Morpheus0101
posted this
01 September 2015
Slider shortcode not playing. It works, but it does not autoplay. I have supplied an example below. Have I customized correctly? Looking through the documentation, it is not clear whether it is correct to keep the "speech marks" or not, but it makes no difference at the moment. Have tried with and without.
[slider css="slider" wide_slides="yes" wide_carousel="no" interval="3000"][slide]content here[/slide][slide]content here[/slide][/slider]
I am using Joomla 3.4.3 and have customized the Themler blank template.
Can anyone help on this?
Hi, Slider shortcode not playing. It works, but it does not autoplay. I have supplied an example below. Have I customized correctly? Looking through the documentation, it is not clear whether it is correct to keep the "speech marks" or not, but it makes no difference at the moment. Have tried with and without. [slider css="slider" wide_slides="yes" wide_carousel="no" interval="3000"][slide]content here[/slide][slide]content here[/slide][/slider] I am using Joomla 3.4.3 and have customized the Themler blank template. Can anyone help on this? Thanks
