no add section , don't work
spok
spok posted this 23 April 2025
when I open from library it is empty. There is no item to add in library. there is a message -
"No results were found."
no matter if I'm looking for something or not, this message is unchanged.
when I open from library it is empty. There is no item to add in library. there is a message - "No results were found." no matter if I'm looking for something or not, this message is unchanged.
spok
it also doesn't work locally on the computer and on another where I installed the latest version. Is this the problem with you?
ralphray89046
ralphray89046 posted this 18 June 2025
@slope game the machine where I installed the most recent version does not function locally. Are you having trouble with this?
@[slope game][1] the machine where I installed the most recent version does not function locally. Are you having trouble with this? [1]: https://slopegame3d.org
ralphray89046
ralphray89046 posted this 08 September 2025
@speed stars Are you experiencing issues with the machine where I installed the latest version not working locally?
@[speed stars][1] Are you experiencing issues with the machine where I installed the latest version not working locally? [1]: https://speedstars-game.io
shana598brush
shana598brush posted this 08 September 2025
This usually means the library isn’t properly indexed or synced. Try restarting the app, checking your internet connection, and ensuring the content source is correctly linked. If it persists, clear the cache or reinstall the app to refresh the library. HHAeXchange
> when I open from library it is empty. There is no item to add in library. there is a message - > "No results were found." > no matter if I'm looking for something or not, this message is unchanged. This usually means the library isn’t properly indexed or synced. Try restarting the app, checking your internet connection, and ensuring the content source is correctly linked. If it persists, clear the cache or reinstall the app to refresh the library. [HHAeXchange][1] [1]: https://www.hhaexchange.com.co
