Joomla 5 Upgrade
bernd33
bernd33 posted this 28 March 2025
I'm working at the moment on an upgrade for a friend.
He used Joomla 3 and Themler and now wants to upgrade to joomla 5.
I got a testpage and upgraded joomla now to version 5.2.5.
Now I want to install a fresh themler, to rebuild his existing page.
But when I install the themler template (untitled) and want to access that template I get errors :(
Attempted to call an undefined method named "isAdmin" of class "Joomla\CMS\Application\SiteApplication".
Does anybody got that issue too ?
kind regards
Bernd
Hi, I'm working at the moment on an upgrade for a friend. He used Joomla 3 and Themler and now wants to upgrade to joomla 5. I got a testpage and upgraded joomla now to version 5.2.5. Now I want to install a fresh themler, to rebuild his existing page. But when I install the themler template (untitled) and want to access that template I get errors :( Attempted to call an undefined method named "isAdmin" of class "Joomla\CMS\Application\SiteApplication". Does anybody got that issue too ? kind regards Bernd
aisha85adams
aisha85adams posted this 29 March 2025
The issue you’re facing seems to be a compatibility problem between Themler and Joomla 5.2.5, as the isAdmin method appears to be missing in the SiteApplication class of Joomla 5. This is likely due to changes in Joomla's API from earlier versions. To resolve this, first ensure you're using the latest version of Themler, which may address compatibility issues. If the error persists, enable error reporting in Joomla to pinpoint the source of the problem. You might need to update the code manually to align with Joomla 5’s API, replacing calls to isAdmin with methods compatible with the new version.
Aisha
pikepass
Hello, The issue you’re facing seems to be a compatibility problem between Themler and Joomla 5.2.5, as the `isAdmin` method appears to be missing in the `SiteApplication` class of Joomla 5. This is likely due to changes in Joomla's API from earlier versions. To resolve this, first ensure you're using the latest version of Themler, which may address compatibility issues. If the error persists, enable error reporting in Joomla to pinpoint the source of the problem. You might need to update the code manually to align with Joomla 5’s API, replacing calls to `isAdmin` with methods compatible with the new version. Regards, Aisha [pikepass][1] [1]: https://www-pikepass.com
valariemoody
valariemoody posted this 23 December 2025
It's a very challenging problem. Upgrading Joomla 5 necessitates a consistent version answer. Thank you for sharing, I will be able to study and discover more excellent resources. Geometry Online is an online game that may be played on a variety of platforms, including PCs, laptops, and web browsers.
It's a very challenging problem. Upgrading Joomla 5 necessitates a consistent version answer. Thank you for sharing, I will be able to study and discover more excellent resources. [Geometry Online][1] is an online game that may be played on a variety of platforms, including PCs, laptops, and web browsers. [1]: https://geometryonline.io/
dajah60378
dajah60378 posted this 03 January 2026
Upgrading to Joomla 5 is a great move for site stability, especially for developers looking to optimize the mobile experience for high-traffic platforms. If you are managing a gaming site or looking to distribute a specific APK, the new system's speed and security improvements make it much easier to integrate local payment gateways like JazzCash and EasyPaisa. It’s definitely the right time to transition if you want to offer a seamless, real-money gaming experience to your users on mobile
Upgrading to Joomla 5 is a great move for site stability, especially for developers looking to optimize the mobile experience for high-traffic platforms. If you are managing a gaming site or looking to distribute a specific [APK][1], the new system's speed and security improvements make it much easier to integrate local payment gateways like JazzCash and EasyPaisa. It’s definitely the right time to transition if you want to offer a seamless, real-money gaming experience to your users on mobile [1]: https://lucky101-game.com.pk/lucky-101-login/
eja.ge.r.m
eja.ge.r.m posted this 18 March 2026
Upgrading your site to Joomla 5 is a major technical milestone, much like using the SRD Status Checker to monitor your social relief application progress. The error you are seeing occurs because the isAdmin() method was deprecated and removed in Joomla 4 and 5; it must be replaced with isClient('administrator') in the code. Ensuring your Themler version is updated to v.567 or higher is the primary way to fix this available SRD grants, as these later versions specifically include compatibility for the modern Joomla API.
Upgrading your site to Joomla 5 is a major technical milestone, much like using the SRD Status Checker to monitor your social relief application progress. The error you are seeing occurs because the isAdmin() method was deprecated and removed in Joomla 4 and 5; it must be replaced with isClient('administrator') in the code. Ensuring your Themler version is updated to v.567 or higher is the primary way to fix this [available SRD grants][1], as these later versions specifically include compatibility for the modern Joomla API. [1]: https://mysrdstatuschecker.co.za/types-of-sassa-grants/
saimali90990
saimali90990 posted this 04 August 2026
Upgrading to Joomla 5 certainly improves performance and security, which is especially valuable for gaming and download websites. A faster and more stable platform also creates a better experience for users looking for trusted mobile gaming resources. If you're interested in exploring real-money gaming apps, Lucky 101 game apk is another option worth checking out for its smooth interface and mobile-friendly gameplay.
Upgrading to Joomla 5 certainly improves performance and security, which is especially valuable for gaming and download websites. A faster and more stable platform also creates a better experience for users looking for trusted mobile gaming resources. If you're interested in exploring real-money gaming apps, [Lucky 101 game apk][1] is another option worth checking out for its smooth interface and mobile-friendly gameplay. [1]: https://lucky101app.com/
saimali90990
saimali90990 posted this 05 August 2026
Modern websites and applications perform much better when they focus on speed, security, and an intuitive user experience. The same expectations apply to mobile gaming, where players appreciate platforms that are reliable and easy to navigate. If you're interested in exploring entertaining mobile games, Luck 33 Game is worth checking out for its responsive interface, diverse game selection, and convenient payment options like JazzCash and EasyPaisa.
Modern websites and applications perform much better when they focus on speed, security, and an intuitive user experience. The same expectations apply to mobile gaming, where players appreciate platforms that are reliable and easy to navigate. If you're interested in exploring entertaining mobile games, [Luck 33][1] Game is worth checking out for its responsive interface, diverse game selection, and convenient payment options like JazzCash and EasyPaisa. [1]: https://luck33game.com/
saimali90990
A well-optimized platform always creates a better experience by improving stability, loading speed, and overall usability. Mobile gaming users also prefer apps that are simple to install and easy to explore. For those looking for a modern gaming platform in Pakistan, Star game download offers an enjoyable collection of games, smooth performance, and convenient payment methods including JazzCash and EasyPaisa, making it a practical choice for everyday entertainment.
A well-optimized platform always creates a better experience by improving stability, loading speed, and overall usability. Mobile gaming users also prefer apps that are simple to install and easy to explore. For those looking for a modern gaming platform in Pakistan, [Star game download][1] offers an enjoyable collection of games, smooth performance, and convenient payment methods including JazzCash and EasyPaisa, making it a practical choice for everyday entertainment. [1]: https://stargamedownload.cloud/
