I installed your program on a clean computer where it wasn't there before. I logged in, and I have the same problem as on previous ones. The library is empty. The photo library loads but the section elements don't. I get the message "no results a.....". It's not the computer's configuration that's the problem, but the connection or access to your database. I don't have an antivirus and I turned off the firewall.
Maybe there is some ban on IP addresses from my pool?
I have previously installed the current themler on another computer and it is exactly the same. The photo library loads but the section library does not.
I installed your program on a clean computer where it wasn't there before. I logged in, and I have the same problem as on previous ones. The library is empty. The photo library loads but the section elements don't. I get the message "no results a.....". It's not the computer's configuration that's the problem, but the connection or access to your database. I don't have an antivirus and I turned off the firewall. Maybe there is some ban on IP addresses from my pool? I have previously installed the current themler on another computer and it is exactly the same. The photo library loads but the section library does not.
