     * (where ___ is the post format) and that will be used instead.
         if(get_field('titre')) {
             echo '<p>' . get_field('titre') . '</p>';
Is good my display field is good (see below)
is good for fourteen theme
But i don't know insert this code for theme themler . i don't find get_template_part( 'content', get_post_format() ); for insert my code.
My field is not found the right place ( see below)
not good with themler
thx for help
deuns26
ps: if we could THEMLER in php in html code to echo.(his would be the dream)
Thank you for your answer. with theme fourteen i insert just after `get_template_part( 'content', get_post_format() );` <?php /** * The Template for displaying all single posts * * @package WordPress * @subpackage Twenty_Fourteen * @since Twenty Fourteen 1.0 */ get_header(); ?> <div id="primary" class="content-area"> <div id="content" class="site-content" role="main"> <?php // Start the Loop. while ( have_posts() ) : the_post(); /* * Include the post format-specific template for the content. If you want to * use this in a child theme, then include a file called called content-___.php * (where ___ is the post format) and that will be used instead. */ get_template_part( 'content', get_post_format() ); if( function_exists('get_field')) { if(get_field('titre')) { echo '<p>' . get_field('titre') . '</p>'; } } Is good my display field is good (see below)![is good for fourteen theme][1] But i don't know insert this code for theme themler . i don't find `get_template_part( 'content', get_post_format() );` for insert my code. My field is not found the right place ( see below) ![not good with themler][2] [1]: http://s22.postimg.org/bc2p9gsi9/theme_fourteen.jpg [2]: http://s23.postimg.org/vd62mao7f/theme_themler.jpg thx for help deuns26 ps: if we could THEMLER in php in html code to echo.(his would be the dream)
Stagger Lee posted this 27 August 2015
You are confuse and need to read old topics here at forum and documentation.
You dont touch PHP files. Go to the Insert tab and find CMS Code control. Drag and drop it wehere you want, and paste this ACF code inside.
You are confuse and need to read old topics here at forum and documentation. You dont touch PHP files. Go to the Insert tab and find CMS Code control. Drag and drop it wehere you want, and paste this ACF code inside.
deunsdenis
I understand thx
I did not know it was possible to do this
It's good
thank you for taking the time to answer me
I wish you a good day
I vote STAGGER LEE :-)
Hi I understand thx I did not know it was possible to do this It's good thank you for taking the time to answer me I wish you a good day I vote STAGGER LEE :-)
You are welcome.
Take it easy to avoid frustration. Give Themler few weeks, it is much more complex and difficult than Artisteer.
You are welcome. Take it easy to avoid frustration. Give Themler few weeks, it is much more complex and difficult than Artisteer.
deunsdenis
yes themler is difficult vs artisteer but is very good.
PS:
simply
<?php the_field('my_custom_field'); ?>
work too
thx and good bb
yes themler is difficult vs artisteer but is very good. PS: simply <?php the_field('my_custom_field'); ?> work too thx and good bb
Use above code and WP will not spit you errors, and probably blank page, if new WP version stop to work with your version of ACF.
deunsdenis
deunsdenis posted this 28 August 2015
Yes you are right , I begin the code , so not easy at the beginning.
I try to convert your code to work with my other fields.
example: I tested for image fields,can be , not fair, but his works.
<?php
         if(get_field('image')) {
           echo '<p><img src="'.get_field('image').'"/></p>';
ACF other fields are more complicated, but I will succeed
Yes you are right , I begin the code , so not easy at the beginning. I try to convert your code to work with my other fields. example: I tested for image fields,can be , not fair, but his works. <?php if( function_exists('get_field')) { if(get_field('image')) { echo '<p><img src="'.get_field('image').'"/></p>'; } } ?> ACF other fields are more complicated, but I will succeed
fannindion
fannindion posted this 25 April 2025
A lot of websites put a personalized input field right between the article's main content and the comments part. This could be a registration form, a feedback box, or a field for users to leave comments slope 2. This lets people interact with the material before or after reading the comments of others.
A lot of websites put a personalized input field right between the article's main content and the comments part. This could be a registration form, a feedback box, or a field for users to leave comments [slope 2][1]. This lets people interact with the material before or after reading the comments of others. [1]: https://slope-2.io/
rosiewilsonnsjh
rosiewilsonnsjh posted this 10 June 2025
Go to the Joomla! Admin page and click on Content > Fields . To make a new unique field, click on "New." Fill in the information asked for in your area, such as the title, type, brainrot clicker Make sure you put it in the right place, like "Articles."
Go to the Joomla! Admin page and click on Content > Fields . To make a new unique field, click on "New." Fill in the information asked for in your area, such as the title, type, [brainrot clicker](https://brainrotclicker.io/) Make sure you put it in the right place, like "Articles."
lindasmile116
lindasmile116 posted this 24 September 2025
The Advanced Custom Fields plugin is incredibly useful for adding custom content to WordPress sites, but it can sometimes be tricky to position the fields exactly where you want, especially if you're trying to insert them between specific elements like content and steal a brainrot comments.
The Advanced Custom Fields plugin is incredibly useful for adding custom content to WordPress sites, but it can sometimes be tricky to position the fields exactly where you want, especially if you're trying to insert them between specific elements like content and [steal a brainrot][1] comments. [1]: https://steal-brainrot.io/
posuklouf
posuklouf posted this 27 September 2025
ACF can be a pain sometimes, especially with different themes! Glad to see people helping each other out. Hope deunsdenis figures it out, Themler sounds like a beast compared to Artisteer, haha! Bloodmoney | 67 Clicker
ACF can be a pain sometimes, especially with different themes! Glad to see people helping each other out. Hope deunsdenis figures it out, Themler sounds like a beast compared to Artisteer, haha! [Bloodmoney][1] | [67 Clicker][2] [1]: https://bloodmoney-game.app [2]: https://67clicker.pro
arnlodbevis
arnlodbevis posted this 22 October 2025
In Plants vs Brainrots, the Rhino Toasterino is a limited Brainrot that generates $500/s in Normal trait income.
In [Plants vs Brainrots][1], the Rhino Toasterino is a limited Brainrot that generates $500/s in Normal trait income. [1]: https://plantsbrainrots.io/
selenamoha276
selenamoha276 posted this 28 October 2025
Clicker Games online combine simplicity and strategy, making them perfect for players who enjoy steady growth and engaging mechanics without overwhelming complexity.
[Clicker Games][1] online combine simplicity and strategy, making them perfect for players who enjoy steady growth and engaging mechanics without overwhelming complexity. [1]: https://clickergamesaz.io
maxfelix868
maxfelix868 posted this 29 October 2025
Festivals celebrating performing arts unite cultures under shared experiences. From Shakespearean festivals to Bollywood dance events, they provide stages for both tradition and innovation. Audiences witness creativity beyond borders. These gatherings encourage dialogue, inspire collaboration, and strengthen cultural appreciation, showing how performance serves as a universal language of connection. www.auctionsearchprofits.com
Festivals celebrating performing arts unite cultures under shared experiences. From Shakespearean festivals to Bollywood dance events, they provide stages for both tradition and innovation. Audiences witness creativity beyond borders. These gatherings encourage dialogue, inspire collaboration, and strengthen cultural appreciation, showing how performance serves as a universal language of connection. [www.auctionsearchprofits.com][1] [1]: https://www.auctionsearchprofits.com/
maxfelix868
Gardening supports mental clarity and mindfulness. Spending time nurturing plants encourages us to slow down and live in the moment. Observing small details—like new leaves sprouting or a flower blooming—helps shift focus away from daily stress. A home garden becomes a personal retreat that promotes calmness and serenity. www.myoldcokecountyhome.com
Gardening supports mental clarity and mindfulness. Spending time nurturing plants encourages us to slow down and live in the moment. Observing small details—like new leaves sprouting or a flower blooming—helps shift focus away from daily stress. A home garden becomes a personal retreat that promotes calmness and serenity. [www.myoldcokecountyhome.com][1] [1]: https://www.myoldcokecountyhome.com/
maxfelix868
The rise of cyberwarfare blurs the line between military and civilian life. Societies now face threats that target infrastructure, businesses, and individuals. Defending against these invisible enemies requires cooperation between military experts and ordinary citizens who manage critical technologies. www.profitdonationcapitalism.org
The rise of cyberwarfare blurs the line between military and civilian life. Societies now face threats that target infrastructure, businesses, and individuals. Defending against these invisible enemies requires cooperation between military experts and ordinary citizens who manage critical technologies. [www.profitdonationcapitalism.org][1] [1]: https://www.profitdonationcapitalism.org/
maxfelix868
Real estate crowdfunding has democratized property investing. Businesses now use platforms to raise capital from small investors, making large projects accessible to many. This trend reshapes real estate finance, enabling businesses to tap into broader funding pools while giving individuals the chance to participate in lucrative property markets. www.rghhomes.com
Real estate crowdfunding has democratized property investing. Businesses now use platforms to raise capital from small investors, making large projects accessible to many. This trend reshapes real estate finance, enabling businesses to tap into broader funding pools while giving individuals the chance to participate in lucrative property markets. [www.rghhomes.com][1] [1]: https://www.rghhomes.com/
maxfelix868
Paywalls have sparked debate within the media industry. While they generate revenue, they limit access to essential information. Some outlets experiment with hybrid models—keeping vital public-interest reporting free while charging for premium content. This approach helps balance sustainability with public responsibility to keep critical information widely available. www.galaxyartsinc.com
Paywalls have sparked debate within the media industry. While they generate revenue, they limit access to essential information. Some outlets experiment with hybrid models—keeping vital public-interest reporting free while charging for premium content. This approach helps balance sustainability with public responsibility to keep critical information widely available. [www.galaxyartsinc.com][1] [1]: https://www.galaxyartsinc.com/
maxfelix868
maxfelix868 posted this 12 November 2025
Stage makeup is another hidden hero in performing arts. It exaggerates features so that expressions are visible even from the last row. Beyond visibility, makeup transforms actors into mythical creatures, villains, or heroes. The performing arts thrive on these transformations, reminding us of the magic of illusion. www.socialprofitstrategies.net
Stage makeup is another hidden hero in performing arts. It exaggerates features so that expressions are visible even from the last row. Beyond visibility, makeup transforms actors into mythical creatures, villains, or heroes. The performing arts thrive on these transformations, reminding us of the magic of illusion. [www.socialprofitstrategies.net][1] [1]: https://www.socialprofitstrategies.net/
