Mysql & databases
Eric-P
Eric-P posted this 01 September 2015
Hello, I would like to know to Themler installed on Windows 8, it is possible to access a database phpmyadmin / Backup for MySQL databases.
Eric
Hello, I would like to know to Themler installed on Windows 8, it is possible to access a database phpmyadmin / Backup for MySQL databases. Eric
12 Comments
Support Team posted this 02 September 2015
Eric,
We do not restrict access to databases on your side.
Thank you!
Eric, We do not restrict access to databases on your side. Thank you!
Eric-P
Eric-P posted this 02 September 2015
then I can have access, what is the base url
http://127.0.0.1:12080 / phpmyadmin
then I can have access, what is the base url http://127.0.0.1:12080 / phpmyadmin
Chris
Chris posted this 02 September 2015
Themler does not include phpmyadmin in its installation.
But you can download and use it, if you want.
Please use these MySQL credentials:
Server Address: 127.0.0.1
Server Port: 12306
Login: root
Password:
We plan to add an option for full backup/restore to Themler soon.
Themler Support Team
Themler does not include phpmyadmin in its installation. But you can download and use it, if you want. Please use these MySQL credentials: Server Address: 127.0.0.1 Server Port: 12306 Login: root Password: We plan to add an option for full backup/restore to Themler soon. Thanks, Themler Support Team
Eric-P
thank you
thank you
wdale
wdale posted this 21 October 2015
Server Port: 12306
Login: root
Password:
> Themler does not include phpmyadmin in its installation. > > But you can download and use it, if you want. > > Please use these MySQL credentials: > > Server Address: 127.0.0.1 > Server Port: 12306 > Login: root > Password: > > We plan to add an option for full backup/restore to Themler soon. > > Thanks, > Themler Support Team > >
wdale
Themler support says that "We plan to add an option for full backup/restore to Themler soon."
Meanwhile Akeeba Backup works fine, but the Kickstart restore is more complicated, and has some pitfalls. I had to recover my website work after Themler locked me out and have worked all of that out. BTW, don't install a login module, and then shutdown Themler AFTER having logged out, or you will likely have the same problem.
It would likely take a few precious hours to type all of that information here, so I will defer that (unless someone has the need and is put in touch with me via an email from Themler support).
Themler support says that "We plan to add an option for full backup/restore to Themler soon." Meanwhile Akeeba Backup works fine, but the Kickstart restore is more complicated, and has some pitfalls. I had to recover my website work after Themler locked me out and have worked all of that out. BTW, don't install a login module, and then shutdown Themler AFTER having logged out, or you will likely have the same problem. It would likely take a few precious hours to type all of that information here, so I will defer that (unless someone has the need and is put in touch with me via an email from Themler support).
Albin Klein
Albin Klein posted this 15 April 2016
I just installed phpMyAdmin and it works perfectly with Themler instalation...
Thank you a lot!
I just installed phpMyAdmin and it works perfectly with Themler instalation... Thank you a lot!
david157
david157 posted this 19 May 2016
Hi Albin
I think you may be able to help me.
I'm trying to restore a database into Themler. It would be very helpful if you could let me know how you installed phpMyAdmin within Themler. If i can get this sorted, I will be able to restore the database.
In my opinion, it should really be integrated within Themler.
Many thanks in advance, David
Hi Albin I think you may be able to help me. I'm trying to restore a database into Themler. It would be very helpful if you could let me know how you installed phpMyAdmin within Themler. If i can get this sorted, I will be able to restore the database. In my opinion, it should really be integrated within Themler. Many thanks in advance, David
david157
I've actually already got Xampp v3.2.1 but no idea how to change the server port?
Thanks, David
I've actually already got Xampp v3.2.1 but no idea how to change the server port? Thanks, David
david157
I've now done that but can't login to phpMyadmin. Possibly something to do with config.inc.php but I'm giving up the will to live at the moment.
Thanks, David
Hi I've now done that but can't login to phpMyadmin. Possibly something to do with config.inc.php but I'm giving up the will to live at the moment. Thanks, David
Support Team posted this 24 May 2016
Hello David,
please refer to my response for topic
http://answers.themler.com/questions/79809/problem-starting-themler
Hello David, please refer to my response for topic http://answers.themler.com/questions/79809/problem-starting-themler regards, Aileen
jp107
jp107 posted this 19 August 2018
Server Port: 12306
Login: root
Password:
Hi has support been added yet?
Would like to copy my website to a development folder/database locally
> Themler does not include phpmyadmin in its installation. > > But you can download and use it, if you want. > > Please use these MySQL credentials: > > Server Address: 127.0.0.1 > Server Port: 12306 > Login: root > Password: > > We plan to add an option for full backup/restore to Themler soon. > > Thanks, > Themler Support Team > > Hi has support been added yet? Would like to copy my website to a development folder/database locally
