Carousel with Multiple Small Images
stevens
stevens posted this 30 August 2015
Is there a way to use the Themler to add a sliding carousel with multiple images displayed at the same time?
Like http://jsfiddle.net/Va8Un/550/ or https://www.wonderplugin.com/wordpress-carousel/
Is there a way to use the Themler to add a sliding carousel with multiple images displayed at the same time? Like http://jsfiddle.net/Va8Un/550/ or https://www.wonderplugin.com/wordpress-carousel/
Stagger Lee posted this 31 August 2015
Not possible.
Install free Meta Slider plugin and use it in widget control area. You did not say what CMS it is ?
Not possible. Install free Meta Slider plugin and use it in widget control area. You did not say what CMS it is ?
stevens
stevens posted this 31 August 2015
Not possible.
Whoops. I'm running WordPress.
> Not possible. > > Install free Meta Slider plugin and use it in widget control area. You did not say what CMS it is ? Whoops. I'm running WordPress.
Bootstrap seems has this function. But I have no clue how to pull images from WP, right now. Anyway it is nothing you want, there are no options and all needs to be done in code.
Install Meta Slider and enjoy your free time.
http://bootsnipp.com/snippets/featured/simple-carousel
http://bootsnipp.com/snippets/featured/infinite-carousel-loop
http://bootsnipp.com/snippets/featured/thumbnail-carousel
Bootstrap seems has this function. But I have no clue how to pull images from WP, right now. Anyway it is nothing you want, there are no options and all needs to be done in code. Install Meta Slider and enjoy your free time. http://bootsnipp.com/snippets/featured/simple-carousel http://bootsnipp.com/snippets/featured/infinite-carousel-loop http://bootsnipp.com/snippets/featured/thumbnail-carousel
stevens
Good point.
Is it best practice to use a slider plugin as well for the main hero images? Or use Themler's slider?
> Bootstrap seems has this function. But I have no clue how to pull images from WP, right now. Anyway it is nothing you want, there are no options and all needs to be done in code. > > Install Meta Slider and enjoy your free time. > > http://bootsnipp.com/snippets/featured/simple-carousel > http://bootsnipp.com/snippets/featured/infinite-carousel-loop > http://bootsnipp.com/snippets/featured/thumbnail-carousel Good point. Is it best practice to use a slider plugin as well for the main hero images? Or use Themler's slider?
Is Solution
Themler slider wont give you carousel. Depends what do you need.
I personaly if dont need something advanced use Themler slider. One plugin less, as all this code inside Themler is already parsed and take own miliseconds of pageload.
Themler slider wont give you carousel. Depends what do you need. I personaly if dont need something advanced use Themler slider. One plugin less, as all this code inside Themler is already parsed and take own miliseconds of pageload.
