posted this
28 August 2015
1- ON HOW MANY DIFFERENT PC CAN INSTALL THEMLER desktop?
One desktop and one laptop.
2- HOW TO MOVE THE LICENSE BETWEEN PC, HOW UNINSTALL AND DEACTIVATE ACTIVATE desktop?
Install and uninstall in a usual way and then Sign in when Themler asks.
We have server limitations on a number of connections. You will not have any problems if you're using Themler by yourself.
3- HOW TO SELECT THE VERSION OF JOOMLA IN THEMLER (2.5 OR 3.4)
Themler desktop install only Joomla 3.3.1
If you need to try Themler on joomla 2.5 you will need to download Themler theme and use it on your local/hosted joomla 2.5.
4- WHY AFTER EXTENDED LICENSE OF Artisteer IF I EXPORTING TO JOOMLA I SEE IN PLUGIN 3.2-3.3 AND NOT 3.2-3.4?
This is old note. The themes work ok on Joomla 3.4 too.
Please note that if you want to convert Artistere joomla theme to themler theme you should export Artisteer theme from Artisteer as Themler theme for Joomla.
!joomla-export.png!
